Jack ideas
Discussion in 'General Tundra Discussion' started by gladecreekwy, May 17, 2017.
  1. May 17, 2017 at 7:39 AM
    gladecreekwy
    gladecreekwy [OP] Wyoming
    J
    Jackson Wyoming
    2014 trd silver tundra
    6" lift, bumper and winch.
    This is the first truck I've had with a 6 in lift. Looking for a compact jack that stores easily and is stable enough to use off road.
    Any ideas ?
  2. May 17, 2017 at 7:59 AM
    Help New Member
    Tucson, AZ
    2014 Blue DC 5.7 FFV
    Bright pink truck nuts.
    A massive bottle jack might be the most compact solution aside from a hi-lift type jack.
    Bear, Jsena, gosolo and 1 other person like this.
  3. May 17, 2017 at 8:13 AM
    osidepunker
    osidepunker OsidePunker
    Alex
    2013 Tundra DC 4x4
    Full LT, full armor, fully self contained Speed Glamper
    Agreed. I use a big bottle jack for everything when on the trail. Floor jack when at home. I have a 60" hilift that I have never used lol
    Spolar, Jsena, gosolo and 2 others like this.
  4. May 17, 2017 at 8:16 AM
    You probably would run out of jack before suspension anyway Alex...I can relate.
    I use a 4x4 block of wood and HF bottle jack.
    Jsena, Bprose and osidepunker[QUOTED] like this.
  5. May 17, 2017 at 8:21 AM
    osidepunker
    Alex
    2013 Tundra DC 4x4
    Yeah I do. But lately I have been jacking from the control arm since its so long. Just use a block of wood to cushion the arm. This saves me from have to jack, block, and jack some more lol. The rear isn't a big deal as I jack from the axle.
    But if I'm in a bind on the trail, I now have hilift point on all four sides of the truck now. Its just never been needed
  6. May 17, 2017 at 8:26 AM
    I have to strap the axle to the frame if I'm gonna use a HL Jack. I assume you probably have to do the same, especially in the rear?
    Jsena likes this.
  7. May 17, 2017 at 9:52 AM
    osidepunker
    Alex
    2013 Tundra DC 4x4
    Not sure, I haven't jacked from the side. From the center rear, with a 60" jack, I can get the wheels off the ground. Its sketchy AF though. Now that you are making think about it, I probably do have to strap for a side lift. The rear has 17" travel and maybe 90% usable articulation. the front is 16" with maybe 80%. I might run out of jack before the wheels lift. I should test this
    040Tundra and ColoradoTJ[QUOTED] like this.
  8. May 17, 2017 at 10:59 AM
    On a 60" HL Jack, you may be ok.....but then you get into the jack lean, and sometimes that gets sketchy. You have more travel than I do and a 48" jack is worthless unless the axle is ratchet strapped.
    I found out the hard way on a trail many moons ago, figured I would pass down my dumb ass learning curve. The desert can be really unforgiving.
  9. May 17, 2017 at 11:08 AM
    Spvrtan
    Spvrtan Amateur fabricator
    Kris
    San Diego, CA
    Black '14 CM SR5 w/ SC; 40s on 17s; 5.29s
    I used my 48" Hi-Lift just fine on the trail (soft sand) to swap out a rear tire. That's with 37s on a 7" lift, too. Had no issues nor worry with the jack; that was jacking from the sliders.
    Jsena and 040Tundra like this.
  10. May 17, 2017 at 11:36 AM
    osidepunker
    Alex
    2013 Tundra DC 4x4
    Yeah dude thanks. I never really thought about it until you mentioned something. like I said, I jacked from the rear and I was able to lift the wheels, but jack lean sucked and I use a lot of my jack length to get it done. Next time I'm at camp I'll play with it and see what happens.
    Its a different story when you have MT leafs and control arms. You're not working with the same amount of suspension travel that I am or a jeep with a lot of flex. On my rear, 17" travel with maybe 90% usable articulation means that there can be roughly a 30" difference in suspension height between left and right tires. I would have to actually attempt it to see how much jack length would be required to lift a tire, but it's going to be a lot. Probably doable as long as the jack doesn't lean too much. Definitely not going to work with a 48" jack.
  11. May 17, 2017 at 12:23 PM
    Cool Alex. Let us know what you come up with. The ol' jack lean has earned me some dents in my body panels, that is for sure. Kinda sucks the way HL Jacks need to be set up at times. I would rather take a dent vs the alternative.
    osidepunker likes this.
  12. May 17, 2017 at 2:50 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    @gladecreekwy ,some good advice here.
    I'm always carrying the big bottle jack and hi-lift also. Usually have a packing blanket (primarily to toss on the winch cable) to prevent body panel damage from the jack lean. In the winter if I'm expecting I may need to chain up I'll throw in my light weight floor jack.
    Too much is better than too little.
    I'm not lifted as much as you all, but the problem still comes up.
  13. May 17, 2017 at 2:57 PM
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
  14. May 17, 2017 at 3:05 PM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    How many inches does that go up? 16??
  15. May 17, 2017 at 3:13 PM
    My 4 ton bottle jack extends to 15 1/8" and then the 4" block of wood.
    NewImprovedRon and Jsena[QUOTED] like this.
  16. May 17, 2017 at 3:19 PM
    Spvrtan
    Kris
    San Diego, CA
    This was the incident I was talking about..
    Krezz and Jsena like this.
  17. May 17, 2017 at 3:22 PM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    So you. Have rock sliders to use that
  18. May 17, 2017 at 3:22 PM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    How hig is your truck tj
  19. May 17, 2017 at 3:31 PM
    I use this for my Jeep Wrangler. It is on tons and 40" tires.
    My truck is just stock height.
    BestGen and Jsena[QUOTED] like this.
  20. May 17, 2017 at 3:41 PM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    Cool cool
    ColoradoTJ likes this.
  21. May 19, 2017 at 6:22 AM
    gladecreekwy
    J
    Jackson Wyoming
    ColoradoTJ and Jsena like this.
  22. May 19, 2017 at 8:25 AM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    Nope, but I'm looking for something besides that Hi jack to get my truck up when I lift it..
  23. May 19, 2017 at 8:26 AM
    JTP
    JTP The Big Black Moose
    Sterling, Alaska (Formerly DFW Texas)
    The Big Black Moose
    WHERE IN THE HECK CAN I GET ONE OF THESE?
  24. May 19, 2017 at 8:28 AM
    JTP
    The Big Black Moose
  25. May 19, 2017 at 8:54 AM
    JTP
    The Big Black Moose
    Ive got a 7" lift. Jacking the truck up to change a tire has been on my mind. Just bought this truck and don't know if the stock jack will get it off of the ground. This and a chunk of 6x6 timber and a chunk of 2x6 (to cushion between front end) will have to go in the truck some place. Description says 21" of lift. Will look further into all of this.
    They also have this same jack at Tractor Supply. Shows to be an in stock item that you can walk in and buy. $40.00
    Jsena and gosolo like this.
  26. May 19, 2017 at 10:04 AM
    Tacotundra
    Tacotundra New Member
    Vegas
    2022 Tundra
    Those look like would work nice price is not bad either.
    NewImprovedRon likes this.
  27. May 19, 2017 at 11:44 AM
    sdhq_offroad
    sdhq_offroad New Member
    GILBERT, AZ
    Jsena likes this.
  28. May 19, 2017 at 1:58 PM
    JTP
    The Big Black Moose
  29. May 19, 2017 at 2:21 PM
    sdhq_offroad
    GILBERT, AZ
    That is for the complete jack. It comes with the small 8" extension. However the extensions are sold separately but I cannot guarantee any fitment on other than the 1.5 and 2 ton harbor freight aluminum jacks.
  30. May 20, 2017 at 9:46 AM
    Jackalope
    Jackalope New Member
    Flagstaff, AZ
    2007 RCSB 5.7 4x4
    I use the pro eagle extension on a harbor freight 2.5 ton. I used a 1 1/8" hole saw to cut a hole in it and replace the existing pad. The twist mount feature was sketchy.
    Tibetan Nomad and gosolo like this.
