Upper control arms ICON..
Discussion in 'Wheels & Tires' started by Tundrapwr16, Oct 15, 2021.
  1. Oct 15, 2021 at 3:54 PM
    Tundrapwr16
    Tundrapwr16 [OP] Best Toyota made ever
    Rob
    California
    2000 RC 3.4 liter white work truck .
    Pioneer radio and intermittent wiper switch and led lights. I also use AMZOIL Products only..
    Hey guys, have a set of Icon coil overs on my tundra. I have the BBS TRD wheels on and I just installed some 295/70/18s on them. Tires clear entire wheel wells. I adjusted up my ICONS about 1inch turning collet down. The tire guy said when wheels turn the upper control arm hits the tires. Any suggestions,? TOTAL CHAOS makes a great set of uppers. Can I just use a small spacer to pull wheel away a 1/2 inch ?? Temp fix. Or is it not good to do that?
  2. Oct 15, 2021 at 3:57 PM
    equin
    equin Texarican Tundra
    Ed
    DFW, TX
    Yes, a lot of folks add wheel spacers to their stock wheels, partly for that reason. Just make sure you get good quality, reputable wheel spacers.
    TucsonTundra1794 likes this.
  3. Oct 15, 2021 at 4:35 PM
    Tundrapwr16
    Rob
    California
    Are they safe ? And. What brand of spacers shall I buy? And. Where do I order them through? Summit ?
  4. Oct 16, 2021 at 12:12 PM
    equin
    Ed
    DFW, TX
    I have no experience with wheel spacers. I’ve read on here from others that do run them that they’re safe. I don’t remember which brands are the best, though. Hopefully the wheel spacer experts will chime in.
  5. Oct 16, 2021 at 1:08 PM
    Tundrapwr16
    Rob
    California
    Perfecto I would very much like to hear from them please.
  6. Oct 16, 2021 at 2:55 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    No you can’t use a 1/2” wheel spacer. The studs will protrude through the spacer and hit the wheel. 1” is minimum if you have dimples in your wheels.
