limit straps and bump stops for fox 3/1
Discussion in 'Suspension' started by wexttxco, Sep 29, 2021.
  1. Sep 29, 2021 at 5:48 PM
    wexttxco
    wexttxco [OP] New Member
    21 SR5 DC 4x4
    Fox 2.5 RR, 35x12.5r18 x3 on method 701, armor, front bumper
    Hi everyone,
    Do I need, or would it help, if I got limit straps and different bump stops for my truck? Suspension will be front 3", fox 2.5 DSC, rear 1.5" leaf pack with fox 2.5 DSC, on 35's. Truck used sometimes on trips and such but nearly half the miles will be offroad, whether gravel and dirt ranch roads, or crawling around in rough stuff in the desert.
    Thanks!
    2mchfun likes this.
  2. Sep 29, 2021 at 5:59 PM
    wexttxco
    21 SR5 DC 4x4
    Also, I'll be driving with spirit on ranch roads, but no plans for jumps or hitting whoops at 100 or anything like that. But do plan to make use of the shocks for fast stuff, and crawling.
  3. Sep 29, 2021 at 6:56 PM
    Vizsla
    Vizsla pretend2send
    If you jump it = tires leaving the ground then straps are a good idea. Hydro bumps are very nice, not much available for the front, but plenty options for rear. I tried various non-hydro bumps, didn’t notice any improvement, just had less $ in my pocket.
    snivilous, TRDFerguson and Hbjeff like this.
  4. Sep 29, 2021 at 7:28 PM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    So Durobumps aren’t as cool as they sound?
  5. Oct 1, 2021 at 5:46 AM
    wexttxco
    21 SR5 DC 4x4
    I won't be jumping it really. But in the jeep world I used to reside in, we still bought them.
  6. Oct 1, 2021 at 7:28 AM
    2mchfun
    Limit straps? I have bought the hardware, still need to fab some brackets. Limit straps will be going on to avoid blowing up shocks especially on my rear axle. Not because I jump the truck, but because sometimes one cannot see a dip before being right on top of it, especially at night. Then there could also be an instance of needing to avoid a drunk or similar and taking the ditch. In such case I would prefer to come out the other side mostly unscathed. Petty much just saying I like to prevent vs. repair what could have been prevented. Somewhere on this forum I posted a thread on this subject, type limit straps in the search box and you can likely locate it.
    wexttxco[OP] likes this.
  7. Oct 26, 2021 at 9:40 AM
    wexttxco
    21 SR5 DC 4x4
    Bump, any more thoughts?
  8. Oct 26, 2021 at 10:01 AM
    2mchfun
    Yeah, my thoughts reflect that I need to make the time and get my brackets fabbed up. Won't be long, winter will arrive and my fingers would rather stay inside her at that point. Time goes too fast!!!
    wexttxco[QUOTED][OP] likes this.
