03 K&N intake on an 06?
Discussion in '1st Gen Tundras (2000-2006)' started by DocSchultz, Oct 17, 2021.
  1. Oct 17, 2021 at 9:00 AM
    DocSchultz
    DocSchultz [OP] New Member
    Golden Co
    2006 Tundra Limited
    Tundra limited Merged with Darrell Walter edition. plastic Removal of bedcaps and Fender Wells. Custom made tailgate and sidebed metal Made. Installed With green panel bond. Raptor liner installed in the bed. Everything but the truck cab came off down to the frame. Took off all the loose rust with wire wheels. Por 15 All accessible metal parts. I did all the work on the body and the frame machine at school where I was attendingLincol Tech for auto body. I did all the body work tainted and cleared this Tundra. It also has and fab 3 Step running boards. It also has a rebuilt transmission about 70000 miles ago. Soon to come as a Turbo kit with more than likely a standalone E you with it. And then when Everything else is done mechanically and cosmetically interiors last .
    I found a good deal on an 03 K&N cold air intake. I was wondering if it would fit on my 06 without any problems?
    Thanks
  2. Oct 17, 2021 at 11:47 AM
    HBTundra
    HBTundra New Member
    2006 DC 2wd
    IMO , waste of money . . . the factory setup is superior.
    Unless you just want to tinker, then have at it . . . not sure about the fit though from 03 to 06.
    DocSchultz[OP] and shifty` like this.
  3. Oct 17, 2021 at 12:16 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    I believe that the throttle body is a different size. @empty_lord ?
    DocSchultz[OP] likes this.
  4. Oct 17, 2021 at 12:31 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    You don’t need all that extra dirt in your engine
  5. Oct 17, 2021 at 2:40 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    yes.
  6. Oct 17, 2021 at 5:10 PM
    shifty` Ten EV 12's so you know I raise hell
    Don't bother with aftermarket. Toyota's OEM filtration products stomp the crap out of aftermarket, even the "performance" stuff. And it's not very expensive. Don't bother with K&N. I honestly believe that's part of the secret sauce to Toyota's longevity. Solid-built drivetrains with killer OEM filtration products.
    DocSchultz[OP] and HBTundra like this.
  7. Oct 19, 2021 at 11:30 AM
    DocSchultz
    Golden Co
    2006 Tundra Limited
    Thanks everybody I'm sticking with the OEN air filter just going to continue to put top quality air filters in often
    Darkness and Hbjeff like this.
  8. Oct 20, 2021 at 6:48 AM
    Jcross0304
    Jcross0304 New Member
    Johnathan
    2006 Tundra SR5 DC 4wd
    I have a K&N cold air intake on my 06. Came on the truck when I bought it. I would do an even trade on it for a factory intake. Nothing wrong with it. Sounds goods just a little loud for my taste.
  9. Feb 27, 2022 at 12:29 PM
    Playfast12
    Playfast12 New Member
    Just use K&N filter itself with stock intake
