High performance calipers
Discussion in '2.5 Gen Tundras (2014-2021)' started by JMcrewmax, Oct 25, 2021.
  1. Oct 25, 2021 at 11:44 AM
    JMcrewmax
    JMcrewmax [OP] New Member
    Tundra trd pro crew max
    Searching toyota parts, their showing the hp brake kit wont fit the ‘21 .. anyone know where to get the trd calipers for the ‘21 trd pro
  2. Oct 25, 2021 at 11:49 AM
    Kratos
    Kratos Woof
    2021 MGM Limited Nightshade
    I'm not aware that Toyota made more than one caliper for the Tundra?
  3. Oct 25, 2021 at 11:50 AM
    JMcrewmax
    Kratos[QUOTED] likes this.
  4. Oct 25, 2021 at 11:54 AM
    Kratos
    Kratos Woof
    Wow, pricey!
    SteyrM40A1 likes this.
  5. Oct 25, 2021 at 12:01 PM
    2mchfun
    Hello Allstate....
  6. Oct 25, 2021 at 12:06 PM
    JMcrewmax
    Haha incredibly!!! Im not a fan of the stock ones. They dont match the black/red.
  7. Oct 25, 2021 at 12:41 PM
    Downytide
    Downytide New Member
    GTA
    Lunar Rock that whines
  8. Oct 25, 2021 at 5:54 PM
    Dogsled
    Dogsled New Member
    White 2020 1794 4x4
    Currency converter= Earned to wasted dollars
    PowerBrakes on an 18” wheel
    Haven’t really gotten on them yet… letting them seat for a bit.. super smooth and solid feel right now driving around town.. but I got them because I didn’t like OEM softness and fade when towing my travel trailer… will find out in a couple weeks when I take the trailer out for a week.
    stuckinohio likes this.
  9. Oct 26, 2021 at 9:38 AM
    pman9003
    pman9003 New Member
    2020 Platinum 4x4
    How's the pedal feel with this setup? Does it use the factory front rotor?
  10. Oct 26, 2021 at 12:50 PM
    Downytide
    GTA
    Pedal feels good, I think next up is braided brake lines in the back, and yes, uses stock rotors.
  11. Oct 26, 2021 at 1:14 PM
    TundraTed
    TundraTed New Member
    2020 SR5 TRD Sport Crewmax 4x4
    In order: Orvis dog cover for rear bench seat, OE gun safe, Husky liners front/rear, Tyger tonneau tri fold, Rough Country seat covers
    is that a tire mount scratch at 10 o’clock on the wheel?
  12. Oct 26, 2021 at 2:17 PM
    Dogsled
    Dogsled New Member
    White 2020 1794 4x4
    Sorry about the tires Ted…. Honestly, there were so many buyers I probably should have asked more for them..:notsure: I Probably left money on the table…
    A little mounting grease..:rolleyes:
    Need Brand new -Act Contour Husky liners?.. about to post ‘em.. Just though I’d give you first shot:thumbsup:
  13. Oct 26, 2021 at 2:25 PM
    TundraTed
    No problem at all. Have you posted more photos of the EvoCorse wheels? I may change my plan altogether!
    I have the Husky Liners already but thanks for asking.
  14. Oct 26, 2021 at 2:33 PM
    Dogsled
    Dogsled New Member
    White 2020 1794 4x4
    https://evocorse.com/project/dakarzero-alloy-wheel/
    DakarZero 8,5x18
    • Size: 8.5Jx18”
    • Min ET 0, Max ET 45
    • Min PCD 98×4, Max PCD 165×6
    • Weight depending on the application: 13.5 to 14.9 kg
    • Standard color: white
    • Available colors: silver, gold, anthracite, matt black, bronze
    • Use: rally raid, off-road
    • Material: aluminum alloy A356-T6
    • Steel inserts: 60° taper included
    • Max load: 1250 kg per wheel
  15. Oct 27, 2021 at 8:39 AM
    pman9003
    pman9003 New Member
    2020 Platinum 4x4
    Thanks for the info. How much of an improvement over stock would say it was in terms of pedal feel? Since you are still considering stainless lines for the rear, my assumption is that it didn't stiffen things up as much as you would like?
  16. Oct 27, 2021 at 9:45 AM
    Downytide
    GTA
    It's firm enough that I'm satisfied with, it'll never match a track car, we got lots of brake lines between the cab and chassis, etc etc.
    As reference, its lot firmer than before, and WAYYYYY better than my Ram Rebel, fyi, my Rebel had 380mm rotors vs Tundra 354mm, definitely a worthwhile upgrade.
