Long term storage
Discussion in 'General Tundra Discussion' started by Lowcoco, Oct 21, 2021.
  1. Oct 21, 2021 at 4:52 PM
    Lowcoco
    Lowcoco [OP] New Member
    Jose
    2017 Tundra SR5 Crewmax 4X4
    Bilstein 6112/5160
    Hello, I'm in the military and I will be leaving the country for 4 years. I'm currently thinking of leaving my tundra at my parents house, garage not an option so I will be leaving outside. What are some thing you guys would recommend I do. Should I have them drive it from time to time or should I put it on Jack stands? Is it a good idea to let it sit for that long? If I do let it sit for all 4 years, should I drain all fluids?
  2. Oct 21, 2021 at 5:08 PM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
  3. Oct 21, 2021 at 5:29 PM
    NCSkeeter
    NCSkeeter New Member
    2019 Silver Tundra Crewmax 4x4 1794
    TRD Rear Sway Bar, Truxedo X15 Tonneau Cover, Toyota OEM Bed Mat
    I love my Tundra, but I would sell it rather than have a depreciating asset sitting unused for four years. Resale values are insanely high right now. The value of that truck will be much lower in four years.
    Thank you for your service! :oldglory:
    TheBeast, Trooper2, BTBAKER and 3 others like this.
  4. Oct 21, 2021 at 5:29 PM
    Make sure you get some rodent deterrents if you are letting it sit outside that long.
    Stay safe. Thank you for your service. :oldglory:
    Lowcoco[OP] and 2mchfun like this.
  5. Oct 21, 2021 at 5:33 PM
    alwzdfiant
    alwzdfiant New Member
    2013 Tundra Crew Max
  6. Oct 21, 2021 at 5:35 PM
    Jchetty
    Jchetty New Member
    NJ, Middlesex County
    4 years is a long time- really long time. With today’s hot market, I would highly consider selling. There always be Tundras for sale.
    If not, you def need a car cover. What is scary is if animals make a nest. You will have to keep it registered and insured. Maybe transfer the car to your parents and let them drive and use it. Ask them to take it out weekly.
    If you want store it, do not put it up on jackstands. You want the suspension under load. This can cause the tires to flat spot. Race Ramps sell these little curved ramps that help prevent it. You will wanna change the fluids but not drain. You will want to add fuel stabilizer.
    If the truck hasn’t been started in a while, pull the fuel pump fuse/relay and bump the starter a few times. This helps build oil pressure. You will want to pull the battery completely or disconnect the negative cable to prevent it from draining. A trickle charger would be ideal but dunno if that is possible
    Trooper2 and Lowcoco[OP] like this.
  7. Oct 21, 2021 at 5:49 PM
    toyofan87
    toyofan87 Beer thirty
    Seth
    Gettysburg, Penna
    You having a 2017, close to being paid off?? Such a killer truck to sit four years... Been there before during a deployment, but I had a restored a 71 Karma Ghia and decided to put in long term inside/storage bldg... Climate controlled, full tank, battery tender, pest controlled, and with a breathable cover....
    If you can afford a bldg storage site, go for it, a good investment for a killer truck and peace of mind... Good luck and thanks for your mission calling. Be safe and safe return home..
    Toyotoholic and Lowcoco[OP] like this.
  8. Oct 21, 2021 at 6:24 PM
    georgiey22
    georgiey22 SW Idaho
    2019 Tundra | TRD Sport | Cavalry Blue | Crew Max
    My family and I Thank you for your service Jose.
  9. Oct 21, 2021 at 7:15 PM
    2mchfun
    Indoor rv storage and open containers of moth balls inside the cab, under the hood, and on the floor around the perimeter. Have someone refresh them every 6 months. Remove battery, sell tires. Flush fluids upon return prior to driving. Ask insurance and registration dmv for non usage policy/tags.
    Be safe soldier!! Good luck!!!
    Lowcoco[OP] likes this.
  10. Oct 21, 2021 at 7:39 PM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    2022 Ram TRX Level 2
    Thank you for your service and be safe.
    I’d vote to sell it and invest the money. You should see a decent return on your money in 4 years and you can upgrade.
    Sumo91, Dogsled and Trooper2 like this.
  11. Oct 21, 2021 at 8:36 PM
    Dogsled
    Dogsled New Member
    White 2020 1794 4x4
    Currency converter= Earned to wasted dollars
    I second this advice…. Cars are a huge depreciating expense… besides in 4 yrs gas could be up to $10/gal…:eek2:… Then what?..Definitely don’t want an 8 yr old gas guzzler that may need work just to get up and running… Godspeed Brother and be safe.
  12. Oct 21, 2021 at 9:20 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Sell it. Throw the money into Crypto. Buy a brand new 2025 Tundra when you get back.
  13. Oct 21, 2021 at 9:35 PM
    Saltyhero13
    Saltyhero13 Throbbing Member
  14. Oct 21, 2021 at 9:39 PM
    18" TRD Off Road Wheels
    Not true, at least in my state, so it may vary by state. If you notify the DMV that the vehicle won't be used they can basically flag it as inactive so you don't accrue the registration fees. Insurance is a good idea in case of something like a fire/accident, but the registration is worth looking into, especially if you live in a state that rakes you over the coals on cost.
  15. Oct 21, 2021 at 9:46 PM
    Saltyhero13
    To piggy back on this comment call your insurance to let them know of your situation. If you store it, most can keep you covered at a reduced rate since you won't be driving it.
    GODZILLA[QUOTED] likes this.
  16. Oct 21, 2021 at 9:51 PM
    TheBeast
    TheBeast The Beach
    best plan ever..lol
    OP might be able to get close to one bitcoin with today's used market on Toyotas
    OP comes back from deployment in 4 years and now 1 bitcoin worth $200K.
    OP jumps in the air and goes on tundras.com to thank @joonbug who is now driving a 2024 Long travel Tundra.
    joonbug[QUOTED] and Saltyhero13 like this.
  17. Oct 22, 2021 at 4:17 AM
    Jchetty
    Jchetty New Member
    If he doesn’t plan to have anyone drive it then yeah- you are correct. I would assume that he would want someone to periodically put her on the road.
    Personally- any vehicle I have is insured. That way if something happens- I don’t lose the vehicle with no recourse. Not every home insurance policy will cover vehicle damage under every situation.
    Also with catalytic converter theft and leaving it outside - perfect target for a car thief.
  18. Oct 22, 2021 at 4:21 AM
    All good points.
    OP, I'd see if your folks are willing to run it on some kind of 30 minute errand once a week, or every other week to keep the kinks worked out. That, or do some hefty research into long term vehicle storage and weight that out against selling. Personally, I love the Tundra and I want it to be my old truck when I'm rattling around in my 70s (should I live that long) so I am biased against the selling option.
    Lowcoco[OP] and toyofan87 like this.
