Adding Overhead Console From 2nd Gen
Discussion in '2.5 Gen Tundras (2014-2021)' started by WFD473, Feb 6, 2021.
  1. Feb 6, 2021 at 8:52 AM
    WFD473
    WFD473 [OP] Long Live The V8
    Northeast Illinois
    2014 MGM SR5 CM 4x4
    I was looking to install the larger overhead console from a 2nd gen that goes further back to the rear seats. Has anyone done this and is it even possible? It would add way more storage and even has another set of lights that face the back seats. Considering the 2nd and 3rd gen roofs are the same, I would think it would work...
    https://www.ebay.com/itm/Console-Fr...4-Box-Fits-07-13-TUNDRA-2424304-/233875669353
  2. Feb 6, 2021 at 8:57 AM
    WFD473
    Northeast Illinois
    2014 MGM SR5 CM 4x4
  3. Feb 6, 2021 at 9:05 AM
    preacher35
    preacher35 RIGHTEOUS MEMBER
    2018 MGM Platinum Crewmax 4x4
    Hmmm.... Seems a stretch. The slope of the roof would have to be identical between the two gens and if the mounting points do not line up, you'd have to find a way to "rig" it. It's entirely possible, but probably a lot of fabricating. Good luck! Post pics if you get it to work!
    WFD473[OP] likes this.
  4. Feb 6, 2021 at 9:11 AM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    The cab lines are the same as far as I know (the doors are the same except for the trim). Whether the mount points are there or not, not sure. For $70, probably not a bad experiment to try.
  5. Feb 6, 2021 at 7:38 PM
    llbts1
    llbts1 New Member
    2018 Tundra Limited
    Please let us know if you do this. First mod I looked for in my 2018 truck was a larger overhead console. Never found anything.
  6. Feb 8, 2021 at 8:13 AM
    panicman
    Eric
    2018 SR5 CM TRDoffroad MGM
    This is a clever mod. Please let us know how you proceed.
    I wonder if you could harvest the whole headliner and console from a wrecking yard gen 2...?
  7. Aug 10, 2021 at 11:12 AM
    ToyoD
    ToyoD New Member
    Drew
    2021 SR5 DC
    Build page link in signature
    @WFD473 Did you end up doing this?
  8. Sep 30, 2021 at 7:05 AM
    WFD473
    Northeast Illinois
    2014 MGM SR5 CM 4x4
    Alright, Gents. I finally got time to do this after finding a console from a wrecked one on one of my FB Tundra groups. The good news is that it indeed bolts right up! The mounting point for the longer console is still there under the headliner, you just have to order two of the screw-clip things from the dealer. Unfortunately, I can't find the paperwork that had the part number on it. If you tell them what you're looking for, they can find it.
    If your radio has Bluetooth, make sure to find a console from a truck that has it too. The circled parts are the mic's. The harness that connects to the console is the same thankfully, at least for my 2014, making it plug and play.
    Once I had everything set to go, I traced the outline of the console about a half inch inside the perimeter on the headliner. It was a little nerve-racking cutting into the headliner, but I went slow and made sure it was straight.
    If I could do it over again, I would have rounded the corners at the back, so you can kind of see them peeking out with it all bolted up. Oh well...
    And here she is in all her glory! Well worth the effort to gain much needed additional storage, in my opinion. Why they removed it in the first place is beyond me. Probably to save a few bucks would be my first guess, just like the driver's side grab handle. If anyone has any questions, fire away!
  9. Sep 30, 2021 at 7:08 AM
    g6t9ed
    g6t9ed Novice Tundra Modder
    2017 Black CrewMax 1794 4x4
    This is freaking awesome! Definitely one of the things I missed when I went from my '08 to my '17. Thanks for the inspiration. I might have to add this.
    Edit: A couple of questions:
    1) Did you use any type of cutting device or just something like a box cutter?
    2) I couldn't tell but did you have the rear seat overhead lights? Does this require you to remove that?
    WFD473[OP] and HulkSmurf14 like this.
  10. Sep 30, 2021 at 7:52 AM
    WFD473
    Northeast Illinois
    2014 MGM SR5 CM 4x4
    You're welcome!! Yeah, it's a bummer that they remove things when they do updates, but I give them kudos for leaving everything in place to add them right back!!
    1) Yes, all I used was a sharp box cutter. Went through like buttah.
    2) I have a crew max with the rear lights. I didn't have to touch them because the console doesn't go far enough back to interfere. Hope that makes sense. For those with a DC, I'm guessing you'd have to find a console with the rear lights integrated into them.
    RainMan_PNW and g6t9ed[QUOTED] like this.
  11. Sep 30, 2021 at 8:00 AM
    AggiePhil
    College Station, TX
    Sunroof is in the way.
  12. Sep 30, 2021 at 8:03 AM
    RussellVaughan
    RussellVaughan New Member
    Houston
    2015 Gray TSS 5.7 CM SR5 4x4
    AMP Research PowerSteps; Katzkin leather seats (Nightrunner, all black, no perf/logo); TRD 18" BBS Forged rims; Nitto Terra Grappler G2 LT295/70R18) tires; LT295/70R18 spare tire; Rough Country speedo calibrator; Fox 2.0 IFP front & rear w/1" leaf blocks; TRD PRO black headlamps w/Headlight Revolution harness; TRD PRO grill w/color match hood bulge; RCI engine skid plate; BakFlip MX4 tonneau; Baja Design Squadron Sport fog lights w/clear wide lens; front/rear color match bumper covers; K&N CAI; Pedal Commander throttle controller w-trailer brake bezel; SE Toyota wireless charger tray; VLEDS interior and exterior LED lights; AJT Designs interior chrome delete; Sparks Parts driver side grab handle kit; Pop&Lock tailgate lock; ICS Fab dash mount w/support plate; ICS Fab center console mount; SNS Custom Design ABS sensor guards; TRD PRO shift knob; Undercover Swingcase bed storage; Rad Rubber Design engine splash guards; Bull Ring bed rail tie-downs; exterior debadge w/black & engine badge and black 4x4 badge; Charvonia Design billet bed tie-down anchors; rear console USB port; TRD rear sway bar; Fumoto Oil Pan Valve; Toyota metal oil filter assembly; Vexing R1 dash cam; X2Power 24F Battery.
    Wow this is awesome! any chance you could send a pic with all the compartments open? I'd like to get a sense of what they could hold
    Edit: Nevermind, I googled it. Thanks again. I just bought a doublecab version since it appears to be identical except it has the extra light toward the rear end.
    WFD473[QUOTED][OP] likes this.
  13. Sep 30, 2021 at 8:14 AM
    g6t9ed
    Thanks for the quick reply and confirmation.
    I just thought of another question. Since you cut into the headliner, have you noticed any additional road noise or higher cabin noise?
  14. Sep 30, 2021 at 8:43 AM
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
    That's pretty ingenious. Looks like you could fab some Raptor style toggle switches up there replacing one of those compartments instead of the current thing folks are doing in the small cubby by the shifter.
    I hate how our headliner and its trim isn't black. Such an easy thing they could of done to make this truck nicer.
  15. Sep 30, 2021 at 8:51 AM
    How much was that?
    ATHiker likes this.
  16. Sep 30, 2021 at 9:45 AM
    Occidentalis
    Occidentalis Out Snakin'
    North Florida
    2015 Inferno TRD Pro
    Very cool. May have to do this at some point unless the 2022 sunroof can be retrofitted =D
  17. Sep 30, 2021 at 10:11 AM
    RussellVaughan
    Houston
    final cost after taxes and shipping was $280... Used in "excellent" condition on ebay
  18. Sep 30, 2021 at 11:49 AM
    WFD473
    Northeast Illinois
    2014 MGM SR5 CM 4x4
    Not at all! I moved the white foam looking stuff to the sides to make room for the console, so maybe that helped keep it sounding the same. But, I also have a Dirty Deeds exhaust system, so that could be covering any additional noise there may be.
    g6t9ed[QUOTED] likes this.
  19. Sep 30, 2021 at 12:09 PM
    jimmyfu
    jimmyfu New Member
    N. California
    2014 Tundra DC SR
    this is awesome! now to find one for my double cab... thanks for being the first to test this out!
    WFD473[OP] and Vang530 like this.
  20. Oct 1, 2021 at 9:47 AM
    What the!?
    What the!? New Member
    2017 Pro
    Looks great. I might have to do this.
  21. Oct 1, 2021 at 12:36 PM
    RainMan_PNW
    Casey
    Clark County, WA
    SWEET!
    I've got a moonroof, so no chance of doing that. But if I didn't, I'd be all over it.
  22. Oct 1, 2021 at 12:45 PM
    GayFish
    GayFish Member
    2016 Super White SR5 CM 5.7L 4X4
    welp, wish I didn't see this, now i'm gonna spend my Saturday calling Junk yards.
  23. Oct 26, 2021 at 10:04 PM
    jimmyfu
    jimmyfu New Member
    N. California
    2014 Tundra DC SR
    just curious - with that new cutout, is it easier to add sound deadener? :monocle:
  24. Oct 27, 2021 at 12:01 AM
    panicman
    Eric
    @Roman
    any chance we can get these consoles new/OEM??
    OP- great idea and great write up!
  25. Oct 27, 2021 at 2:13 PM
    WFD473
    Northeast Illinois
    2014 MGM SR5 CM 4x4
    Thank you, Sir! :hattip:It was a fun mod to do.
  26. Oct 27, 2021 at 2:43 PM
    What the!?
    2017 Pro
    The clips, are they the ones in the diagram 63317a?
  27. Oct 27, 2021 at 3:26 PM
    WFD473
    Northeast Illinois
    2014 MGM SR5 CM 4x4
    Those look like the ones. They're the same ones that hold in the original. You just need 2 more.
    What the!?[QUOTED] likes this.
  28. Oct 27, 2021 at 3:30 PM
    WFD473
    Northeast Illinois
    2014 MGM SR5 CM 4x4
    These ones. They should come with the 2 screws as well.Screenshot_20211027-172753_Chrome.jpg
    What the!? likes this.
  29. Oct 27, 2021 at 6:49 PM
    panicman
    Eric
    Next question- is it possible PRIOR TO CUTTING to pull the headliner enough to see if the sheet metal is the same in 2018?
    To be sure, my guess is that the sheet metal remains unchanged from ‘14-‘18, but I’d sure hate to cut that headliner away and see nothing but featureless roof!
    This is such a cool mod. Thanks again.
    WFD473[OP] and ToyoD like this.
  30. Nov 4, 2021 at 12:27 PM
    jimmyfu
    jimmyfu New Member
    N. California
    2014 Tundra DC SR
    ^I think if you take out the rear map light, you should be able to pull down and feel around.
    I just finished this on my double cab. It seems that the whole console unit is just a tad too short, as I've still got a gap (not from cutting) showing:
    Other than that, a pretty easy job to do. If you have a double cab, there's a separate power wire for the rear light you can utilize. The wire harness that came with my console was one long one that harnessed into the plug in the front, but I couldn't use it as I had to swap over the bluetooth module from my original overhead console.
