Brake Check
Discussion in '2.5 Gen Tundras (2014-2021)' started by Tevanstx, Oct 19, 2021.
  1. Oct 19, 2021 at 1:49 PM
    Tevanstx
    Tevanstx [OP] New Member
    Thomas
    2015 Tundra 1794
    Any idea why the piston on the front passenger Fr?caliper won't retract and destroy 2 rotors?
    Thanks,
    Thomas
  2. Oct 19, 2021 at 2:36 PM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Needs a new caliper? Or ar least a solid rebuild? A very occasional thing to occur...moreso occurring on 1st gens
  3. Oct 19, 2021 at 3:29 PM
    Tevanstx
    Thomas
    2015 Tundra 1794
    You may be right on the rebuild. I'm trying to rule out the actuator since I don't have a scan tool any longer...wife's family apparently needed it more.
    I replaced the caliper first because I couldn't get it to retract with a clamp or a hang grenade. Now it seems the the hub is....past needing replacement. What's worse is I have an extended warranty but if course there's always a catch.
    I'm gonna check the hub out and then rebuild the truck starting on the front left.
    HulkSmurf14 likes this.
