2014 Spare Tire Lock Removal
Discussion in 'Wheels & Tires' started by Nobody Special, Oct 9, 2021.
  1. Oct 9, 2021 at 10:10 AM
    Nobody Special
    Nobody Special [OP] New Member
    I am trying to remove this worthless spare tire lock to go back to the standard connection. Has anyone removed one of these? I see no pins or hardware to disconnect. Thanks.
  2. Oct 9, 2021 at 10:23 AM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
  3. Oct 9, 2021 at 10:33 AM
    Nobody Special
    That would only lower the spare. It would not remove this part. I want to remove this altogether and not have a special key.
  4. Oct 9, 2021 at 10:44 AM
    Nobody Special
    See attached. Let me know if anyone can help. Thanks.
  5. Oct 9, 2021 at 10:48 AM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Did you look at the install guide I linked? Looks like the lock is just pressed into the standard fitting, so get under and see if you can pry it out. I think you have to buy the whole hoist assembly, not just that one piece, to replace the tire mount bracket.
  6. Oct 9, 2021 at 11:09 AM
    Nobody Special
    First question is resolved. I fiddle farted around with it and it just fell out of the holder. I don't know what was holding it in place to begin with.
    However, since I ground out the lower piece to remove the tire, I still need to replace that part. Anyone know where I can find it or what I can use in place of it?
  7. Oct 9, 2021 at 6:28 PM
    thearborbarber
    thearborbarber New Member
    SoDak
    2018 Tundra SR5
    Stick a nut on the end and weld it on?
  8. Oct 10, 2021 at 5:06 AM
    mnm
    mnm Old Guy...
    Mark
    Smithfield, VA
    2008 Tundra Limited 4x4 DC
    I managed to drive the pin out of the ass'y though the spare tire was still mounted. It was a complete pain in the a$$ but it worked. I bought truck used and it didn't have a key. I found out just by accident crawling around under the truck one day. Glad I found out before I was on the side of the road needing to change a tire.
