hello from Falken Tires
Discussion in 'Wheels & Tires' started by Falken QA, Sep 27, 2021.
  1. Sep 30, 2021 at 12:18 PM
    #61
    Casper421
    In the woods
    06 DC
    315’s or 35x12.50’s on a 1st gen require tubing the firewall and other issues. A 35 pizza cutter would be ideal.
    GODZILLA and Falken QA[OP] like this.
  2. Sep 30, 2021 at 12:19 PM
    #62
    Bikeric
    Bikeric New Member
    Eric
    2007 DC 5.7
    Blown Engine.....
    :monocle:
  3. Sep 30, 2021 at 12:27 PM
    #63
    Casper421
    In the woods
    06 DC
    Use your words.
    alb1k likes this.
  4. Sep 30, 2021 at 12:37 PM
    #64
    Mallcrl
    Mallcrl New Member
    Anand
    Maryland
    '21 DC SR5 SX
    For the same reasons I went with 285/75/18 instead of the typical 35x12.50/18 or 295/70/18; the two biggest advantages are a substantially lower weight (less rotating mass/unsprung weight) and that a tall and skinny tire is able to "tank track" better at decreased off-road pressures. This isn't to say that a wider tire doesn't serve a purpose, there are absolutely situations where wider is better, but as an overall, the skinnier tire will work just as well if not better. Looking back at fairly famous off-road competitions globally, the "pizza cutter" (tall and skinny) has been the go-to choice for many years (this isn't' to jump on the "this is how it's always been done so we keep doing it" bandwagon at all, just saying it works)
  5. Sep 30, 2021 at 12:40 PM
    #65
    newemi
    newemi New Member
    2020 Tundra CM Ltd CB
    Sorry I’ve been a part of the derailed thread. I know more about the tire industry than I want to, but nobody cares, nor do I. Apparently I know nothing a Cooper tires lol. Not to mention the struggles they have had with all their investment in China factories and the tire tariffs.
    That said, for those that care, every tire sold in the US will list a Dot number. That gives you date of manufacturer plus it will also identify the plant that made the tire. If you don’t want a China tire, than just ask the tire dealer to inspect the dot code before install, they can even request matching date codes from the distributors.
    but what do I know. Back to you Mr E.
    Seafury likes this.
  6. Sep 30, 2021 at 12:46 PM
    #66
    ezdog
    ezdog New Member
    Gateway To The West
    2001 RCLB V8,4WD 2015 RCLB 5.7,4WD
    Is that supposed to be me?
    All I know is that you seemed to reply without reading the comments you quoted,thats all?
    It came across to me as somewhat condescending as you were asserting the same things already mentioned by the factory man.
    You tire knowledge had nothing to do with my comments at all.
    Falken QA[OP] likes this.
  7. Sep 30, 2021 at 12:47 PM
    #67
    Bikeric
    Bikeric New Member
    Eric
    2007 DC 5.7
    Blown Engine.....
    Weighing the purchase of a Gen 1 Tundra to use these tires, or sell them off to a current Gen 1 Tundra owner....
  8. Sep 30, 2021 at 12:57 PM
    #68
    daveeasa
    Welcome Robert from Falken. Your comments are going a long way towards nudging me towards your tires. I appreciate the open and honest communication.
  9. Sep 30, 2021 at 3:34 PM
    #69
    Falken QA
    Falken QA [OP] New Member
    I have address the matter with the user.
    Feel free to post questions on this thread. Or tag or @ me on threads that need attention that I may have overlooked.
  10. Oct 1, 2021 at 6:48 AM
    #70
    DanTundra
    DanTundra Danny
    Wilmington, NC
    2015 Ribbon Blue Tundra SR5 4x4
    TRD sway bar, airbag kit, Diamondback HD, LED headlights, Pedal Commander, Bilsteins 6112's up front with shims (2.5 inch lift), 5160s in the rear with CB +2 shackles (1.5 inch lift), Falken Wildpeak AT3W 285/75/18, TRD Pro Grill insert, MattGecko under hood and bed light kit,
    No rub on the factory UCA at least on my truck. It is close but no contact.
    2mchfun[QUOTED] likes this.
  11. Oct 1, 2021 at 7:56 AM
    #71
    Tipsovr
    Tipsovr New Member
    2012 RW Crewmax
    Love my Wildpeak AT3s on my V8 4Runner. When my current tires wear out I will put a set on my Tundra.
  12. Oct 1, 2021 at 12:59 PM
    #72
    ErikTRDTUNDRA
    ErikTRDTUNDRA New Member
    Erik
    2018 Tundra crewmax 1794
    Got the new skins installed today.
  13. Oct 3, 2021 at 10:06 AM
    #73
    Elroy_unlimited
    Elroy_unlimited New Member
    Eric
    Murfreesboro TN
    2017 limited crew max
    I almost did the same thing but ended up finding a new set on eBay. Depending on the size, I’d check there before settling for another tire.
    #73
  14. Oct 19, 2021 at 2:04 PM
    #74
    ekmason
    ekmason New Member
    2021 Tundra SR5 TRD Off-Road MBM
  15. Oct 21, 2021 at 2:21 PM
    #75
    Falken QA
    Just want to give anyone considering Walmart for tires. Note that Walmart will not provide tire after service/warranty if you do not purchase their optional warranty coverage. While you may save some bucks, you could most likely get your tires price matched or close to it with your local tire shop or authorize online vendor. From experience, Walmart may ship you wrong size tires and won't accept returns once tires are mounted on a wheel.
    To save you from future headaches, check with your local/favority tire shop & see if they can get aggressive with pricing against Walmart or Amazon listings.
    Seafury, Oey12, ErikTRDTUNDRA and 2 others like this.
  16. Oct 21, 2021 at 2:33 PM
    #76
    Elroy_unlimited
    Eric
    Murfreesboro TN
    Got my Wildpeaks mounted up. So far so good!
    How can I get some Falken decals?
  17. Oct 21, 2021 at 2:59 PM
    #77
    Falken QA
    Go ahead and send an email to inquiries@srnatire.com . Marketing will be handling your request.
  18. Oct 21, 2021 at 3:00 PM
    #78
    toyofan87
    toyofan87 Beer thirty
    Seth
    Gettysburg, Penna
    Big fan of Falkens Wildpeaks AT3's...Very impressed so far with mild offroading to my deer stand... Great both on and offroad.. Happy camper!!
    Seafury and Falken QA[OP] like this.
  19. Oct 21, 2021 at 3:49 PM
    #79
    FireArrow
    FireArrow New Member
    MD
    2021 MGM Crewmax
    Put Wildpeaks on my 16 Tacoma. Very pleased with both wet and dry traction as well as low noise.
    Seafury, toyofan87 and Falken QA[OP] like this.
  20. Oct 21, 2021 at 5:08 PM
    #80
    Falken QA
    hello all. Hold off on sending emails to info@. I'll check back tomorrow on a proper email that goes directly to marketing.
    Elroy_unlimited and Zebruaj like this.
  21. Oct 22, 2021 at 4:44 AM
    #81
    Parksareforever
    Parksareforever New Member
    2020 TRD DC 4x4
    I had wildpeaks on my tacoma. The only AT I will buy from here on out. Looking forward to getting some for my tundra.
  22. Oct 22, 2021 at 4:53 AM
    #82
    MotoTundra
    MotoTundra The Ocho
    Don
    Thanks for being here @Falken QA !
    I have some AT3W’s on my GX470 and I love them.
    When my Tundra is ready for new tires thats what I will be going with.
    Seafury likes this.
  23. Oct 22, 2021 at 5:36 AM
    #83
    mattywizz
    mattywizz New Member
    Bend, OR
    2020 Silver 1794
    I second the local tire shop. I did all my "shopping"/deciding here and all the big online retailers, but when I was ready to purchase I went to a highly rated local shop. His price on the Wildpeak was better than anyone else out there...unfortunately they were/are on back stock. I wasn't in a rush since I was waiting on wheels too. But now my wheels are here and I'm sitting on a set of Icon Vector 5s waiting for some 285/75-17 wildpeak AT3ws. I don't "need" tires so it will be okay, just don't love the stock michelins.
  24. Oct 22, 2021 at 8:48 AM
    #84
    Falken QA
    email contact updated for sticker request
    Seafury, mcharfauros and Zebruaj like this.
  25. Oct 22, 2021 at 9:20 AM
    #85
    Zebruaj
    Zebruaj New Member
    MN
    08 CM SR5
    Thanks @Falken QA! I put an email in.
    Edit: got an automated bounce back. Email address is no good.
  26. Oct 22, 2021 at 12:14 PM
    #86
    Elroy_unlimited
    Eric
    Murfreesboro TN
    Same
  27. Oct 22, 2021 at 12:53 PM
    #87
    Falken QA
    proceed with
    My apologies all. inquiries@srnatire.com
    I was too quick to reply back. I have tested myself and have not received any bounce back
  28. Dec 5, 2021 at 3:22 PM
    #88
    Zebruaj
    Zebruaj New Member
    MN
    08 CM SR5
    Did anyone ever get a sticker? Or a response?
    I've seen nothing come out of emailing them.
  29. Dec 5, 2021 at 3:40 PM
    #89
    CaptTyler
    CaptTyler Life’s too short to have an ugly boat.
    Tyler
    2018 Ram 2500 Cummins
    Love my AT3’s, would buy again in a heartbeat.
    Glad to have you on the forum!
    Seafury likes this.
  30. Dec 5, 2021 at 7:01 PM
    #90
    Elroy_unlimited
    Eric
    Murfreesboro TN
    Nope. I received an email asking for my info at the end of October but have yet to receive anything in the mail.
