Tire pressure questions
Discussion in '1st Gen Tundras (2000-2006)' started by ThatYeti, Oct 26, 2021.
  1. Oct 26, 2021 at 1:37 PM
    ThatYeti
    ThatYeti [OP] New Member
    2000 Tundra SR5
    Asked in another thread but can't find much on this so figured it was worth a separate thread.
    Door tag on my 00 4.7 AC 4WD shows 26/35psi for front and rear tire pressures. Also just replaced my stock 16s with a set of factory 17s from an 05/06 model. Advice given was if unloaded to go higher in the front (35-40) and lower in the rear (25-30).
    While I can understand changing the pressures to account for a heavy load or towing, I'm not sure why they'd of not accounted for that on the door tag unless I'm missing something.
  2. Oct 26, 2021 at 1:45 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
  3. Oct 26, 2021 at 1:47 PM
    ThatYeti
    2000 Tundra SR5
    Tundra2[QUOTED] likes this.
  4. Oct 26, 2021 at 3:30 PM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    This will get you in the ballpark, very useful when moving away from stock tires or changing tire load ratings
  5. Oct 26, 2021 at 3:36 PM
    ThatYeti
    2000 Tundra SR5
    Thanks, won't let me start any smaller than a 17inch wheel though
  6. Oct 26, 2021 at 3:41 PM
    frichco228
    Frank
    Virginia
    Yes it will, it is a drop down box. What was the factory tire size the truck came with and what are you running now?
  7. Oct 26, 2021 at 3:49 PM
    ThatYeti
    2000 Tundra SR5
    Ah ok but now I'm not able to match the pressure. The rearsh show 35 on the tag and the calculator shows they should stay the same. But for the fronts the tag shows should be 26 and the drop down doesn't go that low (35 is the lowest).
  8. Oct 26, 2021 at 3:56 PM
    frichco228
    Frank
    Virginia
    What was the stock size and load rating and what size and load rating are you running now?
  9. Oct 26, 2021 at 4:07 PM
    ThatYeti
    2000 Tundra SR5
    Old tires : 245/70/16 "Extra Load" Continental Cross Contact
    New tires : P255/75/17 113S "M&S" Firestone Destination A/T
  10. Oct 26, 2021 at 4:29 PM
    frichco228
    Frank
    Virginia
    Your new tires have higher capacity (larger, stronger tire) but it states to run them at same pressure at lest- no lower than 26 lowest pressure. So, pressure listed on the door would be fine. I generally find that running a few LBs higher (just a few, a couple of pounds adjustment makes a big difference) offers better tire wear and drivability.
    And Tundra2 mentioned the chalk test, easy to do and helpful. Try a few lbs higher than the sticker and see how the truck drives and tires wear, and do a chalk test to see if you are getting a good contact patch with that pressure. Here is how
    https://www.youtube.com/watch?v=MIvbFgrH0IQ
    ThatYeti[OP] likes this.
  11. Oct 26, 2021 at 4:36 PM
    ThatYeti
    2000 Tundra SR5
    Appreciate all the advice and it's been raining here for like 27 hours so the chalk will have to wait for a dry day but I set them a few higher than the sticker just cause it seemed low to me so we'll see how it goes when I take it out again (only drive it like once a week maybe)
  12. Oct 26, 2021 at 4:48 PM
    ThatYeti
    2000 Tundra SR5
    To confirm though, when I'm towing or loading the bed heavy I should flip the 26-28 up front with the 35-38 on the rear?
