Oops, I did it Again. I'm 2 for 2...
Discussion in '1st Gen Tundras (2000-2006)' started by Truckin' Girl 1117, Oct 4, 2021.
  1. Oct 4, 2021 at 8:52 AM
    Truckin' Girl 1117
    Truckin' Girl 1117 [OP] Custom
    Christine
    Grafton
    2003 Black Tundra Xtracab
    Hi every one!
    After hand splitting a half face cord of oak for the wood stove, (because the girl does need stay warm on those chilly nights), I guess I was a little tired and my softball pitch tossing the split wood in the bed of the truck was a little sloppy, and yup, you guessed it... the girl not only took out the right rear window, but the center one as well. Damn, I'd call that a 2 fer if I ever saw it. I mean what's the chances of that happening? The old "two birds with one stone" thing. So after finding out from the friendly Toyota dealer that the rear window assembly was going to be $1800.00+, (ouch), I quickly decided to take things into my own hands.
    So here is the dilemma, I taped up the right side, (I think I'm on my 4th layer of assorted duct tape), and I replaced the center window with a piece of plexi which is fine. So the question is, has anyone been able to replace one of those widows with success? I did find a guy on the internet that sells slightly smaller windows that you glue over the broken edge, but I don't know, that doesn't sound like the greatest solution. Any thoughts?IMG_1134.jpg
  2. Oct 4, 2021 at 8:53 AM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    2000 Tundra 4x4 "$1100 Build"
    Check with a glass company, like safelight or a local shop. They should be able to repair if for much cheaper.
  3. Oct 4, 2021 at 9:07 AM
    There was a post on here about the same thing a few months back as well i recall. I'd like to say that person found a used replacement but I can't remember.
    BubbaW likes this.
  4. Oct 4, 2021 at 9:10 AM
  5. Oct 4, 2021 at 9:12 AM
    Patch999, Black Wolf and Darkness like this.
  6. Oct 4, 2021 at 9:13 AM
  7. Oct 4, 2021 at 9:14 AM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
  8. Oct 4, 2021 at 9:25 AM
    2mchfun
    Damn that buys a whole bunch of firewood split and delivered. Precisely one of the few reaons my truck received a headache rack. The thought of buying that high dollar rear power window. Yikes! Anyway, wish you better days ahead!!
  9. Oct 4, 2021 at 9:27 AM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
  10. Oct 4, 2021 at 10:09 AM
    N84434
    N84434 In the Frozen Tundra
    Milwaukee WI.
    2001 Limited TRD
  11. Oct 4, 2021 at 10:37 AM
    dbittle
    dbittle Middle Age Member
    Huntsville AL
    2006 V8 RCLB 2WD
    This^. Or see what your local glass company wants for a new one. You are probably looking at around $300 or so to get the glass replaced either way. On the wood splitting accident, I almost did the same thing a couple of months ago. The log bounced off the ones already in the truck and hit the back glass. Didn't break it though, so I was lucky that time.
  12. Oct 4, 2021 at 10:44 AM
    Teutonics
    Teutonics BestGen Member
    2005 DC SR5 4WD
    And all this time I thought I was the only one that did that type of thing.... :-/
  13. Oct 4, 2021 at 11:14 AM
    Truckin' Girl 1117
    Christine
    Grafton
    Thanks everyone for the support! I'll check out these leads and see if anything sticks.
    2mchfun likes this.
  14. Oct 4, 2021 at 12:08 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
  15. Oct 4, 2021 at 12:22 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    When I brought base molding, I open the window and slide it inside the cab cause I got a cover without a rack.
  16. Oct 4, 2021 at 12:25 PM
    Truckin' Girl 1117
    Christine
    Grafton
    I just fabricated one out of Plexiglas (from Home Depot) and installed it with some silicon caulk. Honestly it works just fine.
    w666 likes this.
  17. Oct 4, 2021 at 12:39 PM
    Truckin' Girl 1117
    Christine
    Grafton
    yup I found that. He somehow found one in a junkyard and had it installed for $300. I'm never that lucky...
  18. Oct 4, 2021 at 12:48 PM
    dbittle
    Huntsville AL
    2006 V8 RCLB 2WD
  19. Oct 4, 2021 at 1:16 PM
    Truckin' Girl 1117
    Christine
    Grafton
    I asked for a quote, and if they can install it. If so that would be a sweet deal...
    dbittle likes this.
  20. Oct 6, 2021 at 8:34 AM
    Truckin' Girl 1117
    Christine
    Grafton
    Hello I did locate a untinted window at a junkyard for $100. But it is from a 2001, and I have a 2003. Do you guys think it will fit? Thank you!
  21. Oct 6, 2021 at 8:40 AM
    It will fit. They are bolted in by the frame. They also use some sealer around the edges. The factory one is the way to go, the aftermarkets don't fit or behave as well.
  22. Oct 6, 2021 at 8:41 AM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    From 00-06 should be the same
  23. Oct 6, 2021 at 9:33 AM
    EvilMilkshake
    EvilMilkshake New Member
    05 AC Limited 4x4
    I use mine all the time, but I'm lucky and have the power center window in my '05. Really gets the air circulating when you open the front windows.
    Darkness[QUOTED] and des2mtn like this.
  24. Oct 6, 2021 at 10:48 AM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    As much as I love the air flow mine is manual. I forget to close it whenever I open it, plus I get all the debris from my bed in the cab if its open.
    I can only imagine how annoying those double cab full roll down windows must be.
    :D I would hate to have one.
    BubbaW and EvilMilkshake[QUOTED] like this.
  25. Oct 7, 2021 at 6:43 PM
    Truckin' Girl 1117
    Christine
    Grafton
    They don't install, but the price is right and its on the way home from the cabin. So I have a couple of questions. Is this thing fragile, or can I wrap it in a moving blanket for transport. And, although I'm pretty handy, is this something I can install? The rear seat is removed, and I have every tool known to man. Thanks!
  26. Oct 7, 2021 at 6:44 PM
    Truckin' Girl 1117
    Christine
    Grafton
    What is that???
  27. Oct 7, 2021 at 6:58 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    To stop load hitting the glass
    Dan_of_Earth and 2mchfun like this.
  28. Oct 7, 2021 at 7:02 PM
    2mchfun
    That would be the cost of your damages repaired properly or back to original condition. Your post said 1800 bucks, to me that buys a bunch of firewood.
  29. Oct 7, 2021 at 7:04 PM
    Truckin' Girl 1117
    Christine
    Grafton
    The headache rack. Sorry I wasn't clear...
  30. Oct 7, 2021 at 7:05 PM
    Truckin' Girl 1117
    Christine
    Grafton
    Ok I get it Thanks!
    2mchfun likes this.
