  1. Oct 16, 2021 at 6:31 PM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    :fistbump:
    BiggHertz likes this.
  2. Oct 16, 2021 at 6:32 PM
    Dogsled
    Dogsled New Member
    White 2020 1794 4x4
    Currency converter= Earned to wasted dollars
    PowerBrakes Kit… Calipers/Rotors/stainless brake lines… Only a couple of days old… haven’t had a chance to test them out… They were recommended to me by my mechanic for towing my trailer… they dissipate heat well.. I guess :notsure:… They look sexy as sh*t though…
  3. Oct 16, 2021 at 6:43 PM
    Chris5MGM1794
    Chris5MGM1794 New Member
    2016 Magnetic Gray Metallic Tundra 1794
    installed my 40 sheets of sound deadening material in the truck, had great luck with this stuff in my ram so figured I'd do it in the tundra too
    D4x4TRD, AggiePhil, Cosmoblu and 7 others like this.
  4. Oct 16, 2021 at 7:38 PM
    NorthShore
    NorthShore New Member
    2014 SR5 TRD Offroad Crewmax
    Made a little progress on interior chrome delete. Anyone have a tip on removing the shift gate piece? Couldn't get the d#*% thing out.
    D4x4TRD, Cosmoblu, 1794TX and 2 others like this.
  5. Oct 16, 2021 at 7:48 PM
    NWPirate
    Zach
    WA
    If I remember right, it's plastic welded on the back side. You have to remove the whole console piece.
    1794TX likes this.
  6. Oct 16, 2021 at 7:58 PM
    Elroy_unlimited
    Elroy_unlimited New Member
    Eric
    Murfreesboro TN
    2017 limited crew max
    Installed my lift wheels and tires.
    GAknight, D4x4TRD, 3xYOTA and 25 others like this.
  7. Oct 16, 2021 at 8:14 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Buy the AJT one and snap it over the chrome
  8. Oct 16, 2021 at 10:49 PM
    engineer
    engineer Drive it 4ever
    Seattle, WA
    '21 Limited Double Cab
    Test fit my new ReadyRamp. They had been out of stock for a while, so I jumped on these. Yes, it does fit with the Total Chaos bed stiffeners! Now I'd like to know what's the best way to stiffen the tailgate for loading my motorcycle?
  9. Oct 16, 2021 at 11:26 PM
    Toe404
    Toe404 just a poser
    Tomas
    Concord ,CA
    '21 Cavalry TRD Sport CM Tundra & 25 TRD Pro Sequoia
    Your tailgate can handle the weight of the bike rolling in and out of the bed no problem. I’ve loaded my bike in and out of trucks for years and never once had an issue
  10. Oct 17, 2021 at 1:43 AM
    It's easy. I'll reply again when I'm more awake and tell you how to do it.
    1794TX, 1UP and Hamster14 like this.
  11. Oct 17, 2021 at 5:47 AM
    Hightide
    chadington von banks
    Abalama
    Magic School Bus
    Oh shit, bro!
    Damn!
    I hope everyone is ok.
  12. Oct 17, 2021 at 5:47 AM
    justcuz
    justcuz 2.5 Gen Member
    RobertD likes this.
  13. Oct 17, 2021 at 5:49 AM
    Hightide
    Abalama
    Magic School Bus
    New aftermarket bumper time!
    :smokertransformer:
  14. Oct 17, 2021 at 5:53 AM
    So to get that chrome piece off, pull the trim panel off . The whole panel comes off as pictured. There are 2 screws on the shifter assembly to remove it.. On the bottom you will see where the chrome is attached by 5 or so plastic pins that are melted in place. I used needle nose pliers to carefully twist those off. The chrome can now be removed. When I put mine back together, there was enough pin material left in the hole that I used a soldering iron to melt it to the surrounding plastic of the hole. After I did that, I took the pieces that I twisted off and melted those back into them as well. I did mine a year ago and have not had any issues at all.
    GAknight, D4x4TRD, AZ Red Nek and 4 others like this.
  15. Oct 17, 2021 at 5:59 AM
    Clemsonman14
    Clemsonman14 New Member
    2020 SR5 Crewmax 4x2
    Is the trans cooler noticeable when looking at the truck through the grill?
    diablodalton likes this.
  16. Oct 17, 2021 at 8:18 AM
    DCB500
    DCB500 New Member
    Oklahoma City
    2019 Tundra SR5 TSS Double Cab
    Wheels, sound system, antenna, tailgate letter inserts, Grill/Hood Bulge, Exhaust, Leather
    You’ll have to take that whole center section out and break it loose from underneath. Very easy to remove, just pry up from underneath the console lid but AJT makes a piece you can just snap over it.
  17. Oct 17, 2021 at 8:20 AM
    EatSleepTacos
    EatSleepTacos New Member
    Randy
    West Valley, AZ
    2020 Crewmax SR5 TRD Sport
    GAknight, D4x4TRD, AggiePhil and 15 others like this.
  18. Oct 17, 2021 at 8:36 AM
    1794TX
    Steven
    N.TX
    '20 1794
    Once the console parts are off, there are two little tabs on either side of the plate that lift up just a bit to allow the whole thing to lift off. You'll get one side up and it'll re-seat itself when you're working the other side, so right-lane patience and resisting the urge to pry harder won't come that easy. Once it's off, there are some plastic welds on the under-side of the plate to dremel off to get the chrome separated from the rest of the piece. I used 600-grit sandpaper on the chrome to try and get the SEM trim black paint to stick, and I'm happy with the result. I like the AJT pieces just fine, but am happier having painted. I did the shifter, the silver dash piece, the steering wheel silver, the steering wheel emblem, and the vent rings the same day. It was a kinda long day, but it's done.
  19. Oct 17, 2021 at 9:11 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    Here’s a better pic. One guy in the cooler thread painted his black with some radiator paint but I kinda like it peeking through.
    3xYOTA, AggiePhil, Cosmoblu and 7 others like this.
  20. Oct 17, 2021 at 9:23 AM
    Clemsonman14
    It really doesn’t look bad. Probably wouldn’t even notice it after a while
  21. Oct 17, 2021 at 10:59 AM
    Depends on the grill and the color of the cooler.
  22. Oct 17, 2021 at 1:52 PM
    MooseTundra
    MooseTundra New Member
    Mark
    SLC, UT
    2021 Lunar Rock Tundra TRD Pro
    After a brief 7 month wait for the backorder, got the RSI Smart Cap. The bed rails were able to be used and not removed which was great.
    While he won't ride back there, Moose had to check it out.
    GAknight, 3xYOTA, Toondra and 34 others like this.
  23. Oct 17, 2021 at 2:11 PM
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
    @IowaGuy
    IowaGuy likes this.
  24. Oct 17, 2021 at 2:27 PM
    Dupey
    Dupey I love chips and salsa!
    Northern Colorado
    2014 tundra platinum
    TRD PRO GRILL TRD PRO HEADLIGHTS W/I hacker ADAPTER WIRING WEATHER TECH FLOOR LINERS C4 FRONT BUMPER WITH 30 inch LIGHT BAR RCI ROCK SLIDERS RCI SKID PLATE RCI LOW PROFILE BED RACK ARB TOURING ROOF TOP TENT TOYTECH 2.0 FRONT COILOVERS TOYTECH REAR SHOCKS TOYTECH 1.75 SHACKLES
    Finally got my RCI Rock sliders on!! Super excited.
    GAknight, D4x4TRD, Jbehredt and 15 others like this.
  25. Oct 17, 2021 at 2:57 PM
    NorthShore
    Thanks for the tip. Once I knew what I was looking for it popped off in 10 secs. I did pretty much same approach you describe on cup holder/silver trim yesterday. Will post pic of shift gate once dry and installed. Cheers!
    1794TX[QUOTED] likes this.
  26. Oct 17, 2021 at 3:36 PM
    jclem65
    jclem65 New Member
    james
    2019 cement tundra crewmax sr5 trd off road
    interior led's,fortin remote-start with i linker
    i would like to do this as well..... when you get a chance can you fill me in on the specifics.
    Toe404[QUOTED] likes this.
  27. Oct 17, 2021 at 3:57 PM
    boostedtrdpro
    boostedtrdpro voided warranty
    Jeremy
    2024 GMC Sierra 2500HD AT4X 2020 Sequoia TRD Pro 040
    Reinstalled my skid this morning after getting the suspension all buttoned up and aligned. Fitted a 35” spare under the truck after some surgery with an angle grinder to the spare tire guides. Clears the shackles by about 3/16” on each side and about 2” from the dual exhausts.
  28. Oct 17, 2021 at 4:25 PM
    Yzed608
    Yzed608 New Member
    Wisconsin
    Nice! As @Toe404 said you don't need to do anything to the gate.
    On the ReadyRamp itself, my dad has used one on his 2005 Tundra since new, and it's been awesome. We do run a couple tie downs from the chain loops on the hitch to about the middle of the ramp on one of the rungs and snug it, just do make sure the ramp won't pop up or move when the bike is on it. Then once the ramp is in the 'bed extender' form, you can take the tie downs and run them up and over the bottom to keep it from bouncing around at all. The straps they give you don't work too bad though. Not a great photo but you can get the idea.
  29. Oct 17, 2021 at 5:03 PM
    romad86
    romad86 New Member
    Warrenton, VA
    2021 Limited Cement
    I’ve been eyeing one of these. Heard nothing but good things. Looks good!
    MooseTundra[QUOTED] likes this.
  30. Oct 17, 2021 at 5:18 PM
    junior
    junior Member
    Zach
    Santa Cruz, CA
    2016 Tundra TRD Off Road
    Black Rhino Rapid 17" 35x12.5 Mickey Thompson Baja Boss Fox Performance Elite 2.5 DSC at 3" with Coachbuilder 1/4" shim on driver side JBA UCAs Fox Performance Elite 2.5 DSC rear shocks Dobinsons HD Leaf Springs Firestone Airbags + Daystar Cradles Prinsu Cab Rack 2024 Four Wheel Camper Project M Camper Mods: Goal Zero Yeti 4000 house battery 200w solar IceCo fridge Truma Propane Heater
    Was gonna be attempting this with CB shackles soon. Thanks for sharing, glad to see it does work!
    1794TX and boostedtrdpro[QUOTED] like this.
