TRD Pro Grille ,,,, part number needed Silver sky metallic
Discussion in '2.5 Gen Tundras (2014-2021)' started by brandostundra, May 13, 2020.
  1. May 13, 2020 at 1:32 PM
    brandostundra
    brandostundra [OP] New Member
    looking to do the TRD Pro grill sway on my 2016 Tundra in silver sky metallic.
    I have the toyota part number for the bulge , but looking for the toyota part number for the grille assembly in the silver sky metallic. thanks
  2. May 13, 2020 at 1:40 PM
    DSTundra
    DSTundra New Member
    Dave
    Albuquerque, NM
    2017 Tundra Platinum
    It isn't available because the TRD Pro doesn't come in Silver Sky Metallic. If you have an existing surround that is silver sky metallic, you can order the TRD Pro in any color you want, but you'll need to separate the insert from the surround on both the new grille and your existing grille so you can swap inserts. It's a mild pain, but very doable. I just did it a week and a half ago on my '17 Platinum.
    Dave
  3. May 13, 2020 at 1:48 PM
    rodl12
    rodl12 New Member
    Rod
    South Jersey
    2017 Tundra SR5 Double Cab
  4. May 13, 2020 at 2:15 PM
    brandostundra
    thanks for the replies,
    dave was it difficult to do what you did? in regards to installing the black center grille into a factory sky silver frame? Just an hour or 2 on the work bench?
    RODL12 , I like daves grille better, but followed the link and read that someone named roman can provide what I need painted in silver sky. does anyone have contact for roman?
  5. May 13, 2020 at 2:38 PM
    RangerBP
    RangerBP SC Expat. Go gamecocks.
    2017 4x4 DC, Silver Sky
    Roman isn’t offering painted parts aside from what can be ordered direct. That limits the pro grille surround only to those colors that the pros came in for whatever year. Since pros never came in SSM, you’ll have to take it somewhere local to be painted.
    The first post on this thread will help you out a lot: https://www.tundras.com/threads/ultimate-oem-toyota-parts-thread.10707/page-93
  6. May 13, 2020 at 3:46 PM
    brandostundra
    well im learning a lot here pretty fast.
    ok, let reverse engineer this.
    i have a 2016 limited in silver sky metallic, with chrome grille , surround and buldge.
    Like many others, I want to get rid of all that chrome. I have found a few hood bulges in this color , and have the toyota part number as well.
    I guess I need to find a silver sky metallic grille surround , What other years was silver sky metallic offered for the tundra?
  7. May 13, 2020 at 3:47 PM
    rodl12
    rodl12 New Member
    Rod
    South Jersey
  8. May 13, 2020 at 3:48 PM
    rodl12
    rodl12 New Member
    Rod
    South Jersey
  9. May 13, 2020 at 3:48 PM
    brandostundra
    thanks for the link, but magnetic grey is the same color as silver sky , so there would be a difference in color
    ................ but might look interesting ??
  10. May 13, 2020 at 3:53 PM
    rodl12
    rodl12 New Member
    Rod
    South Jersey
    They are out there, you might have to do a little digging. Maybe try and reach to the ebay seller.
  11. May 13, 2020 at 3:56 PM
    unclebeejo808
    unclebeejo808 New Member
    Oahu
  12. May 13, 2020 at 4:15 PM
    brandostundra
  13. May 13, 2020 at 4:20 PM
    Inquiringone
    Ter
    NorCal 408
    Not many yet, mostly stock.
    Sparks parts can paint any color
    For most parts that I’ve seen advertised. Good luck
  14. Oct 6, 2021 at 8:40 AM
    wexttxco
    wexttxco New Member
    21 SR5 DC 4x4
    Fox 2.5 RR, 35x12.5r18 x3 on method 701, armor, front bumper
    Bump, anyone have the part number for ssm grille and bulge?
  15. Oct 7, 2021 at 7:55 AM
    Highsierraguy
    Highsierraguy New Member
    Nor Cal
    The reply’s in this thread are still accurate. I’m unhappy with the color match of my sparks parts surround and bulge as it’s noticeably darker. If I could do it over I’d just order a base color like black or white and take them to a body shop to paint to match.
  16. Oct 7, 2021 at 7:57 AM
    50Shades
    50Shades Sin City Tundras
    J
    West Coast
    2021 Tundra SR5 CrewMax Trail Edition 4x4
    reviews about sparkparts color match is mediocre. I am very hesitant to order my front bumper caps from them
  17. Oct 7, 2021 at 2:55 PM
    wexttxco
    wexttxco New Member
    21 SR5 DC 4x4
    Great info, thank you. I'll have a bumper/grill guard anyways, so maybe I'll just go to black.
  18. Oct 14, 2021 at 9:02 PM
    mgnchakar
    mgnchakar New Member
    2016 Black Tundra TRD 4x4
    Sticking with chrome!
  19. Oct 15, 2021 at 3:38 AM
    PermaFrostTRD
    Northern NY
    Just to clarify a little about auto painting and dealer “color match”
    The dealer is painting your parts to a “code”. For mgm, ssm, etc. your trucks have been exposed to elements from anywhere from 1-7years (based on the gen 2.5 release dates). UV is a nightmare to paints and clearcoats. If your pro grille surround had been allowed to age the same amount of time as your truck, you likely wouldn’t notice the difference. For a true color match, find a good body shop that can start with your “code” and adjust based on your vehicles age. $.02
    wexttxco likes this.
  20. Oct 17, 2021 at 1:48 PM
    9DivDoc
    9DivDoc New Member
    Wisconsin
    2021 TRD PRO CM MGM 2021 SKM CM Limited
