  1. Oct 17, 2021 at 5:56 PM
    Hamster14
    Hamster14 New Member
    Utah
    2014 Tundra Limited
    -46 gallon tank - shell
    awesome setup!!
    1794TX and MooseTundra[QUOTED] like this.
  2. Oct 17, 2021 at 6:18 PM
    FlyByMike
    FlyByMike New Member
    2018 MGM Tundra Platinum 4x4
    Added some Diode Dynamics amber floods (SS3 Pros) today, and got some new Yokohama Geolandar G015s (stock size 275/55R20) mounted earlier in the week.
  3. Oct 17, 2021 at 6:51 PM
    02ducky13
    02ducky13 New Member
    Terry
    TSS 2017
    None
    Need a night pic with those on, that's my next upgrade.
    Toe404 and FlyByMike[QUOTED] like this.
  4. Oct 17, 2021 at 7:02 PM
    mcharfauros
    mcharfauros Hafa Adai
    MO
    06 AC SR5 4X4
    Dumb Truck Thangs
    Diggin it, was looking into this one when I had my Tacoma, finally one came up for sale local. Hopefully one pops up for the Tundra in the used local market.
    MooseTundra[QUOTED] likes this.
  5. Oct 17, 2021 at 7:10 PM
    boostedtrdpro
    boostedtrdpro voided warranty
    Jeremy
    2024 GMC Sierra 2500HD AT4X 2020 Sequoia TRD Pro 040
    Weird quoting myself but, there’s a few spots of bare metal where the grinder nicked the black paint under the truck removing the spare tire guides…I think it needs painted so it doesn’t rust. Should I just use good old Rustoleum flat black enamel? What would you guys use?
    HulkSmurf14 likes this.
  6. Oct 17, 2021 at 7:12 PM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Just spray the Rustoleum as it will likely never be seen as long as you stay on your tires and not your roof. Easy fix!
  7. Oct 17, 2021 at 7:21 PM
    LarryDangerfield
    Tyler
    Northern Wisconsin
    You just wait
    If you don't want to mess with paint you can use this https://www.amazon.com/CRC-06026-He...gid=pla-522705564860&ref=&adgrpid=61116063494 I used it after I destroyed the powder coating on some coilovers and after a long salty winter where I sprayed looked just like the day the powder coating came off.
  8. Oct 17, 2021 at 7:23 PM
    00PS
    00PS New Member
    2016 Barcelona Red Limited Crewmax TRD 4x4
    Your headrest is on backwards. ;)
    Tundrastruck91 likes this.
  9. Oct 17, 2021 at 8:15 PM
    Dogsled
    Dogsled New Member
    White 2020 1794 4x4
    Currency converter= Earned to wasted dollars
    Yep..Best mod yet!..
    HulkSmurf14 and 1794TX like this.
  10. Oct 17, 2021 at 8:27 PM
    normagene
    normagene New Member
    Normagene
    New England
    2021 Cement DC Limited Texas Edition
    Texas Edition
    Not sure what you mean by “getting the shift gate out”. Are you asking how to remove just the chrome part from the shift gate?
    If you are saying “remove the entire shift gate” it’s really easy. Remove the shift stick, open the center console and pop out the entire center component. There are two tabs on each side of the shift gate so with a small screwdriver gently press on each tab and it pops/pulls right out.
  11. Oct 17, 2021 at 8:34 PM
    Dsptundra
    Austin TX Area
    2021 Silver Limited CM
    Those look great with the limited grill. Did you modify the brackets at all or did they line up as shown?
  12. Oct 18, 2021 at 12:56 AM
    SAGE63
    San Diego County
    no mod to brackets. fit good
    Dsptundra[QUOTED] likes this.
  13. Oct 18, 2021 at 6:09 AM
    normagene
    Normagene
    New England
    Texas Edition
    Got rid of the cupholder chrome!
    Dipped using Anthracite Gray Plasti-dip then several coats of clear matte enamel rust-oleum.
    Steve66, a522467, AZ Red Nek and 12 others like this.
  14. Oct 18, 2021 at 6:13 AM
    dugfur
    dugfur New Member
    doug
    2016 limited DC
    REALLY NICE. where did you get these from????
    TRDFerguson likes this.
  15. Oct 18, 2021 at 6:23 AM
    Nowhereman
    Nowhereman New Member
    Al
    Monterey Bay area
    2021 Tundra SR5 / TRD / Cement
    Rough Country shocks, ReTrax cover, Summo springs, black out badging, bed extender, "some other things I can't mention"
    The bugs and low flying birds will be impressed !:thumbsup:
    batman900[QUOTED] likes this.
  16. Oct 18, 2021 at 6:47 AM
    BecauseRacecar
    BecauseRacecar New Member
    Ohio
    '20 Tundra SR5 DC 4x4 Magnetic Gray
    Do you like the visors? I was curious if putting those on will fix the horrible wind-buffeting I get inside when opening the windows. This truck has the most violent airflow of any vehicle I've owned when the windows are open.
  17. Oct 18, 2021 at 6:51 AM
    Nowhereman
    Al
    Monterey Bay area
    There's this thing, it's really cool. It's called air conditioning.....:crapstorm:
  18. Oct 18, 2021 at 6:53 AM
    Bob_Wiley
    Bob_Wiley I feel good, I feel great, I feel wonderful...
    Eric
    AZ
    2016 Black SR5 Crewmax 5.7 FFV
  19. Oct 18, 2021 at 6:56 AM
    Badknees
    Badknees New Member
    2016 White Tundra 1794 CM 4X4
    TRD Pro BBS Wheels, TRD LED Headlights, Rigid LED Fog lights, 040 TRD Grille, 040 Hood Bulge, Black Center Valence, Driver's Grab Handle, TRD Pro Fox Suspension, 1.00" BORA Wheel Spacers, 1.5" Rear Shackles, TRD Front and Rear Sway bars, 295/70 R18 Cooper Discoverer AT3 XLTs, Full Size Spare, TRD Dual Exhaust, Console cover, Console Organizer, Husky Liner X-act Contours, Tinted Front Windows, Stubby Antenna, Autoventshade Deflectors, Duplicolor Painted Calipers, 040 Painted Front End Caps, Undercover Armor Flex Bed Cover
    If only the double cabs had that power rear window you could open a bit to let the air flow through...:p :crapstorm:
    Edit: I have the visors and they also help block the sun coming in at low angles and good for leaving the windows cracked on hot summer days!
  20. Oct 18, 2021 at 7:13 AM
    NorthShore
    NorthShore New Member
    2014 SR5 TRD Offroad Crewmax
    Remove just the chrome part os what I meant. Got them out and finished up yesterday. Thnaks to all who gave tips/suggestions. Really happy with the results.
  21. Oct 18, 2021 at 7:35 AM
    EatSleepTacos
    EatSleepTacos New Member
    Randy
    West Valley, AZ
    2020 Crewmax SR5 TRD Sport
    Threw this together in about 30 min with stuff I had laying around. 15”x36” with a single 3” leg to support that one corner. Sturdy enough and easy to pop in and out as needed.
    3CC7C046-E4BE-4BFB-AFAB-C6CB1BFD0CFB.jpg CA2500EF-D1C1-4297-807D-553846C3290F.jpg 3D4E9FDB-193A-4C6A-A63E-BF831E017474.jpg DD0A11F2-2144-494C-92DF-5FA63F0E2573.jpg
    GAknight, Scud, FishFlash and 22 others like this.
  22. Oct 18, 2021 at 8:01 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    Are you doing a build to the new Tundra to match your Tacoma? :D:sawzall:
    EatSleepTacos[QUOTED] likes this.
  23. Oct 18, 2021 at 8:08 AM
    Mtneer4life
    Mtneer4life New Member
    Dusty
    2019 Cavalry Blue Tundra
    Just installed this nice carbon fiber shifter knob. Nice feel and I really like the way it looks.48923FAA-57C0-4A75-9F9E-A89D53303577.jpg
  24. Oct 18, 2021 at 8:09 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    Hereeeck no, I need this to be a comfortable daily driver and reliable tow rig.
    Jaypown[QUOTED] and 1794TX like this.
  25. Oct 18, 2021 at 8:16 AM
    Badknees
    Badknees New Member
    Maybe figure a way to hinge that puppy so you can flip it back and leave it under the seat whenever you don't need?
  26. Oct 18, 2021 at 8:20 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    I thought about that but the frequency in which he's in the truck is so infrequent that it's honestly not worth it.
    Badknees[QUOTED] likes this.
  27. Oct 18, 2021 at 8:22 AM
    Badknees
    Badknees New Member
    Nice idea you have and makes me think. It sure would be nice to have a level floor in the back at times. BTW, like your dog and neighbors (?) Camaro!
  28. Oct 18, 2021 at 8:26 AM
    romad86
    romad86 New Member
    Warrenton, VA
    2021 Limited Cement
    Some good ingenuity there.
  29. Oct 18, 2021 at 8:26 AM
    TexAirUh
    TexAirUh New Member
    NEPA
    2021 Cement Tundra Limited TRD O/R
    I surprisingly haven't experienced that eardrum blowing wind sound yet in this truck. I mostly got these to be able to crack the windows in the rain / snow without getting wet and am pretty happy with them so far. Super easy to install and they look great. My windows are well tinted but as mentioned above, these also help with the sun when it's at a weird angle.
  30. Oct 18, 2021 at 8:31 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    I've built a similar, albeit much sturdier platform for my Tacoma, and having a flat surface for stuff is so handy.
