2007 Tundra Tranny slipping
Discussion in '2nd Gen Tundras (2007-2013)' started by LordCARtoons, Oct 20, 2021.
  1. Oct 20, 2021 at 8:22 AM
    LordCARtoons
    LordCARtoons [OP] New Member
    Good day everyone. Have a question and hopes that someone had the same experience and solved the problem.
    I have a 2007 Toyota Tundra 4x4 with 5.7L iForce, 6 speed auto. I just bought the truck and got it on the road as a daily driver. I have noticed it is shifting really weird.
    For example, sometimes when I put it in drive, the D doesn’t light up on the dash and when that happens, the low4 light on the dash flashes. Once I play with the shifter until the d lights up, then, everything seems fine.
    But what happens all the time is when driving, the truck shifts gears very late at high revs if I give it to much gas. If I give it very little gas, it seems to shift fine. Also when driving, if I give it some extra gas pedal, it seems to go in low gear way to fast and high revs like I am going street racing. Lol.
    Any advice would be amazing. Thanks a million in advanced.
  2. Oct 20, 2021 at 8:42 AM
    audiowize
    audiowize New Member
    Paul B.
    2008 Tundra SR-5 4x4 5.7
    How many miles are on the truck? Have you service the transmission?
  3. Oct 20, 2021 at 9:05 AM
    socaldiablo
    socaldiablo New Member
    Carlsbad, CA
    2013 White Tundra SR5 Rock Warrior
    Leer camper shell, slight lift kit, TRD Pro BBS wheels
    Has the fluid ever been changed? I would start with that ....you'd be amazed at the difference fresh, good fluid can make.
  4. Oct 20, 2021 at 10:14 AM
    LordCARtoons
    Truck has about 175,000 miles on it. And the truck had papers of a tranny flush at the Toyota dealership 3 years ago.
  5. Oct 20, 2021 at 11:25 AM
    Uhhhh....
    Uhhhh.... New Member
    Dave
    Virginia
    2016 Silver Limited DC
    7” BDS, 37s
    I'd do a drain & fill (not a flush), and maybe throw a bottle of Sea Foam in it.
  6. Oct 20, 2021 at 7:04 PM
    audiowize
    Paul B.
    By doing a drain and fill, do it yourself so you know it has been done. This is definitely one of those services that is frequently billed but not actually done.
  7. Oct 20, 2021 at 7:21 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    I would side with drain and fill... my transmission has been acting funny, with no real regular maintenance, until now... when I have started thw draining and filling maintenance...
  8. Oct 20, 2021 at 8:15 PM
    NueveTundra
    NueveTundra Mod list in Bio
    Planet Earth
    07, Black Tundra SR5 CrewMax
    Exterior: Toytec ultimate 3" lift level, Total Chaos Uniball UCA's, Total Chaos Cam Tab Gusset kit, AcanII smoked headlights, AcanII smoke Tail lights (2.5 gen style), DV8 front winch bumper , Badlands 12k winch with Apex Synthetic, White AUTMATCH Shackles 3/4" D Ring Shackle, Apex Winch shackle, Trail Ridge mirrors ,Icon Rebound Pro 17"x8.5" +25, Cooper Discovery STT Pro 285/70R17, PowerStop drilled n slotted rotors W/Carbon pads, Rigid flood flush mounts rear bumper , WeatherTec rain guards , OEM black side badges , Rigid Amber Radiance Pods. Energy Suspension Red Rack and Pinion Bushings, EAG front mesh Grille, RCI HighLift bed mounts. Rough Country DS2 Steps, A.R.E OverLand Canopy with Ascend basket, Stickers: ToyTec lifts windshield banner, Red Strange Music window sticker(back cab), White Strange Music sticker(back canopy), White Rigid sticker x2 (canopy sides), white Official BigFoot Research Team (Back Canopy) Interior: Alpine double din touch iLX-650 , JL C5-653's (front) JL C1-650x (rear) , JL JX400 4 channel amp , JL JX500 mono amp , 2 JL 12" subs , WeatherTec floor mats, Kenwood F/R Dash Cams, Black steering wheel emblem overlay, Tekonsha P3 Brake controller, ToyTec "Fresh" Scent coilover air freshener, Under the Hood: Koyo all aluminum radiator, Mishimoto red silicon hoses , XS Power 3000 amp battery , LAlectric 300 amp Alternator , K&N replacement filter. Online LED store accessories Fuse/relay box. (Identified) Dirty Deeds 8" Cat back exhaust with DD resonator delete/axel over converted into dump. Coming soon:
    I would check the slack on the PNRD switch an see if its needs adjustment. Since its not registering the D light unless the shifters played with. Also doing a test and inspection of its functions would help shore up any doubts an go down the line from there.
    a half unrelated issue I had happen was when my led tail lights were going out it pop a fuse stopping the indicator from working witch if I recall gave some issues with driving.
    also as always make sure battery terminals are clean and tight.
    could be a wiring issue or ECM give me a moment to dump info in 2nd message.
  9. Oct 20, 2021 at 9:05 PM
    NueveTundra
    Planet Earth
    These three areas above are all related they are controlled by the ECM but the ECM also needs info from them.
    this process above will help rule out worn clutch's or low line pressure that would be a mechanical issue for cause of slipping
    all these ones above are info and testing on the Park/Neutral switch. Witch could cause the known issue with the D indicator light not coming on unless the shifters fiddled with.
    the 4lo light flashing is a warning for a issue with this said circuit witch house's a lot things besides PN switch.
    all of the above is ECM and ECM testing witch can also be a cause for this issue.
    I tired my best off the info given to gather this info with out dumping hundreds of pages. a few things can help me provide more accurate info like witch version of the 5.7L and console shift or column shift. thanks
    hope this information helps and allows you to get to the bottom of this. :);)
