Muffler Bearing Rattle "lets learn lets share"
Discussion in '2nd Gen Tundras (2007-2013)' started by NueveTundra, Oct 24, 2021.
  1. Oct 24, 2021 at 7:56 PM
    NueveTundra
    NueveTundra [OP] Mod list in Bio
    Planet Earth
    07, Black Tundra SR5 CrewMax
    Exterior: Toytec ultimate 3" lift level, Total Chaos Uniball UCA's, Total Chaos Cam Tab Gusset kit, AcanII smoked headlights, AcanII smoke Tail lights (2.5 gen style), DV8 front winch bumper , Badlands 12k winch with Apex Synthetic, White AUTMATCH Shackles 3/4" D Ring Shackle, Apex Winch shackle, Trail Ridge mirrors ,Icon Rebound Pro 17"x8.5" +25, Cooper Discovery STT Pro 285/70R17, PowerStop drilled n slotted rotors W/Carbon pads, Rigid flood flush mounts rear bumper , WeatherTec rain guards , OEM black side badges , Rigid Amber Radiance Pods. Energy Suspension Red Rack and Pinion Bushings, EAG front mesh Grille, RCI HighLift bed mounts. Rough Country DS2 Steps, A.R.E OverLand Canopy with Ascend basket, Stickers: ToyTec lifts windshield banner, Red Strange Music window sticker(back cab), White Strange Music sticker(back canopy), White Rigid sticker x2 (canopy sides), white Official BigFoot Research Team (Back Canopy) Interior: Alpine double din touch iLX-650 , JL C5-653's (front) JL C1-650x (rear) , JL JX400 4 channel amp , JL JX500 mono amp , 2 JL 12" subs , WeatherTec floor mats, Kenwood F/R Dash Cams, Black steering wheel emblem overlay, Tekonsha P3 Brake controller, ToyTec "Fresh" Scent coilover air freshener, Under the Hood: Koyo all aluminum radiator, Mishimoto red silicon hoses , XS Power 3000 amp battery , LAlectric 300 amp Alternator , K&N replacement filter. Online LED store accessories Fuse/relay box. (Identified) Dirty Deeds 8" Cat back exhaust with DD resonator delete/axel over converted into dump. Coming soon:
    Alright so I figured I would do a mini write up of an experience I had with an exhaust shield that lost two bolts. Hopefully this will be as entertaining as informational.
    One day I noticed an ever so weird rattle coming from somewhere. It almost sounded like a bad bearing from a pulley assembly. I spent time looking for it and chasing it to no avail becoming flustered at this point in time. As when I hit the gas the rattle would increase (since the exhaust would shake more causing the loose shield rattle louder) so I was thinking for sure the rattle had to be coming from the rotating assembly. As it was late, I grabbed my keys an slammed the drivers door to call it a night and grab a cold one. As the door slammed my ears perked up as I heard a faint rattle. I then went to look under my Tundra poking and shaking every body mounted shield figuring it had to becoming from one of them. All of them were tight, then I noticed the shield on the most forward drivers side cat was loose and had two broken bolts. So I fished around in my container of spare nuts and bolts finding two Identical nuts and bolts from some other vehicles exhaust system, installed and tightened them. Success, no more noise or rattle I was so relieved.
    Embarrassed over a few things that I missed, and felt I shouldn't have. I keep it as learning story an say "well I just needed to tighten the lash on the muffler bearing" :rofl:
    ...moral of the story is sometimes things seem definitive in a way. "Rattle got louder with RPM , a sign of rotating assembly" but was something completely 98% stationary. So from that day forward I add and suggest to others to add the door slam to eliminate rattles from non-rotating assembly parts. CDF256C9-30F6-400D-B0F3-BBF0BA4095CE.jpg 0EAC2592-84AD-48A6-8D82-3313D322FBC7.jpg
    feel free to share your interesting story or experience with a troubleshoot or diagnostic that seemed to defy logic or the process. Or just a really bizarre vehicle story. :);)
  2. Oct 24, 2021 at 8:11 PM
    JimboSlice413
    JimboSlice413 Super Nice Guy
    Bakersfield
    I have to empty rocks out of those every so often, they'll rattle pretty good. Took me forever to find it
  3. Oct 24, 2021 at 8:23 PM
    boostedtrdpro
    boostedtrdpro voided warranty
    Jeremy
    2024 GMC Sierra 2500HD AT4X 2020 Sequoia TRD Pro 040
    My brother in law had a bad rattle on his 95 Cherokee that 3 shops guaranteed he had a wasted bearing in the bottom end and needed a crate motor. It also got louder with RPM increase. I didn’t really look it over but offered to help him yank the motor and put in a new one. He brought it over and pulled it in my back yard onto a huge concrete pad I had back there and we got to work. Spent most all weekend taking stuff apart and getting the cherry picker in place. Sunday around 2 we were ready to unbolt it from the transmission (97% engine pulled) and I yanked the shield covering the flywheel to remove the bolts and much to my surprise I found 1 flywheel bolt was missing, and 1 was backed out about 3/4 of the way. That sucked, but all in all it was great news so we finished pulling the motor and put it in the shop on the stand and went through it. New oil pump, freeze plugs etc…
  4. Oct 25, 2021 at 1:01 PM
    tnbndr
    tnbndr New Member
    New Berlin, WI
    2012 White Rock Warrior CrewMax
    I remove those cat and muffler covers as I have had the rattle often on other trucks.
  5. Nov 5, 2021 at 4:12 PM
    Notarobot
    Notarobot Jagged lines!
    2013 CM
    My muffler bearings suddenly went out as well. It was intermittent and inconsistent, so I knew it wasn't internal. I crawled underneath and listened. Something was definitely loose. I started hitting stuff until I got it to rattle. Diver's side cat off the manifold. I still haven't fixed it. I haven't decided to remove completely or put new bolts in.
  6. Nov 6, 2021 at 6:20 AM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    Another suggestion that works very well, especially if the cat covers are really rusted or the areas where the bolts attach are degraded- use a couple big stainless hose clamps to secure the heat shield- put it around the shield and cat and tighten it well until no more rattles. This has worked for me on multiple vehicles and was a trick a learned from an exhaust mechanic/builder.
    NueveTundra[OP] and Notarobot like this.
  7. Nov 6, 2021 at 12:33 PM
    shannon
    shannon New Member
    shannon
    Asheville, NC
    2010 DC
    Class act right there a real 2 percenter!!
