Leveling?
Discussion in 'Suspension' started by fire66dave, Oct 20, 2021.
  1. Oct 20, 2021 at 6:47 PM
    fire66dave
    fire66dave [OP] New Member
    Dave
    2010 Maroon Tundra TRD DoubleCab
    Brand new to the Tundra fam, just bought a 2010 TRD DoubleCab in pristine condition with only 76k on it. It has some nice aftermarket XD rims and I couldn't be happier. A couple of people mentioned putting a leveler on the truck...
    I don't mind doing some fun stuff to the truck over time, but what is the general opinion here?
    ColoradoTJ likes this.
  2. Oct 20, 2021 at 8:25 PM
    Welcome from NY.
    You can get Bilstein 5100 shocks for the front to level it.
    alb1k likes this.
  3. Oct 20, 2021 at 8:28 PM
    fire66dave
    Dave
    Thanks!
    But is a good for the truck, or is it just a cosmetic thing?
  4. Oct 20, 2021 at 8:31 PM
    It's good.
    Do a search of posts about them. Plenty of people have done it.
    T-Rex266 and alb1k like this.
  5. Oct 20, 2021 at 8:32 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    It's good for some stuff, like bigger tires. Looks for sure. Its a modification from original, so good is fairly subjective.
  6. Oct 21, 2021 at 4:02 AM
    toyofan87
    toyofan87 Beer thirty
    Seth
    Gettysburg, Penna
    Lots of options here, research in the suspension section of the forum and see what others posted... Different makes, brands, heights, etc..pros and cons about what they installed... It's all there to read... I'm a big fan of Toytec, solid and true... There's better, yeah Kings-Fox..but mine rides better than stock and suits me fine. Good luck. Any pics?
  7. Oct 21, 2021 at 8:07 AM
    COTundie
    COTundie Whoa Black Betty
    Trey
    Black 5.7 DC TRD 4x4
    Pretty things
    Yep.
    It's good for increasing the center of gravity, which arguable has negative handling repercussions. It's good for decreasing fuel efficiency. It is also good for increasing your front driveshaft CV angles.
    They are also good for badassery like more ground clearance, ability to fit larger tires, and just the aesthetics of leveling out the stance of the truck.
    I just installed Eibach 2.0 adjustable coilovers 2 weeks ago, and after getting the alignment dialed back to factory settings, I am loving them. I set them for right about 2" of lift and think it's perfect. I have not lifted the back, but just installed their shocks.
    Honestly the truck handles better, feels tighter and handles large bumps with much more finesse. I did replace the factory Bilsteins with 150k on them, so an improvement is not so unexpected.
    One (handling.?) drawback I have noticed is an increase in "bed bounce" on certain sections of concrete highway. Actually never understood what people were complaining about until I was on fresher, stiffer shocks.
    There are many ways to achieve a "level", or about 2ish inches up front. The least expensive are spacers, and the most expensive would be a custom, long travel setup. I went kind of middle of the road with a US company that manufactures here in the states.
    The visual change is pretty minimal. Just takes care of the excessive amount of rake they came with. Personally think its how they should have come from toyota.
    alb1k[QUOTED] likes this.
  8. Oct 26, 2021 at 5:58 AM
    dougn
    dougn New Member
    Doug
    17 Limited Silver/Grey
    will just raising the front end by 2 inches effect the gas mileage?
  9. Oct 26, 2021 at 6:02 AM
    Jbehredt
    Jbehredt Burgeoning member
    Westminster, CO
    2020 TRD Pro DC White
    Oh absolutely effects aerodynamics and drag. It’s not for any other reason that new fords and chevys sit about 6” of the ground below the front bumper. Gotta get those window sticker numbers up.
  10. Oct 26, 2021 at 6:06 AM
    COTundie
    Trey
    Pretty things
    Yes. But it wont be a big difference... Not until you start putting bigger heavier tires, with high rolling resistance on in order to fill the gap.
    I dont pay the closest attention to the tundras mileage, but I doubt there is even 1mpg difference on the highway between stock and +2
  11. Oct 26, 2021 at 6:07 AM
    If you are just looking for the leveled look without going bigger tires, do a drop shackle kit for the rear.
  12. Oct 26, 2021 at 6:18 AM
    dougn
    dougn New Member
    Doug
    I would like a less bouncy suspension than my stock bilsteins. Hate the idea of larger tires due to rotation weight/flywheel and gearing
  13. Oct 26, 2021 at 6:30 AM
    Black
    2014 Tundra Limited CrewMax
    Falcon leveling system and Coachbuilder +1 shackles. Give a fantastic ride on and off-road.
    You don’t need to go large to make it look good.
    I have the above listed suspension and 33” tires. No need for regearing and added weight is not that much. Only going up one side really from stock.
    Plus it will handle any off-roading that most folks will throw at it.
    jeffw6236 likes this.
