Oil change gone wrong… Drain bolt spun on
Discussion in '2.5 Gen Tundras (2014-2021)' started by newemi, Oct 10, 2021.
  1. Oct 11, 2021 at 8:52 AM
    2mchfun
    I dunno, I heard of 3 welded nuts breaking off this week alone. Granted all were not oil pans. Welding done right should be stronger than the material around it. Just my 2 cents.
  2. Oct 11, 2021 at 8:58 AM
    C.I.
    C.I. Surf, off road, sleep, repeat
    Cesar Pedrin
    Cabo, Mx
    2016 5.7 4x4 Bronze Crewmax
    Mods: Ongoing... probably never ending
    F133, N variant has a long nipple, S variant has a short nipple.
    Good luck brother.
  3. Oct 11, 2021 at 9:53 AM
    Nueces
    Nueces New Member
    Texas Hill Country
    2002 Tundra SR5 AC
    Have not read this whole thread. I lost a Jeep TJ oil pan the same way. Oil change guy had been air wrenching the plug and broke loose the bung, which was simply pinch folded in place. We put in a new pan.
    NewImprovedRon likes this.
  4. Oct 11, 2021 at 10:44 AM
    huntertn
    huntertn New Member
    Tennessee
    2008 White CrewMax Limited 4x4
    Sorry, I should have explained that in my post. It comes in a tube like rtv (silicon sealant). I used the Toyota stuff but some people use other brands or just plain Permatex silicon.
    Just make sure it is clean and you get all the oil residue off. I installed an F133s when I put the new pan on and have been happy with it.
    I hope the dealership will help out on the cost but I would not hold my breath that they will cover it all. Which is unfortunate.
  5. Oct 11, 2021 at 10:53 AM
    crewmaxlmt
    crewmaxlmt How dare you!
    scott
    2020 Crewmax Limited
    If you encounter an issue with Toyota not wanting to cover this, have the threads tack welded to the pan so that they can verify that you did not over torque the drain valve. The threaded insert should be able to take much more than the recommended torque value being that this is a maintenance item.
  6. Oct 11, 2021 at 11:11 AM
    newemi
    newemi [OP] New Member
    2020 Tundra CM Ltd CB
    11am oil pan is off now.
    looks like the bung nut is cracked. Got my fumoto valve out and now I’m confused as my regular drain bolt tightens up correctly despite the crack. The fumoto valve threads are definitely stripped
    8CA234D1-1DF4-40E9-963E-48FCF1B075DC.jpg 3928E750-1372-4B57-8438-C4A2FF0B9E22.jpg
  7. Oct 11, 2021 at 11:14 AM
    Cock-A-Doddle-Do
    Cock-A-Doddle-Do New Member
    Brett
    Cypress, Texas
    2021 TRD Off Road CM -Super White
    Perhaps you cross threaded the Fumoto valve?
  8. Oct 11, 2021 at 11:16 AM
    crewmaxlmt
    scott
    The bung cracked which then allowed it to open up slightly when torquing your Fumoto valve down. Since the Fumoto valve is brass, the steel bung took the majority of the brass threads off.
  9. Oct 11, 2021 at 11:17 AM
    As inconvenient as it is, this is why I've always done my own oil changes twice a year even if it 40 degrees outside. Hope it all works out for you.
  10. Oct 11, 2021 at 11:29 AM
    C.I.
    Cesar Pedrin
    Cabo, Mx
    lol! wrong quote!
  11. Oct 11, 2021 at 11:36 AM
    Rodtheviking
    Rodtheviking New Member
    Vancouver, WA
    Sequoia
  12. Oct 11, 2021 at 11:50 AM
    Oey12
    Oey12 New Member
    Joey
    New York
    2020 SR5 TRD OFFROAD
    That sucks OP! Hope it works out for you. I had a similar issue when installing one in my old 2017 4RUNNER. Luckily in my case the minute I head an odd crack noise I stopped and was able to slowly back it out with some pliers.
  13. Oct 11, 2021 at 12:58 PM
    Northbound Train
    Northbound Train Masshole
    Glenn
    Western MA
    Black 2016 SR5 Double Cab 4x4 5.7
    If the truck were towed to them with the brass valve spinning in the bung, I think you would of had a case that something brass and hollow on the inside would not have broken that. But who knows, they might of tried to get out of paying even if they thought so too.
    I had this happen too on the red car in my avatar. Unfortunately there is no clearance to remove the pan with the engine in place so it was a project to repair it.
    Good luck with getting it fixed!
  14. Oct 11, 2021 at 1:16 PM
    newemi
    F65A85B2-E059-4E98-93B5-5F092FF7A0F3.jpg Update, the dealer I went to, service manager wouldn’t touch it with a 10ft pole. Picked up my part and the liquid gasket. $280
    so to my surprise there is a notch in the threads. See photo. So it’s possible that their is not a crack in it, though threads still look damaged. Regardless crappy results no matter what.
    georgiey22 and boostedtrdpro like this.
  15. Oct 11, 2021 at 1:21 PM
    Mad Max
    Mad Max New Member
    Max
    2021 Tundra Limited
    notch is there to allow additional oil to drain? Sounds like you may have used the wrong threaded valve also. I would double check your part numbers
    RitcheyRch, 2mchfun, 15whtrd and 3 others like this.
  16. Oct 11, 2021 at 1:25 PM
    newemi
    I don’t thinks so, I’m sure some super smart engineer put it there for some reason. There was still almost a quart of oil in the pan when I dropped it… which almost entirely ended up on me. Lol
  17. Oct 11, 2021 at 1:32 PM
    crewmaxlmt
    scott
    If your pan bung is not cracked, I second that they sent you the wrong valve.
    When you get a new Fumoto valve I would compare the threads major OD and thread pitch with the OEM plug. The simplest way to verify the thread pitch is to lay both threads together. The 60° thread forms should fit exactly with each other. For the major OD, calipers would be best but a scale or tape measure would be good enough.
    RitcheyRch and Drainbung like this.
  18. Oct 11, 2021 at 1:32 PM
    LuvCRVs
    LuvCRVs New Member
    San Antonio
    2021 TRD Sport
    Hard Tri-Fold Tonneau Cover, OEM Bed Mat, OEM All Weather Floor Mats
    Given the original drain plug came out without any reported issues or visual concerns and the bung nut is still attached, sounds more like a DIYer issue than a Toyota issue. Sorry this happened.
    Cock-A-Doddle-Do likes this.
  19. Oct 11, 2021 at 1:58 PM
    Rodtheviking
    Vancouver, WA
    Sequoia
    Wrong valve?
    2mchfun and 15whtrd like this.
  20. Oct 11, 2021 at 2:08 PM
    #50
    TundraTed
    TundraTed New Member
    2020 SR5 TRD Sport Crewmax 4x4
    In order: Orvis dog cover for rear bench seat, OE gun safe, Husky liners front/rear, Tyger tonneau tri fold, Rough Country seat covers
    I checked my Fumoto order on Amazon and, as Rodtheviking noted, I’m showing a B27 valve. The very last bullet is kinda funny although I know too soon....
  21. Oct 11, 2021 at 2:15 PM
    #51
    Rodtheviking
    Vancouver, WA
    Sequoia
    Picture you posted has B28, from what I can see.
    RitcheyRch and 50Shades like this.
  22. Oct 11, 2021 at 2:28 PM
    #52
    glowblue
    glowblue From time to time
    VA
    This would be my guess since the collar of the nut would leave some oil still in the pan when draining. Something seems off with the Fumoto, either wrong part or a manufacturing defect.
    2mchfun likes this.
  23. Oct 11, 2021 at 2:39 PM
    #53
    50Shades
    50Shades Sin City Tundras
    J
    West Coast
    2021 Tundra SR5 CrewMax Trail Edition 4x4
    just stick to the original drain plug lol. fumoto is nice and convenient and you save 30 seconds but that's it. if you're trying to do an oil change on a fleet of tundra's, sure use fumoto. but it's just DIY why the rush? that's just my thinking.
  24. Oct 11, 2021 at 2:44 PM
    #54
    Cock-A-Doddle-Do
    Brett
    Cypress, Texas
    ^^THIS^^
  25. Oct 11, 2021 at 2:45 PM
    #55
    18" TRD Off Road Wheels
    It's for the cleanliness not the speed. I can pop a hose on the valve and drain it with no spills or mess. The oil change when I installed the valve wound up spilling oil on top of my RCI skid because once the flow slowed down it ran down the curve of the pan and dribbled all over the skid.
  26. Oct 11, 2021 at 2:47 PM
    #56
    glowblue
    VA
    This was my exact experience prior to installing the Fumoto.
  27. Oct 11, 2021 at 2:49 PM
    #57
    huntertn
    huntertn New Member
    Tennessee
    The pan on my 08 had the notch too. I figured it was to let more of the oil the oil drain.
    Are the threads in the original pan still good? Also, when I put my Fumoto valve in I noticed that the torque is different. I started to torque it to the original Toyota spec and it seemed like it was going to be too much… so then I read the directions that came with the valve. I don’t remember exactly what it said but it was something like a 1/4 turn with a wrench after hand tight.
    Here is my pan with the same notch.
    NewImprovedRon and Drainbung like this.
  28. Oct 11, 2021 at 2:52 PM
    #58
    Phantom Lord
    Phantom Lord New Member
    Byron
    2017 MGM CM Limited
  29. Oct 11, 2021 at 2:58 PM
    #59
    Cock-A-Doddle-Do
    Brett
    Cypress, Texas
    1/4 turn past hand tight or 18flb
  30. Oct 11, 2021 at 2:58 PM
    #60
    Yeah, I was not happy. Couple that with the oil down the arm popping the plastic nozzle into the filter housing, and I am way happy with the Fumoto valve and Jowett housing.
