Tire rotation...X pattern?
Discussion in 'Wheels & Tires' started by Tundra234, Aug 14, 2021.
  1. Aug 14, 2021 at 5:41 AM
    Tundra234 [OP] New Member
    Are you 2wd guys using the first pattern for your tire rotation? I was trying to explain to my neighbor that it should be done that way normally.
  2. Aug 14, 2021 at 6:16 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    use whatever pattern gets all four tires into different positions over 4 rotations.
    don't over think.
    the 3rd one is goofy. although if you watch discount tire, they use it often. lazy.
    TheBeast and GODZILLA like this.
  3. Aug 14, 2021 at 8:10 AM
    Kfrog
    Kfrog New Member
    2016 Tundra SR-5
    Our local Discount Tire will mark tires prior to removal, LR,LF and so on prior to balancing so they the rotation correct. They also balance every time they rotate all at no charge if you purchase with them or new vehicle.
    YardBird likes this.
  4. Aug 14, 2021 at 8:13 AM
    18" TRD Off Road Wheels
    Watch your dealerships too. That's what Toyota did on mine. I was pissed thinking they didn't do the rotation at all when I checked my TPMS the next day. Turns out they "rotated" them front to rear, and they said that was the Toyota policy. I told them it's a half assed rotation.
  5. Aug 14, 2021 at 8:43 AM
    Giskk
    Giskk New Member
    Mississippi
    2021 Cement Tundra TSS Off-road
    Hmmm… Front to back to front etc is what is in my manual. Now I wonder if I’m doing it wrong.
  6. Aug 14, 2021 at 9:09 AM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    Unless you have uneven wear on one side due to an improper alignment, crossing them to the other side isn’t needed. In which case, get a proper alignment and your tires will wear evenly across the tread
    NewImprovedRon and sportrider like this.
  7. Aug 14, 2021 at 9:13 AM
    sportrider
    sportrider New Member
    Stephen
    2017 White Crewmax Limited
    Why is the third one goofy or lazy? If directional tires are involved, its the only choice without remounting and balancing. I recently rotated mine that way per the owners manual for the Tundra, but also vehicles in the past per theirs as well. I think the main idea is splitting time between front to rear, more than running a tire in the opposite direction for long life. Not a tire expert by any means, but havent had any tires give me issues this way. Also rebalancing occasionally is very important as well. Just my two cents.
    Ely010606 likes this.
  8. Aug 14, 2021 at 9:22 AM
    sportrider
    Stephen
    You're doing fine. As Danman34 stated, as long as the alignment is good and no abnormal wear is noted, just follow the recommended rotation. Sure, if your alignment is out of whack and your tire is getting chewed up, it could be moved to the other side, just to chew the other tire up. Occasional rebalancing and frequent tire pressure checks are more important. How many people truly check tire pressures anymore with tpms?
  9. Aug 14, 2021 at 9:24 AM
    tttrdpro
    tttrdpro Former Naval Person
    SWGA
    2024 GMC 2500 AT4
    In progress…
    The manual says front to back.
  10. Aug 14, 2021 at 9:30 AM
    Bigkitchens
    Bigkitchens New Member
    Alabama
    2014 1794 crewmax 4x4
    Front and back trd sway bars, 14 inch magnaflow dual in dual out exhaust, undercover bedcover, rough country 2 inch leveling coilovers and rear shocks, 285/60/20 nitto ridge grapplers, wireless charger, driver grab handle, tech12volt 10 inch sub and enclosure upgrade , and stillen cold air intake .
    When I went to automotive shool in the 80's, they taught front to back. The theory was if you reverse the steel belts from their normal rotation they would start fraying. I'm sure modern tires have advanced past this.
    NewImprovedRon and YardBird like this.
  11. Aug 14, 2021 at 9:52 AM
    Nowhereman
    Nowhereman New Member
    Al
    Monterey Bay area
    2021 Tundra SR5 / TRD / Cement
    Rough Country shocks, ReTrax cover, Summo springs, black out badging, bed extender, "some other things I can't mention"
    No. 2 doesn't equate well to pattern / direction specific tread designs.
  12. Aug 14, 2021 at 10:00 AM
    Directional treads use number 3. Number 2 is for FWD.
  13. Aug 14, 2021 at 10:02 AM
    Manual says front to rear...same side.
  14. Aug 14, 2021 at 10:04 AM
    Yep front to rear.
  15. Aug 14, 2021 at 10:09 AM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    Not gonna curb all my wheels
  16. Aug 14, 2021 at 10:15 AM
    Right, but does that apply after you've gone with aftermarket wheels and tires? Is Toyota's info based off a completely stock truck or does it account for the multitude of changes we are all making to them?
  17. Aug 14, 2021 at 10:21 AM
    Danman34
    Danman34 New Member
    Danny
    It only takes into account a proper alignment. Doesn’t matter if you have stock or aftermarket. If your alignment sucks, no amount of rotating will make them last as long or wear evenly as they should with a proper alignment.
  18. Aug 14, 2021 at 10:30 AM
    I understand that proper alignment is important. Never doubted it and never thought that a crossing rotation would compensate for it. If you're alignment is effed, then your tires are gonna suffer. That's a dead horse at this point.
    What I'm more concerned with is the fact that wider wheels/tires and different offsets directly affect how a tire is worn as the front suspension cycles. Things like scrub radius.
    Maybe I'm just overthinking it. Even if I am, is there any negative effect of the crossover rotation? I don't think there is. Are there any benefits to the cross rotation? I can think of one pretty easily. We all know your alignment matters. Well, what if the alignment is in spec, but not perfect? You'd have very slow irregular wear that you might not be able to visually detect, and rotating the tires through all positions could help keep your tire wear more even in this situation.
    Just thinking out loud here, and I'm super sleep deprived, so I might be totally full of shit. I can't tell right now.
  19. Aug 14, 2021 at 10:33 AM
    ATV25
    ATV25 Young at heart
    Terry
    Redding, CA
    2019 Platinum
    5100s, Icon Rebounds, Maxxis Razors
    I always go front to back
    FUNNY QUOTE !
    GODZILLA[QUOTED] likes this.
  20. Aug 14, 2021 at 10:39 AM
    Just being honest. If I get some rest I might come back and reread what I posted and slap myself for being an asshat. Never know.
    Tundratoofun likes this.
  21. Aug 14, 2021 at 10:43 AM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    I had some block separation with the tires, once I swap them X pattern. A long time ago, after that I only go front to back
  22. Aug 14, 2021 at 10:45 AM
    Danman34
    Danman34 New Member
    Danny
    You’re over thinking it. Lol. The way the suspension cycles is due to the suspension/alignment. A wider tire isn’t going to change how the suspension articulates. I’ve driven over 140k miles on lifted trucks with bigger tires. Alignment and suspension components that aren’t past due is everything.
    Winning8 likes this.
  23. Aug 14, 2021 at 11:01 AM
    Look into scrub radius. Look at the pic below and they show some basic idea of it. Now, imaging if you put a different offset wheel on in the pic below. You're going to move the center line of the tire in or out, and you are going to have a positive or negative scrub radius. This IS going to affect how your vehicle handles things on the road. This is illustrated on the left side image.
    Saltyhero13 likes this.
  24. Aug 14, 2021 at 11:21 AM
    Danman34
    Danman34 New Member
    Danny
    I’m aware of that. Unless you are changing the spindle that results in a different hub face location, your turning radius isn’t gonna change. The illustration is also highly dramatic. A lower offset wheel isn’t going to instantly turn the vehicle into a dangerous vehicle to drive. Probably 80-90% of trucks on the road are running lower offset wheels and bigger tires. As long as you have a proper alignment ( camber, caster, toe), the tire will not wear and the truck won’t be darting on the road with excessive bump steer.
  25. Aug 14, 2021 at 11:37 AM
    Not turning radius. :facepalm: SCRUB radius. At the size and weight of the tundra, it won't be super pronounced, but it can impact wear on the tires. Not to a huge degree, but as stated, the point of the cross rotation would be to handle small wear irregularities.
    https://youtu.be/62X5saLLOds
  26. Oct 23, 2021 at 8:50 PM
    NueveTundra
    NueveTundra Mod list in Bio
    Planet Earth
    07, Black Tundra SR5 CrewMax
    Exterior: Toytec ultimate 3" lift level, Total Chaos Uniball UCA's, Total Chaos Cam Tab Gusset kit, AcanII smoked headlights, AcanII smoke Tail lights (2.5 gen style), DV8 front winch bumper , Badlands 12k winch with Apex Synthetic, White AUTMATCH Shackles 3/4" D Ring Shackle, Apex Winch shackle, Trail Ridge mirrors ,Icon Rebound Pro 17"x8.5" +25, Cooper Discovery STT Pro 285/70R17, PowerStop drilled n slotted rotors W/Carbon pads, Rigid flood flush mounts rear bumper , WeatherTec rain guards , OEM black side badges , Rigid Amber Radiance Pods. Energy Suspension Red Rack and Pinion Bushings, EAG front mesh Grille, RCI HighLift bed mounts. Rough Country DS2 Steps, A.R.E OverLand Canopy with Ascend basket, Stickers: ToyTec lifts windshield banner, Red Strange Music window sticker(back cab), White Strange Music sticker(back canopy), White Rigid sticker x2 (canopy sides), white Official BigFoot Research Team (Back Canopy) Interior: Alpine double din touch iLX-650 , JL C5-653's (front) JL C1-650x (rear) , JL JX400 4 channel amp , JL JX500 mono amp , 2 JL 12" subs , WeatherTec floor mats, Kenwood F/R Dash Cams, Black steering wheel emblem overlay, Tekonsha P3 Brake controller, ToyTec "Fresh" Scent coilover air freshener, Under the Hood: Koyo all aluminum radiator, Mishimoto red silicon hoses , XS Power 3000 amp battery , LAlectric 300 amp Alternator , K&N replacement filter. Online LED store accessories Fuse/relay box. (Identified) Dirty Deeds 8" Cat back exhaust with DD resonator delete/axel over converted into dump. Coming soon:
    I personally would just look at the tread wear pattern and let the tires tell you how they want to be rotated.
