325 vs 35”
Discussion in 'Wheels & Tires' started by Evo13, Jan 11, 2021.
  1. Jan 11, 2021 at 12:16 PM
    Evo13
    Evo13 [OP] New Member
    2015 Toyota tundra black crewmax 4x4
    Greetings all! Looking for opinions on tire size . 325/65r18 vs 35”x12.5/18 bfg km3 on a 6” Rough Country vertex equipped lift . I know the 325 is wider , but looking for any opinions that may have experience with this setup. TIA
  2. Jan 11, 2021 at 12:29 PM
    DeesCrewMax
    DeesCrewMax New Member
    Deric
    2018 Cement Crewmax SR5
    Accutuned Fox 2.5 DSC/2.0 rr, SnugTop Rebel, Alpine Amp, OEM LED headlights, LED fogs, Remote Start, RB20 steps, RCI Skids, 10" BA Muffler, 17" Icon Alloy Six Speeds, 15" Tint, Pro-clip mount
    With such similar dimensions and ratings, your specific tire choice might end up making more of a difference than the delta between these two sizes..for example with a BFG AT KO2 these are the values that varied between the two sizes (ignore max PSI):
    I have no first hand experience, so i'm useless to you, but i would go with which one likes my wheels better based on width and backspacing for clearance.
  3. Jan 11, 2021 at 5:15 PM
    Evo13
    Thanx for the info Deric!
  4. Oct 24, 2021 at 10:58 AM
    DgoTss
    DgoTss New Member
    Wesley
    Durango Colorado
    2015 dbl TSS
    Hey did you end up going with the 325's? I just got some TRX take off's and looking for any insight into fit and what the wheel offset you used might have been?
