Platinum and 1794 Dealer Spec sheet
Discussion in '3rd Gen Tundras (2022+)' started by ThePolak, Oct 4, 2021.
  1. Oct 4, 2021 at 8:03 PM
    Coal Dragger
    Coal Dragger New Member
    Kung Fu Dick
    I would be surprised if they reduced engine weight very much under the 5.7L. What was reduced in weight shaving off two pistons, two con rods, and the materials in the block, heads, cam, and crank were probably mostly gained back in liquid to air intercooler hardware, and turbochargers. Plus the new 10 speed transmission and significantly beefed up transfer case probably weigh a bit more, maybe the same but that would be quite a feat of engineering.
    Using aluminum for the hood, fenders, and doors (I think) saved weight. The composite bed with aluminum reinforcement definitely saves weight.
    I suspect two dual rate coil springs save a substantial amount of weight over two leaf spring out back. I’ll bet we would be surprised how much weight that saves, although the equipment for the 5 link rear eats back into the weight savings.
  2. Oct 4, 2021 at 8:59 PM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    2022 Ram TRX Level 2
    I’m curious what the hybrid upgrade will cost. I feel like it’s going to be a worthy upgrade for me.
    =JSG= and Tamadrummer88 like this.
  3. Oct 4, 2021 at 9:05 PM
    Captain papa
    Captain papa New Member
    I am surprised by the curb weight. Assuming these are 4 wheel drive the curbs weights are almost identical to 2021 models and about 400 pounds higher than an F150.
  4. Oct 4, 2021 at 9:51 PM
    BigArt
    BigArt New Member
    2008 Tundra Crewmax Limited
    My 2008 Crewmax Limited 4x4 is like 1270 Payload. this is a pretty good improvement. I wonder what the long bed is?
  5. Oct 5, 2021 at 3:43 AM
    Demar002
    Demar002 New Member
    Frank
    2022 Toyota Tundra
    Is it true that you only have the auto power windows up and down for the driver ?
    johnnygoodlife likes this.
  6. Oct 5, 2021 at 3:53 AM
    Melikeymy beer
    Melikeymy beer No cooler for you!
    Muscogee Nation
    2025 RAM 3500 6.7L Cummins
    I hope that CM Platinum PL is real but I'll believe it when I see it on a door sticker.
  7. Oct 5, 2021 at 5:45 AM
    nodak67
    nodak67 New Member
    JR
    its probably because they now offer the off road package on the 1794 and not the platinum.
  8. Oct 5, 2021 at 7:29 AM
    kstateskier
    kstateskier New Member
    Bradley
    Kansas City, MO
    2022 Tunda 1794 - Dark Metallic Grey
    damn thats annoying. I want all 4 auto/up/down. Hopefully all 4 buttons are fucking backlit this time. When I bought my Limited I was annoyed that only the drivers window was backlit. Hell I can't find the door locks in the dark.
  9. Oct 5, 2021 at 10:42 PM
    JasonKing6
    JasonKing6 New Member
    Glad to see HUD is equipped. No videos give this information I was a bit worried. Now new Tundra has every single feature that new modern vehicle should have and is ready to battle all these EVs. Rejoice!
  10. Oct 6, 2021 at 12:42 AM
    CMikeB
    CMikeB New Member
    Doesn't look like driver's glass is auto-up and auto down( like our 04 Honda Pilot!o_O) only auto down.
  11. Oct 6, 2021 at 5:14 AM
    Tamadrummer88
    Tamadrummer88 New Member
    Soon to be 2022 or 2023 Tundra, 2020 Camry Hybrid, 2020 4Runner TRD Pro
    If it’s anything like the up charge with current Toyota hybrids, $1500 to $2k wouldn’t seem out of the norm.
    MTRock and BTBAKER[QUOTED] like this.
  12. Oct 6, 2021 at 5:56 AM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    I can live with that.
  13. Oct 11, 2021 at 11:52 PM
    ubserved
    ubserved New Member
    Michael
    2017 Toytota Tundra Platinum Crewmax
    Grillguard, front LED light bar, Leer Tonneau cover, rear LED bars
    So what exactly is the thigh adjustment support on the front seats? Also anyone know any of the mileage expectations for the new engines?
  14. Oct 12, 2021 at 3:22 AM
    ThePolak
    ThePolak [OP] 2022 Platinum hunt/tow/haul/family ride on order!
    The Land of the Cobra Chicken
    The thigh adjustment is part of the seat cushion. The front of the seat cushion folds down (as normal) but can be adjusted and lifted up to suit those with longer legs.
    As for mileage, I think that may come out soon. I read there was an embargo about testers talking about driving experience until today and I heard that that may also include mileage. I saw som YouTube videos premiering at 7 discussing driving the truck so I’ll try to post a link when I find it again.
  15. Oct 12, 2021 at 8:15 PM
    TundraSchmundra
    TundraSchmundra New Member
    Yeah, it’s nice for taller drivers. But with the spec sheet being released today, we can confirm that the Pro definitely does not get that, and also doesn’t have the heads up display, the heated and ventilated rear seats, or the rear sunshades.
  16. Oct 13, 2021 at 3:19 PM
    ubserved
    ubserved New Member
    Michael
    It has definitely caught my interest. I have a 17 Crew Platinum and the driver door panel is toast. I stand 6'5 and my legs have to go somewhere. I am so ready for the new ones to come out so I can check them out.20210927_140306.jpg
  17. Oct 13, 2021 at 3:37 PM
    nodak67
    nodak67 New Member
    JR
    if you can find a 2018 or higher platinum/1794, they have the seat bolster as standard to test.
  18. Oct 13, 2021 at 10:26 PM
    Lightning_Lad
    Lightning_Lad New Member
    Tom
    Orange CA
    2017 Silver Sky Platinum Pro
    Line x Bed liner Trifold Tonneau cover TRD PRO Dual exhaust TRD PRO sway bar TRD PRO air intake TRD PRO suspension TRD PRO LED 2019 Headlight conversion TRD 2020 Wireless charging tray TRD shift knob TRD PRO Grille TRD red anodized dust caps (+25 hp per wheel) Matt black mirror caps and door handles Tesla style Headunit KTJO 4x4 tail gate pop n lock upgrade Driver side grab handle Viper Remote start Viper alarm system 18” Method NV’s 33.5” Toyo R/T ESP Long box underseat storage 3M ceramic tint
    I have to admit, Toyota really modernized their interiors and optioned the trim levels appropriately. Whilst I would love a TRD Pro, I can’t stomach $12k+ over MSRP to get one and still have a stupid 5.5ft bed.
    I think a lot of people will go with a highly optioned Platinum or 1794 with 4x4 off road package and finally get the best of both worlds.
    =JSG= likes this.
  19. Oct 13, 2021 at 10:33 PM
    DrZoidberg
    DrZoidberg New Member
    Dave
    Tesla MYP
    Also doesn’t have memory seats according to the released spec sheet
  20. Oct 14, 2021 at 1:03 AM
    #50
    ubserved
    ubserved New Member
    Michael
    Anyone who pays over MSRP at any time is brain dead.
  21. Oct 14, 2021 at 7:04 AM
    #51
    TundraSchmundra
    That's strange... in the youtube vid below, if you skip to about 10:05 when he opens the door you can see what appears to be the memory seat buttons on the driver door. I'm sure there's a better video out there that can confirm/deny this.... but let's hope the spec sheet is wrong.
    https://www.youtube.com/watch?v=ppxfU6YE8gE
  22. Oct 14, 2021 at 7:10 AM
    #52
    DrZoidberg
    Dave
    Tesla MYP
    Yeah I see it there too. Like I said in my post above. I’ll wait for the build tool and Toyota spec release
  23. Oct 14, 2021 at 5:32 PM
    #53
    JasonKing6
    I don't see anybody talking about HUD but it's listed here.
  24. Oct 14, 2021 at 6:04 PM
    #54
    nodak67
    nodak67 New Member
    JR
    but the option sheets shows it as part of the AVS system and rear bag package, just a really odd combo package
  25. Oct 15, 2021 at 1:49 PM
    #55
    rickspartan
    rickspartan New Member
    2004 Gray Tundra TRD Offroad
    Where can you see these option sheets?
  26. Oct 15, 2021 at 7:24 PM
    #56
    ThePolak
    They just updated the option sheet.
    https://pressroom.toyota.com/vehicle/2022-toyota-tundra-i-force-max/
    Not sure about what is going on the rea diff on the platinum. When it comes up as a line item it is N/A whiel the 1794 shows it as a P (package). Later down, the TRD package is available on both the plat and 1794 which contain the rear diff. I think they still have some proofreading to do.
  27. Oct 16, 2021 at 7:30 AM
    #57
    Gunship Guy
    Gunship Guy New Member
    Rick
    Don’t forget the fully boxed frame. Back when Ford announced that the super duty line would be getting the aluminum skin like the F-150, they said there would be zero weight reduction. What they gained in weight reduction from the aluminum would be spent making a stronger/stiffer frame.
    David from Automotive Press on YouTube has great info and does read posted comments looking for questions etc.
  28. Oct 17, 2021 at 6:04 PM
    #58
    johnnygoodlife
    johnnygoodlife New Member
    johnny
    bergen county, nj
    kstateskier likes this.
