Normal Behavior or Possible Fan Clutch Issue
Discussion in '1st Gen Tundras (2000-2006)' started by SteveT, Oct 18, 2021.
  1. Oct 18, 2021 at 7:01 PM
    SteveT
    SteveT [OP] New Member
    LugNutz
    2002 Tundra SR5 Access Cab
    None yet. Just good ole maintenance
    Hey all - first timer and first post - thanks for listening!
    So, I have a 2002 SR5 AC in generally very good condition with 192K on it. Just bought it pre-owned from original owner and it was garaged and never been towed with, no rust at all! (even in eastern PA!) I've been doing many PM and general health items to it (oil, trans 4 qt. drain, fuel filter, serpentine belt, struts and shocks, complete front brakes) Currently has 94K on 2nd timing belt that appears in good condition.
    Now for the issue; I thought this was normal at first and and was just an old truck thing. I noticed when accelerating from a standstill through shifts into 2nd and 3rd that the engine roars/howls too loudly, but the shifts are nice and clean. After observing for a week I came to realize this only starts to happen after the engine comes up to temperature and has nothing to do with the drivetrain. I can reproduce the issue when idling in park and rev the engine ever so slightly. After initial cold start and brief fan roar, the engine can rev and it sounds normal, then after temp comes up to normal (half gauge) the roar/howl is there at acceleration. When I manually spin the fan after warm shutdown, it only travels about 5 inches. When spinning it at dead cold in the morning it will spin maybe 3 blade positions (1-1.5 ft)
    Does any of this sound normal or is it possibly a fan clutch issue? How free spinning should the fan be when warm or cold, and should the fan ever stop during normal operating conditions? To the best of my knowledge, my fan never stops. I should also point out that it doesn't do it this way when idling at normal RPMs or does it occur randomly, only at throttle revs or normal acceleration. No other squeals or whines, just the loud engine roar.
    I hope that's not too much rambling and certainly appreciate any feedback. I have no problem spending the coin on a new fan clutch but just hate replacing things unnecessarily. Maybe something else and not fan clutch?
    Thanks alot,
    1kTyy_1 likes this.
  2. Oct 18, 2021 at 7:12 PM
    Desert Dog
    2001 SR5 AC 2WD 4.7l
    Welcome. If the fan only turns 3-5" by hand when spinning it, it is definitely on its way out and I would replace it at this point. It should spin freely about a full rotation by hand.
  3. Oct 19, 2021 at 3:58 AM
    It's not too hard to replace either. I pulled the radiator out when I did mine to give myself A LOT more room.
  4. Oct 19, 2021 at 12:47 PM
    SteveT
    LugNutz
    Thanks very much for the input. New Aisin clutch ordered from Rockauto. Other than the slow free spin, do my other symptoms point to the fan clutch as well?
  5. Oct 19, 2021 at 3:24 PM
    Desert Dog
    Good call. And yes, the other symptoms do point to it being the culprit. Thankfully it's a very simple system and easy to diagnose since there really isnt much to it to misdiagnose. You will notice a significant difference in the function of your fan and its engagement once the new thermostatic clutch is installed.
  6. Oct 21, 2021 at 5:14 PM
    SteveT
    LugNutz
    Thank you boys!! New fan clutch did the trick. The truck drives like a completely different vehicle, so smooth through acceleration. The mount nuts are a bit tedious to deal with, but a couple shaved knuckles later, the clutch went in fine.
    Very psyched this was the fix.
    Thanks again,
    Acatlin96, Voss, bmf4069 and 5 others like this.
  7. Oct 21, 2021 at 5:24 PM
    Desert Dog
    Glad to help and glad to hear.
    Tundra2 likes this.
  8. Oct 21, 2021 at 7:44 PM
    1kTyy_1
    1kTyy_1 New Member
    2001 Toyota Tundra SR5 V8 4.7L 2WD
    Did you watch a tutorial on how to change? If so which did you watch. How long did it take you to complete. Just general questions, don't have to answer if u don't want too
  9. Oct 21, 2021 at 8:02 PM
    Toyoda Tundra
    Toyoda Tundra Boxing and Tundras
    2WD 2004 AC Tundra. V8 strong
    The beginning of this video shows how to remove the fan clutch with a tool. https://youtu.be/RWVFOdha9eA
  10. Oct 22, 2021 at 2:54 PM
    SteveT
    LugNutz
    I didn't see that one but I'll give it a look. I watched this one on youtube:
    https://www.youtube.com/watch?v=yAy...el=1AAuto:RepairTips&SecretsOnlyMechanicsKnow
    Very straight forward. Tips I can offer: clean up the mount threads and buy new mounting nuts to allow fingertip threading easier. And, don't drain the entire radiator, just until it clears the upper hose volume. I didn't pull shroud out, just unfastened, pushed it towards engine, and pulled fan out between shroud and body.
    That'll do it.
  11. Oct 22, 2021 at 3:15 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    I didn't even do that much. I removed the skid plate, unclipped the lower shroud piece and dropped the fan & clutch down to get it out.
  12. Oct 22, 2021 at 8:17 PM
    SteveT
    LugNutz
    Good point, I didn't even notice the shroud split in two like that until I was putting everything back together.
  13. Oct 23, 2021 at 3:46 AM
    tvpierce
    tvpierce Formerly New Member
    Maine
    This would be the perfect time to replace that 15 year old radiator to avoid a pink milkshake. If you're draining the coolant and removing the shroud, the job is already half done.
    Desert Dog and bmf4069 like this.
  14. Jun 11, 2023 at 7:06 AM
    chaas
    chaas New Member
    Chad
    I had the same issue so I changed the fan clutch but it didn't fix the problem, the fan is still engaged all the time. Is it possible they sold me a bad part or maybe it's something else? Thanks!
  15. Jun 11, 2023 at 12:54 PM
    My fan is actually engaged all the time also. I got confused when someone on here said theirs wasn't. I think I got corrected on it, actually, but chose to keep my mouth shut because I wasn't 100% sure.
  16. Jun 11, 2023 at 1:11 PM
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    What did you buy and where? It's possible to get fake parts from e'bay/am-azon/etc.
    If it's fully engaged and 'roaring' all the time, then it's probably bad.
  17. Jun 11, 2023 at 3:01 PM
    Aerindel
    Aerindel New Member
    Montana
    What do you mean engaged? You can't turn it without turning the engine while cold?
  18. Jun 11, 2023 at 4:38 PM
    Is engine running?
    • YES => Fan is spinning
    • NO => Fan is not spinning
  19. Jun 11, 2023 at 5:24 PM
    Aerindel
    Aerindel New Member
    Montana
    This is normal. The fan is never completely disengaged. The difference is that when cold and not running, you can turn the fan, with mild resistance by hand. When hot, the fan is 'locked' to the driveshaft and turns at the same speed.
    FirstGenVol and shifty`[QUOTED] like this.
  20. Jun 12, 2023 at 5:50 AM
    This was my understanding also. Thanks for confirming. :thumbsup:
  21. Jun 19, 2023 at 5:56 PM
    chaas
    chaas New Member
    Chad
    Thanks for all the responses, good to hear it's normal. Was just concerned because of how loud it is when accelerating.
  22. Jun 20, 2023 at 8:38 PM
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    If loud all the time, then it may be bad.
    If only for the first few minutes after startup and when engine is actually 'hot' (loaded/towing up grades or after stopping at a light in 90+ degree weather), then it's probably fine.
    Aerindel likes this.
  23. Aug 2, 2024 at 2:13 PM
    Weejub
    Weejub New Member
    Jamie
    Pittsboro, NC US
    2001 AC TRD
    Bilstein 6112 - Set @ 5/4; General Spring: 2000 - 2006 Toyota Tundra heavy duty rear leaf spring, 5(4/1) leaves
    And, if it is all gunked up, could also explain the overheating. I'm holding out for 40K more miles and do it all with a new timing belt, water pump etc. Given my annual mileage, I doubt I get there, though, before doing it early.
  24. Aug 2, 2024 at 4:54 PM
    Bmktw2
    Bmktw2 Yard Dog
    Nic
    AC 2001 5spd 4x4 V6
    I recently had to replace my fan clutch with an OEM one from Toyota. My original fan clutch was roaring all over the place. When I put the new clutch on, it's loud on startup for about 30 seconds and then goes quiet. No more roar sound after that
  25. Aug 2, 2024 at 5:27 PM
    That's essentially what mine does too. But I've also noticed if I have the A/C on and it's hot as balls outside, when I accelerate from stop lights it's loud as shit too.
