2022 Tundra
Discussion in '3rd Gen Tundras (2022+)' started by 0.S.T., Apr 6, 2020.
Who has actually used the front tow hooks?
  1. Never
    204 vote(s)
    52.6%
  2. 1-5 times
    111 vote(s)
    28.6%
  3. More than 5 times
    45 vote(s)
    11.6%
  4. Almost daily
    7 vote(s)
    1.8%
  5. I'm an off-roader and definitely need it.
    28 vote(s)
    7.2%
  6. I mall crawl
    17 vote(s)
    4.4%
Multiple votes are allowed.
Thread Status:
Not open for further replies.
  1. Oct 9, 2021 at 8:43 AM
    JuicyJ
    JuicyJ New Member
    Nope.
    JL Clean Sweep and the RF version use predictive processing to negate/offset equalization effects that are common on most OEM stereos.
    The stereo making engine noises is variable and unpredictable, and basically the same as music sounds, so those units can not offset the engine sound.
    The HU will likely have a engine sound disable, at least I really hope so! Or at least through TechStream?!?
    This is one area that Nissan does better than most manufacturers, the HU in most Nissan/Infiniti with remote amps sends clean signals to the amps, the EQ is inside the amp. I can hook up aftermarket speakers and amps to most Nissan/Infiniti products without any post-processing re-processing.
  2. Oct 9, 2021 at 8:45 AM
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    Rest assured, that turn signal will continue to be ignored in every major city in the country.
  3. Oct 9, 2021 at 8:49 AM
    JuicyJ
    JuicyJ New Member
    I can get my Titan (every bit a gas guzzler as the Gen 2 Tundra) to show 26 MPG for a few miles. Just need to trick the truck a bit. I always see people doing that when they say their truck is getting "OK" mileage, look around their cluster and you'll see they recently reset it and didn't drive far.
    However, I would say that the what you are seeing on these newer Tundras in these videos is accurate. These trucks are being flogged, then idled in warm temps (every reviewer comments on how hot TX is for this time of year) and they are still showing better MPGs than what our V8 trucks typically get. I also noticed that the cluster display is the same as our new Toyota Corolla, and that thing is accurate to about 0.3 MPG, it doesn't seem to "play games" like I can get older displays to do. It's pretty accurate.
    Cpl_Punishment likes this.
  4. Oct 9, 2021 at 10:33 AM
    Tundratic
    Tundratic New (ish) member
    Canada
    2010 SR5 TRD OR 2023 Limited TRD OR
  5. Oct 9, 2021 at 10:43 AM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    My least favourite feature on any vehicle but I always drive with my lights on anyway.
    sleepybear723 and Pbed85 like this.
  6. Oct 9, 2021 at 11:16 AM
    locoj
    locoj New Member
    Is that George?? I had no idea he did reviews on vehicles too lol. We're all George!
  7. Oct 9, 2021 at 11:32 AM
    19crewmaxTRD
    19crewmaxTRD Tundra Enthusiast
    Seth
    2019 white tundra crewmax
    Yes It will significantly.
  8. Oct 9, 2021 at 11:35 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Is that orange radiator in front a trans cooler…?
  9. Oct 9, 2021 at 11:41 AM
    bsktball55
    bsktball55 New Member
    Missouri
    16 Tundra TRD Pro
    Bakflip MX4 Toneau cover Esp storage Audio system (Helix speakers, JL audio amp and sub) Front windows and windshield tinted LED interior and bed lights
    No the orange radiator is a cooler for the hybrid system which is why it's orange.
    Tundra'25, deptrai and sleepybear723 like this.
  10. Oct 9, 2021 at 11:52 AM
    Hammerdog
    Hammerdog YCMTSUP
    Robbie
    Louisa VA
    2018 tundra sport crew max
    Tint Bed cover Red Tow Hooks TRD Intake 7 inch BDS 22x12’s 35 Toyo’s Rigid ditch lights RC light bar in bottom grille One bad ass stereo
    So do I.
  11. Oct 9, 2021 at 12:08 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    ah! Neato
    sleepybear723 likes this.
  12. Oct 9, 2021 at 12:35 PM
    Cock-A-Doddle-Do
    Cock-A-Doddle-Do New Member
    Brett
    Cypress, Texas
    2021 TRD Off Road CM -Super White
    ^^THIS^^
    Tundra'25 and Dilleytech like this.
  13. Oct 9, 2021 at 1:26 PM
    sleepybear723
    sleepybear723 New Member
    "It might". You can't say one way or another as you have zero evidence besides your feelings. In fact, Toyota increased the towing capacity.
  14. Oct 9, 2021 at 1:35 PM
    sone
    sone New Member
    OK so that video answered my own question... Toyota did move their Catalytic Converter closer to the header so it makes it harder to steal. Good job Toyota!
    Tundrastruck91 and sleepybear723 like this.
  15. Oct 9, 2021 at 1:43 PM
    19crewmaxTRD
    Seth
    The laws of physics don’t change. A 12klb trailer will move a 5klb truck more than a 6klb truck. Just because they increased the tow rating doesn’t mean they made a better towing platform. I assume the new tundra will handle 12klbs just fine in normal road conditions, but it would do it better if I weighed more.
    Cpl_Punishment and Dilleytech like this.
  16. Oct 9, 2021 at 1:55 PM
    belanger9
    belanger9 New Member
    Edmonton, AB
    2016 TRD Off Road Inferno
    A bunch
    The longer wheelbase of the 6.5' CM (over the CM and DC 6.5') will help with towing to help counteract the loss of weight. And IIRC they're moving up to 285 tires from 275 so more contact patch will again help counteract the lower weight. These little things along with how the weight transfers through the frame to the tires could allow the new Tundra at 11k lbs to be as confidence inspiring as the current Tundra at 9k lbs
  17. Oct 9, 2021 at 2:14 PM
    RavingOx
    RavingOx Member
    WNC
    2022 Tundra Platinum in Black
    Better start eating…
  18. Oct 9, 2021 at 2:18 PM
    Badknees
    Badknees New Member
    2016 White Tundra 1794 CM 4X4
    TRD Pro BBS Wheels, TRD LED Headlights, Rigid LED Fog lights, 040 TRD Grille, 040 Hood Bulge, Black Center Valence, Driver's Grab Handle, TRD Pro Fox Suspension, 1.00" BORA Wheel Spacers, 1.5" Rear Shackles, TRD Front and Rear Sway bars, 295/70 R18 Cooper Discoverer AT3 XLTs, Full Size Spare, TRD Dual Exhaust, Console cover, Console Organizer, Husky Liner X-act Contours, Tinted Front Windows, Stubby Antenna, Autoventshade Deflectors, Duplicolor Painted Calipers, 040 Painted Front End Caps, Undercover Armor Flex Bed Cover
    Turn signals? Drivers have to stop texting and actually push the lever to make them work first. :D
    Pipo6007, Oey12 and Cpl_Punishment like this.
  19. Oct 9, 2021 at 2:19 PM
    JuicyJ
    JuicyJ New Member
    Wrong.
    The pre-cat is close to the header, but there's still 2 post-cats right there, full of precious metals. Almost every vehicle out there with pre-cats and post-cats only get their post-cats stolen.
    Toyota didn't do squat about it. Not that they should. Maybe people should stop being scumbags?
    JJtruckon likes this.
  20. Oct 9, 2021 at 2:41 PM
    RavingOx
    RavingOx Member
    WNC
    How am I supposed to do this while I’m holding my phone in one hand and my Starbucks in the other while driving with my knee?
  21. Oct 9, 2021 at 2:41 PM
    19crewmaxTRD
    Seth
    Do we know how much they increased the wheelbase? I tried to find the spec and couldn’t, it will definitely help. 275 vs 285 contact patch change isn’t a big enough change to make a significant difference. Maybe if they went up a load range but I doubt they did that.
  22. Oct 9, 2021 at 2:42 PM
    bsktball55
    Missouri
    16 Tundra TRD Pro
    But not too much... because you know, payload.
  23. Oct 9, 2021 at 2:45 PM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    I thought I read that the CM short bed wheelbase is 2-3 inches longer than the current gen. The CM standard wheelbase should be about a foot longer than that.
    belanger9 likes this.
  24. Oct 9, 2021 at 3:02 PM
    matthinkle
    matthinkle New Member
    Lighthouse Point, FL
    2022 1794 Hybrid
    “hey Toyota, turn on left blinker…”
  25. Oct 9, 2021 at 3:05 PM
    Badknees
    Badknees New Member
    Guess it’s time for an auto-driving Tundra?
    Wait. Use the Starbucks cup…
  26. Oct 9, 2021 at 3:17 PM
    stecky
    stecky Tech Geek
    Dallas, TX
    2021 Nightshade CM MGM
    Actually, I'm hoping the 2022 will support this
    TK1979 and Badknees[QUOTED] like this.
  27. Oct 9, 2021 at 3:24 PM
    Badknees
    Badknees New Member
    Too many things can go wrong while driving and no way auto mfrs. can plan for every eventuality. It will take a long time for me to ever trust this technology.
    But I learned somewhere on this thread that I’m a crusty old man, so I’m good with it!
  28. Oct 9, 2021 at 3:26 PM
    stecky
    stecky Tech Geek
    Dallas, TX
    It's the one thing my wife misses most since we bought our Tundra. I've spoiled her... lol
    Badknees[QUOTED] likes this.
  29. Oct 9, 2021 at 4:02 PM
    locoj
    locoj New Member
    Hey guys so according to Toyota TRD Pro model wont be available until March while SR, SR5, Limited will be available December this year? Or do I have this wrong?
    Boerseun and Tundra'25 like this.
  30. Oct 9, 2021 at 4:07 PM
    RavingOx
    RavingOx Member
    WNC
    The TRD Pro will only have the hybrid engine which won’t be available at launch.
Thread Status:
