Small stumble on heavy acceleration
Discussion in '1st Gen Tundras (2000-2006)' started by Motopilot, Oct 21, 2021.
  1. Oct 21, 2021 at 9:48 AM
    Motopilot
    Motopilot [OP] New Member
    Josh
    NC/FL
    2017 Tundra crewmax 4x4 Platinum edition
    2” level 285/75R17 Falken wild peak RT 34.1”x11.5” bilstein 5100
    2005 DC 4x4 4.7 has a small surge when accelerating onto a highway or similar…any ideas? Fuel injectors maybe?
  2. Oct 21, 2021 at 10:21 AM
    Sirfive
    Sirfive Socially feral
    ‘02 Limited AC TRD
    Bassani cat-back
    Surge is an odd choice of words. Kinda implies a small boost of power, like maybe when it shifts? A stumble is more common, unless its a rhythmic surge?
  3. Oct 21, 2021 at 10:28 AM
    Motopilot
    Josh
    NC/FL
    Good point…not a surge. definitely more of a stumble.
  4. Oct 21, 2021 at 10:31 AM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    Check fuel pressure, could need a filter, could be a pump, but also could be injectors.
    could be a number of sensors.
  5. Oct 21, 2021 at 10:43 AM
    Protip: @Motopilot if you want to correct your thread title, scroll up to post #1 and click 'Thread tools', then choose 'edit title' to replace 'surge' with 'stumble'. Might change who clicks on the thread to read. This is also helpful for folks who sell in the Marketplace, to clearly mark your item as SOLD in the title. Thread tools option only shows if you're the original creator of the thread.
    bmf4069 and w666 like this.
  6. Oct 22, 2021 at 10:38 AM
    Bump for OP now it has a new thread title.
  7. Oct 22, 2021 at 11:55 AM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    Also plugs. Lookit everything, look at the leaks, rust, corrosion, age.
    its way too vague to pinpoint.
    Vids or pics + on the ground, eye on target feedback. Otherwise take it to a shop, cause old trucks are a hands-on hobby.
