Front end steering problem
Discussion in '1st Gen Tundras (2000-2006)' started by 1kTyy_1, Oct 23, 2021.
  1. Oct 23, 2021 at 8:13 AM
    1kTyy_1
    1kTyy_1 [OP] New Member
    2001 Toyota Tundra SR5 V8 4.7L 2WD
    In june I got into a small Collison with a tow dolly/car hauler. My truck was the only one damaged on the front passenger side. Lights still work and tire/brakes was not damaged. But the very next day I had a BAD need for a alignment. Went and got that done but I needed another alignment literally less than 2 months later.
    What parts do you think are damaged and could have caused this?
    Any one else having similar problems?
    Any suggestions welcome and there is not a price on parts since I'm currently replacing most of the mandatory parts. (Radiator/Full front and rear brakes/Headlights) etc.
    Looked under neath and nothing looks broken but will take another look if needed.
  2. Oct 23, 2021 at 8:17 AM
    We like pics to help form opinions here. Your alignment numbers might help as well.
    bmf4069 and 1kTyy_1[OP] like this.
  3. Oct 23, 2021 at 8:59 AM
    jerryallday
    jerryallday New Member
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    Check the poly bushings on the steering rack for wear and tear. Also the lower control arm bushings. Do you know what is going out of Alignment? Cam, toe, caster?
  4. Oct 23, 2021 at 9:10 AM
    1kTyy_1
    Ok will show pictures when I get back home.
  5. Oct 23, 2021 at 9:10 AM
    1kTyy_1
    Will look again when I get back home to make sure. My apologies
    jerryallday[QUOTED] likes this.
