Missing MAF
Discussion in '1st Gen Tundras (2000-2006)' started by Splashbrother13, Oct 13, 2021.
  1. Oct 13, 2021 at 3:58 PM
    Splashbrother13
    Splashbrother13 [OP] New Member
    Aaron
    AZ native
    2000 SR5 Tundra
    Just swapped all 4 of my O-2 sensors and the check engine code tells me MAF. I lift the hood to see what’s up and the plug-in is nowhere to be found. Have no idea how this could’ve happened as I only recently started working on the truck myself. Wtf.
    On the hunt for a replacement
    Darkness likes this.
  2. Oct 13, 2021 at 4:14 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    See that box on the intake tube? Between the accordian section and the throttle body. Check under that. Thats where mine comes from.
    Splashbrother13[OP] likes this.
  3. Oct 13, 2021 at 5:15 PM
    Whatever you do, don't buy an aftermarket replacement, and don't buy it on A-Zon or fleabay. (counterfeit risk is too damn high)
    You may find just cleaning it with MAF cleaner will clear stuff up. May be worth a shot.
  4. Oct 14, 2021 at 12:52 PM
    He has a MAF. Got nothing to plug into it......
  5. Oct 14, 2021 at 12:55 PM
    Taco-Spike
    Two Trucks
  6. Oct 14, 2021 at 12:56 PM
    Again, not missing the actual sensor, missing the plug in harness for the sensor I believe.
  7. Oct 14, 2021 at 12:57 PM
    That MAF looks suspiciously shiny btw. Recently replaced?
  8. Oct 14, 2021 at 12:58 PM
    Taco-Spike
    Two Trucks
    Gotcha, I see now
  9. Oct 14, 2021 at 6:02 PM
    Splashbrother13
    Aaron
    AZ native
    2000 SR5 Tundra
    Ordered a new one before I popped the hood thinking it was simply the actual sensor that needed a swap. When I believe my issue is the missing plug-in, that I have yet to find tucked away anywhere.
  10. Oct 14, 2021 at 6:06 PM
    2mchfun
    Rodent ate it?
  11. Oct 14, 2021 at 6:38 PM
    Splashbrother13
    Aaron
    AZ native
    2000 SR5 Tundra
    Pls lmk if anyone has a trusted Toyota OEM parts site, or what to call the plug in cable in the search bar
  12. Oct 14, 2021 at 6:40 PM
    2mchfun
    Sparks parts
  13. Oct 14, 2021 at 6:45 PM
    Summit Racing is the fastest at a good price, with great service.
    But honestly, if you have a dealership near you, go to https://parts.toyota.com, plug in your VIN into the Search, then search for MAF. You can order, buy, and pick it up at your local dealership.
  14. Oct 14, 2021 at 7:17 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Hopefully it didn't get pulled into that serpentine belt and ripped out while driving. If its there you should be able to find it. Maybe pull the intake tube and see if it's under there.
    shifty` likes this.
  15. Oct 14, 2021 at 8:34 PM
    It's either hiding under the throttle body cover or that's for something else.
  16. Oct 14, 2021 at 9:22 PM
    NickB_01TRD
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    These are from pictures I already had so not perfect. Looks like the harness goes down into another loom.
  17. Oct 15, 2021 at 11:10 AM
    tvpierce
    tvpierce Formerly New Member
    Maine
    It branches off this loom in your pic. The junction should be right where the X is under the air intake.
