1st Gen(2UZ-FE) header options
Discussion in '1st Gen Tundras (2000-2006)' started by FirstGenVol, Sep 23, 2019.
  1. Oct 22, 2021 at 12:52 PM
    #151
    Dave8699
    Dave8699 Trackrat
    NJ
    04 Tundra AC, 2014 Tundra 1794 Crew Max
    Whole truck Raptor liner in olive green, leer camper cap, 5100 with OME, Wheelers AAL and Firestone Air bags.
    Got it I believed you where going to delete the SAIS but want to do it after inspection.
    I know on the 4runner forum some guys have used or headers but they had to cut and weld one of the tubes over the other ones to fit. Also they had to dimple the header around the steering linkage.
    It would be great if I could fit a 04 - 05 4runner tri-y on my tundra
    http://www.dougthorleyheaders.com/t...stainless-steel-long-tube-tri-y-headers_15941
  2. Oct 22, 2021 at 1:10 PM
    #152
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    They make non SAIS tri y. But again, unknown fitment
  3. Oct 22, 2021 at 1:12 PM
    #153
    Dave8699
    Dave8699 Trackrat
    NJ
    Correct not sure how we can determine if 4 runner headers will fit our trucks with miner tweaks.
  4. Oct 22, 2021 at 1:13 PM
    #154
    empty_lord
    05 rollover special
    Sadly it will likely end up being some fool (me) buying and seeing… just hope to hell I can return if not
    Darkness and bmf4069 like this.
  5. Oct 22, 2021 at 1:15 PM
    #155
    Dave8699
    Dave8699 Trackrat
    NJ
    I was thinking in ordering also but didn't want $800 headers hanging out in my garage
  6. Oct 24, 2021 at 10:54 PM
    #156
    empty_lord
    05 rollover special
    @FrenchToasty if you have a chance can you post photos of the headers by the motor mounts, im curious about clearance
  7. Oct 27, 2021 at 12:41 PM
    #157
    Riverdale21
    Riverdale21 Speed seeker
    OTP ATL
    06 DC SR5 Tundra TRD Off Road
    They have arrived. Last ever built set of Stan's tri-y headers for the 2UZFE. Ceramic coated in titanium satin silver. Going to have a good old time installing these.
    Going to be about 2 weeks or so before the dyno and write up. Want to let them break in and allow the ECU to go through some self-learning.
    Tarsis, Lil Steve, bmf4069 and 5 others like this.
  8. Oct 27, 2021 at 1:23 PM
    #158
    empty_lord
    05 rollover special
    So much want
  9. Oct 27, 2021 at 1:53 PM
    #159
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
  10. Oct 27, 2021 at 2:24 PM
    #160
    Dave8699
    Dave8699 Trackrat
    NJ
    How much when does the bidding start?
    bmf4069 and Riverdale21 like this.
  11. Oct 27, 2021 at 8:21 PM
    #161
    Dave8699
    Dave8699 Trackrat
    NJ
    No need to worry about the headache you'll have removing the lower bolts on the manifold if you sell them. :thumbsup:
    Riverdale21[QUOTED] likes this.
  12. Oct 27, 2021 at 8:33 PM
    #162
    empty_lord
    05 rollover special
    wait.. you have an 06... those are for a non vvti motor.. how are you dealing with the SAI ports? drill and tap for plugs?
  13. Oct 27, 2021 at 8:36 PM
    #163
    So my manifolds are gone to the curb long ago. What spacing did you want to see at the motor mounts exactly?
  14. Oct 27, 2021 at 8:39 PM
    #164
    empty_lord
    05 rollover special
    i was going to lob off the SAI tubes and weld them on. but decided fuck it. i'll just get them from dirty deeds plugged. and install the hewit bypass i guess.
  15. Oct 28, 2021 at 9:16 AM
    #165
    Riverdale21
    OTP ATL
    Yes. I will have a write up thread on how to do it after I install these. I have ultra high temp (2,000*F+) medium strength thread locker and aluminum plugs. Aluminum so they will expand/contract at around the same rate as the heads to help prevent leaks and the plugs backing out.
    Edit** almost forgot I have the Hewitt SAIS bypass kit already. My pumps were making the vacuuming noise upon start up and had the SAIS check engine light about a year ago that resolved on it's own. I'll be documenting how to install the Hewitt pump block off plates when completely changing over to 00-04 headers.
    FrenchToasty and Casper421 like this.
