Rear window wiper blade?
Discussion in '2nd Gen Tundras (2007-2013)' started by MXPCUS, Oct 8, 2021.
  1. Oct 8, 2021 at 6:09 AM
    MXPCUS
    MXPCUS [OP] New Member
    Ken
    Southern IL
    2007 Tundra SR5
    Push bar and bed rails
    Has anyone seen any mods where I can add a rear window wiper blade? Using a squeegee on it before I go it's about all I can do. Do I just use Rain-X when it's raining because I can't think of any other way to keep water off of it
  2. Oct 8, 2021 at 6:16 AM
    TheBlackPearl
    TheBlackPearl Newish member
    La Gulf Coast
    2020 Black TSS Crewmax 4x4
    This is the most unique question I think I’ve ever seen on here.
  3. Oct 8, 2021 at 8:05 AM
    Taco-Spike
    Two Trucks
    I mean theoretically you could.
    Mount a wiper actuator module to the front of the bed, space it in tolerance, supply power and a switch. Not sure about speed variable settings (fast / slow)
  4. Oct 8, 2021 at 11:59 AM
    NueveTundra
    NueveTundra Mod list in Bio
    Planet Earth
    07, Black Tundra SR5 CrewMax
    Exterior: Toytec ultimate 3" lift level, Total Chaos Uniball UCA's, Total Chaos Cam Tab Gusset kit, AcanII smoked headlights, AcanII smoke Tail lights (2.5 gen style), DV8 front winch bumper , Badlands 12k winch with Apex Synthetic, White AUTMATCH Shackles 3/4" D Ring Shackle, Apex Winch shackle, Trail Ridge mirrors ,Icon Rebound Pro 17"x8.5" +25, Cooper Discovery STT Pro 285/70R17, PowerStop drilled n slotted rotors W/Carbon pads, Rigid flood flush mounts rear bumper , WeatherTec rain guards , OEM black side badges , Rigid Amber Radiance Pods. Energy Suspension Red Rack and Pinion Bushings, EAG front mesh Grille, RCI HighLift bed mounts. Rough Country DS2 Steps, A.R.E OverLand Canopy with Ascend basket, Stickers: ToyTec lifts windshield banner, Red Strange Music window sticker(back cab), White Strange Music sticker(back canopy), White Rigid sticker x2 (canopy sides), white Official BigFoot Research Team (Back Canopy) Interior: Alpine double din touch iLX-650 , JL C5-653's (front) JL C1-650x (rear) , JL JX400 4 channel amp , JL JX500 mono amp , 2 JL 12" subs , WeatherTec floor mats, Kenwood F/R Dash Cams, Black steering wheel emblem overlay, Tekonsha P3 Brake controller, ToyTec "Fresh" Scent coilover air freshener, Under the Hood: Koyo all aluminum radiator, Mishimoto red silicon hoses , XS Power 3000 amp battery , LAlectric 300 amp Alternator , K&N replacement filter. Online LED store accessories Fuse/relay box. (Identified) Dirty Deeds 8" Cat back exhaust with DD resonator delete/axel over converted into dump. Coming soon:
    Are we talking the back cab window or canopy window?
    Does your Tundra have defrost option?
    TheBlackPearl likes this.
  5. Oct 8, 2021 at 12:01 PM
    Fotnot
    Fotnot SSEM #69; LRCS#1
    Andy
    SW Louisiana
    Swimmers gonna swim
    just rain-x or ceramic coat it and you'll be done
  6. Oct 8, 2021 at 12:38 PM
    Blue Thunder
    Washington
    Put something like Rain-X on it. I use the stuff from Griot’s garage. It helps keep the window cleaner as well
  7. Oct 8, 2021 at 5:44 PM
    Danny3737
    Danny3737 New Member
    2012 Tundra Limited Platinum
    I use Aquapel, it lasts for about a year
  8. Oct 8, 2021 at 5:57 PM
    camron1039
    camron1039 New Member
    Camron
    2021 Tundra Platinum
    Rain x works perfect for me. I reapply each time it rains normally but it’s not necessary.
  9. Oct 8, 2021 at 6:28 PM
    This works well too.
    camron1039 likes this.
  10. Dec 15, 2021 at 1:04 PM
    TacomaLC
    TacomaLC New Member
    Chip
    T-town
    2020 Tundra Voodoo 2020 SequoiaTRD 2000 Tundra LTD (RIP)
    AquaPel works as good (if not better than RainEx) and lasts a lot, lot longer. Easily 5 to 10 times longer in my experience. Only get a month or two out of RainEx. AquaPel effects have lasted a year or two for me. Apply once on the side/rear windows and you’re golden for a year or two. I’m in the rainy PNW too.
    FWIW: AquaPel effects work noticeably better when applied to a clean, dry windshield and with ambient temperatures in the range of 60-75 degrees. Too hot it’s hard to apply easily, too cold it doesn’t seem to work right (doesn’t bond as well maybe?). I’ve done both.
  11. Dec 15, 2021 at 4:06 PM
    Danny3737
    I thought I was the only one using Aquapel. I use it on all my cars and I can easily get 6 months or more on each application. My expensive wipers last much longer too. I agree with the application. You need to make sure you put it in and take it off quickly. Quality paper and microfiber towels are a must.
    TacomaLC[QUOTED] likes this.
  12. Dec 15, 2021 at 4:11 PM
    VTYOTER
    VTYOTER Rock
    Torrey
    Vermont
    2021 TRD Pro LR
    35" KO2, METHOD 701, WESTCOTT COLLAR, CB+3, BUMPER SHIMS, CALIRAISED ROCK SLIDERS STEP EDITION, DIAMONDBACK HD
    Just roll the window down, crystal clear view right out the back :rofl:
