CoachBuilder +3 or Icon RXT Option 2
Discussion in 'Suspension' started by eSkittles, Oct 18, 2021.
  1. Oct 18, 2021 at 1:36 PM
    eSkittles
    eSkittles [OP] New Member
    2021 Tundra Amy Green 1794
    Recently I installed a Leitner Forged bed rack with a CVT Mt. Hood 60" double channel.
    Adding to about 300lbs of weight, I noticed about 1/2" of squat.
    I love how plush and comfy the rear end rides now with option 1 (rated for 0-250 lbs) of the rxt leafs from Icon.
    Ideally I would want some rake in the rear unloaded.
    My options are:
    1) installed the second option from icon (rated 250-500lbs)
    2) buy an install coachbuilders +3 lift shackles
    there are obviously pros and cons to either options
    the first one is free
    second one is going to cost me the parts from Coachbuilders
    Just want to get more opinions.
    The photo shows how the truck sits with option 1 rxt on a NOT level ground
  2. Oct 18, 2021 at 1:38 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Roadmaster is another option I really like because you can dial it in for different loads and it acts as a sway bar too. More expensive though.
  3. Oct 18, 2021 at 1:44 PM
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
    How do you use your truck?
    If you off-road it, what type? High speed, lots of articulation?
    @MadMaxCanon mentions the Roadmaster - it's getting super popular and it's an excellent option for many situations and quite ideal for on-road.
    Just note that if you are regularly full flexing your rear suspension (picture stuffing one side and the other is hanging down in the air) the Roadmaster isn't a perfect option. Although rare, the design can cause the front eyelet to come off during major articulation and it's more of a possibility with aftermarket springs that articulate more. It's not a catastrophic failure but it would require it to be reinstalled or fully removed before continuing to travel.
  4. Oct 18, 2021 at 1:46 PM
    MadMaxCanon
    Also to add, the roadmasters will also give you around 1 to 1.5 inches of lift, depending on how tight you make them.
  5. Oct 18, 2021 at 1:57 PM
    eSkittles
    Yes i offroad! This truck is not my daily, although with the amount of mods im putting on, its making me want to drive it more often haha.
    A bit of both, ideally i would like to be comfortable on those long and rough wash board roads, and still be able to clear obstacles to get to remote camp spots.
    stevep0925 likes this.
  6. Oct 18, 2021 at 2:00 PM
    timsp8
    NY
    You could also get airbags and adjust psi based on weight. I can raise or lower my rear by 2”-3” just adding or removing air.
    Is you rear tire not centered in the wheel well? It looks really far back. Is it the angle of the pic or effect of rtx leafs?
  7. Oct 18, 2021 at 2:03 PM
    Rodtheviking
    Rodtheviking New Member
    Vancouver, WA
    Sequoia
  8. Oct 18, 2021 at 2:04 PM
    mountainpete
    I would go with the Icon.
  9. Oct 18, 2021 at 2:06 PM
    eSkittles
    Not super pumped on the idea of air bags because it will limit my articulation.
    The picture does make the tire look offcentered, but just to be sure, i just stepped out to take a look.
    I do see a little bit of the tire towards the rear. Not sure what its causing but the truck seems fine and it drives fine as well. Hopefully whatever I do (swap leaf or bigger shackles) will help with it.
  10. Oct 18, 2021 at 2:07 PM
    eSkittles
    I might just do so, its free and if i end up not liking it, i can always swap back and try the coachbuilders.
  11. Oct 18, 2021 at 2:14 PM
    mountainpete
    You can also go with +1 Coachbuilders and gain the benefits of the shackles.
    Like many others, I run airbags with Daystar cradles. Allows full articulation as the bags are not mounted at the bottom.
    Airbags are great for adjustability when towing, but when 20 psi or higher tend to pogo a bit over washboard. If you aren't towing I would go springs only if I could.
  12. Oct 18, 2021 at 2:18 PM
    timsp8
    NY
    Like mountainpete said, I have the daystar cradles. I went with airbags because I go from a few hundred pounds with my decked and tools to a 1/2 ton or so if I’m carrying pellets.
  13. Oct 18, 2021 at 2:34 PM
    ToyotaG
    ToyotaG New Member
    trucks friggin nice man
  14. Oct 18, 2021 at 2:48 PM
    BigAl
    BigAl New Member
    2014 SR5 Magnuson SC
    I'm in the same predicament. I've decided to make the jump to option 2. I think the increase in spring rate by swapping a leaf is my preferred option, rather than adding a longer shackle. Of course both will work but I'm guessing that the pack is more prone to being flattened with a longer shackle. However, I think the best of both worlds would be to add a Coachbuilder +1 or similar (Total Chaos shackles for example), at the same time to gain additional strength. The stock shackles are okay, but leaves room for improvement. Let us know what you decide.
  15. Oct 18, 2021 at 2:54 PM
    cctxquicksand
    cctxquicksand IG - TRDistheWrd
    Go with option 2.
    I run this setup full time and the leafs handle the weight very well
    HighDesertSurfer likes this.
  16. Oct 18, 2021 at 3:09 PM
    eSkittles
    yeah option two seems like the best way at the moment (already have the leaf spring)
    adding that +1 for the beefed up shackle i think will also be next too.
    Thanks everyone for the input
    cctxquicksand[QUOTED] likes this.
  17. Oct 18, 2021 at 3:10 PM
    eSkittles
    fifteen52 gang, are you running 37s?
  18. Oct 18, 2021 at 3:40 PM
    cctxquicksand
  19. Oct 18, 2021 at 5:17 PM
    Alexstundra
    Alexstundra Not a new member
    Northeast PA
    2016 MGM DC Trd
    3-1 level kit with add a leaf. 295/70/18r cooper max. Spider head light tail light and third brake light, tint, badges off, ladder racks, trd pro grill, color matched hood bulge, grab handle,coach builder +2, dv8 front bumper with winch, fender flares, bed cover....
    I’m on option two and Coachbuilder +2 and rides good. I’ve only had them on like this so I don’t know the difference between option 1 and 2. And stock vs Coachbuilder shackles so no help there. F722879E-C00F-413F-A8DD-B443B317D76B.jpg
  20. Oct 22, 2021 at 11:07 AM
    eSkittles
    Hey everyone, after very long and painful hours, I went with option 2. what i noticed was that there was a substantial amount of bed bounce GONE! amazing
    another thing i noticed was that just like how there was a very very little bit of sag before going opt 2, there is now a very very bit of rake! So far so good, will keep updated
    HighDesertSurfer and BigAl like this.
  21. Oct 22, 2021 at 1:12 PM
    timsp8
    NY
    Post some pics.
  22. Oct 27, 2021 at 11:53 PM
    eSkittles
    So yesterday i realized that there was a front and rear for the leaf packs after taking a look at the leafs I took out. Today I flipped both packs!
    Ill post pics soon
  23. Mar 2, 2022 at 5:54 AM
    DgoTss
    DgoTss New Member
    Wesley
    Durango Colorado
    2015 dbl TSS
    I did this same thing! I swear it doesn’t say anything on the packs themselves but they are different front and back and I put them in backwards the first time! Still liking the option 2 ride and rake? Stock shackles?
  24. Mar 2, 2022 at 12:32 PM
    eSkittles
    When im unloaded, its perfect, when loaded with a firewood for 3 nights, camping gear for 2, it sags. Coachbuilders shackles are next!
  25. Mar 2, 2022 at 12:33 PM
    eSkittles
    here is the new side profile
    reywcms and GAknight like this.
  26. Mar 2, 2022 at 12:48 PM
    GAknight
    GAknight New Member
    Shade of a Pine, GA
    '14 TSS 4x4
    Too many…scratch that…not done yet.
    Which CB shackles are you planning for?
    Unloaded, about how much lift do you have? Looks like 2.5 - 3”???
    Apologies if I missed this in an earlier post, but are you on 37’s?
    I’m asking b/c I’m on 35’s with 3” CB shackles and airbags with cradles. I’ve got an ARE cap on the back. I’ve been considering changing up some parts, specifically with the springs and the RAS in particular seeing its rise and reviews.
  27. Mar 2, 2022 at 12:50 PM
    eSkittles
    I am not sure, havent done any measuring yet. I am sitting on 35s"
    dont plan on running 37s until i regear with 3x lock
    GAknight[QUOTED] likes this.
  28. Mar 2, 2022 at 1:00 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Looks great! Man I've been wanting these fifteen52 wheels I'm so torn. lol
  29. Mar 2, 2022 at 1:57 PM
    eSkittles
    i love fifteen52. they make very unique wheels and have had ZERO problems with them
    reywcms[QUOTED] likes this.
  30. Mar 3, 2022 at 7:27 PM
    DgoTss
    DgoTss New Member
    Wesley
    Durango Colorado
    2015 dbl TSS
    I had RXT springs on setting 1 with CB +1 shackles and loved the ride but it sagged easily under weight and made a loud “clacking” noise off-road as the leafs were separating and then slapping on up or down travel. I switched to OME springs and it handles weight a bit better but the ride leaves a lot to be desired. Thinking of switching back to RXT with setting 2 or 3?
