Suspension Shop Search in MA or Southern NH?
Discussion in 'Suspension' started by Dre2337, Aug 25, 2021.
  1. Aug 25, 2021 at 7:24 PM
    Dre2337
    Dre2337 [OP] New Member
    Derek
    2015 Toyota Tundra SR5
    In Process...
    Looking for a quality suspension shop north of Boston or in Southern, NH. Any recommendations?
  2. Sep 5, 2021 at 8:17 AM
    abomb60
    abomb60 Maker of things
    Massachusetts
    2018 Tundra 1794 MGM
    If you're looking for someone to do the install let me know. Found a local mechanic in Billerica that was great to work with and he did the install of my OME BP-51's and rear leaf springs.
    Dre2337[OP] likes this.
  3. Sep 5, 2021 at 1:03 PM
    Dre2337
    Derek
    In Process...
    Good to know. Already have 3x1 level but getting new rims and tires soon. Camber looks off right now as it sits so just trying to connect with someone who has done lifts /suspensions before. Also, glad to hear about the springs as I am contemplating beefing mine up. Is it a specific shop or does he do his own side thing?
  4. Sep 5, 2021 at 1:04 PM
    abomb60
    Massachusetts
    Just a guy with a lift at home that does stuff on the side.
  5. Sep 5, 2021 at 1:18 PM
    Dre2337
    Derek
    In Process...
    Ok, I’ll have to figure out how to private message you on here. Know anyone who’s used to doing alignments on trucks with aftermarket tires /lifts etc?
  6. Sep 5, 2021 at 1:20 PM
    abomb60
    Massachusetts
    For alignments I just got to Sullivan Tire here in town. So far they've done good.
  7. Sep 5, 2021 at 3:14 PM
    bflooks
    bflooks New Member
    Metrowest MA
    A knowledgeable and honest shop who knows lifted Tundras is Mike at Akinauto.com
    If all you are looking for is an alignment, there are a few threads on here with specs for best wear but he seems to know them as well.
    Here is what I followed and will likely zero out the camber next alignment. I had amazing luck with Townfair Tire in Littleton tweaking the alignment post tires, but Mike installs lifts on, and aligns, Tundras a lot and i had him get me aligned immediately post lift.
    Specs (borrowed from another site).
    Camber: +.1 degree on both sides
    Caster: between 1.9 and 4 degrees with about .2 degrees less caster on the left.
    Toe: +.12 degrees per side for a total toe-in of +.24 degrees.
  8. Sep 22, 2021 at 1:51 PM
    68 RS/SS
    68 RS/SS New Member
    MIke
    New Hampshire
    2020 TRD Sport DC
    Elias 4wd center
    Main line overland
  9. Sep 30, 2021 at 4:31 PM
    KDDesignsri
    KDDesignsri Www.kddesignsri.com
    Kyle
    Rhode Island
    2021 Tundra
    Just a few so far
    I’m in Rhode Island
