  1. Sep 29, 2021 at 2:33 PM
    TampaRD Pro
    TampaRD Pro Cunning Linguist
    Stanley
    Southwest Florida
    2020 MGM CM TRD Pro
    Lots.
    Installed my onboard air system. Purchased an ARB CKMTA12 Twin compressor and the SDHQ firewall mount for it. Wired the leads directly to the battery and stripped down the switch wiring harness to just the purple trigger wire and connected to my Switch Pros SP-9100 system. I wanted to install a modified "Wifey" air system with fender well connections and intend to later add air horns.
    https://www.amazon.com/ARB-CKMTA12-Board-Performance-Compressor/dp/B0050DI9YQ
    https://sdhqoffroad.com/products/07-21-toyota-tundra-arb-air-compressor-mount-kit
    Since my SP-9100 is mounted to a Power Trays mount on my engine compartment fuse box I had to come up with a location to securely mount the distribution manifold for the air up/down function. After much consideration I found the best place for me to install it would be to the top of the compressor fan mount. There was plenty of room and clearance for the mounting bolts for the block and it in no way interferes with the operation of the compressor. I took a piece of .125 x 3" aluminum flat bar, fabbed up a mount and painted it gloss black.
    I ordered all of the individual components for the the air distribution system separately instead of purchasing the "Wifey" kit from Rago Fabrication, mainly because I could get upgraded parts for the same price (or less). I used a Viair 9280 6 port manifold with mounting holes so that I could easily secure it to the mount. I used lock washers and Red Loctite to secure the manifold bolts to the mount I made due to the heat and vibration of the compressor while in use. This manifold is the only aluminum part I used, opting for solid brass connections for the Legris sleeve/slide valve and on all other air line parts. I assembled the manifold on my work bench and tested all of the connections to it for leakage with my garage compressor before installing it in the truck so as to not be torquing on the mounted compressor. I included an ARB quick connect chuck to allow for a standard air hose to be connected from the front of the vehicle.
    https://www.amazon.com/Viair-92820-...iair+distribution+block&qid=1632949368&sr=8-3
    https://www.grainger.com/product/LEGRIS-1-4-in-Nickel-Plated-Brass-1DDY5
    https://www.northridge4x4.com/part/...MI4JvAno2l8wIVTAeICR0jMA__EAQYAyABEgIPCvD_BwE
    As I mentioned before I used all brass fittings, including the air line push in connections and Tees instead of the plastic ones that are susceptible to heat damage and are rated for less air pressure. I'm sure the plastic fittings work fine but I opted for the metal ones out of an abundance of caution. I also chose red nylon brake tubing, in keeping with the color scheme of my truck, that is rated to 362 psi and 248 degrees. I was very careful to route the tubing along the frame and wiring mounts and to keep well clear of the exhaust pipe and other heat sources.
    https://www.amazon.com/gp/product/B08HQSZHZG?ie=UTF8
    I used Rago Fabrication Tundra air chuck mounts in the fender wells. IMG-1317a.jpg
    After finishing the install I checked every connection for leaks, aired down to 18 pounds and aired back up again. The system works great and I'm looking forward to using it for a long time.
  2. Sep 29, 2021 at 3:13 PM
    Arod8123
    Arod8123 New Member
    2016 Silver sky Tundra Trd
    How did you mount those lights behind the grille?
    aark12 likes this.
  3. Sep 29, 2021 at 3:24 PM
    greg8765
    greg8765 New Member
    Grant
    Utah
    2021 Cement Tundra
    ah yeah! got the same on and attaching them to the skid plate was challenging for a one man show without a fancy jack
    TaquitoBandito likes this.
  4. Sep 29, 2021 at 3:37 PM
    redrum448
    redrum448 New Member
    Do the air hoses ever break while driving? seems the spinning wheels would break them
  5. Sep 29, 2021 at 3:38 PM
    aark12
    aark12 AARK12 - Hello All
    New Mexico
    2020 Tundra Limited TRD
    Bilstein 6112, Pedal Commander, TRD Pro BBS Wheels, Gator Tonneau Cover, Bed Step, TRD Pro Grill, Mirror Caps, Grab Handle, Dirty Deeds 10in System, rear bumper step, dash cam
    Yep, that jack is the ace up my sleeve, haha!!
  6. Sep 29, 2021 at 3:39 PM
    MikeyRedFL
    MikeyRedFL New Member
    SWFL
    2021 Limited Crew Max 4x4
    Got my deliveries from AlphaRex today and naturally had to install them... PRO-Series LED Tail Lights Red Smoke and Alpharex Nova LED Projectors in Alpha Black..
    Very nice products.... couple of hours to install all 4 no rush...
    20210929_121655.jpg 20210929_123324.jpg 20210929_161746.jpg 20210929_130428.jpg 20210929_155654.jpg 20210929_182345.jpg
  7. Sep 29, 2021 at 4:19 PM
    50Shades
    50Shades Sin City Tundras
    J
    West Coast
    2021 Tundra SR5 CrewMax Trail Edition 4x4
    How does the DRL perform in broad daylight? and how bright are the tail running lights and brake lights?
    nmjameswilson likes this.
  8. Sep 29, 2021 at 5:30 PM
    Black Dynamite
    Black Dynamite New Member
    2017 Toyota Tundra Limited Crew Cab
    Any tips on installing these? Any thing we should look out for?
    50Shades[QUOTED] likes this.
  9. Sep 29, 2021 at 5:31 PM
    TampaRD Pro
    Stanley
    Southwest Florida
    2020 MGM CM TRD Pro
    Lots.
    Naw, not if you get the "Special Edition" TRD Pro Spinner wheels from Southeast Toyota dealers. Just the tires turn and the center of the wheel with air outlet is stationary, duh.
    TaquitoBandito and BlueRibbon4x4 like this.
  10. Sep 29, 2021 at 6:13 PM
    jeffw6236
    jeffw6236 New Member
    Jeff
    San Antonio
    2019 MGM CrewMax 4x4
    So this happened today.
    Falcon shocks, Coachbuilder +1, Coachbuilder bumper shims, Icon 6 Speeds, 295/70/17 KO2s. I’ve only been able to drive it for a few miles but the ride is freakin awesome! Prior setup was stock with the 20” TSS wheels and 275/55/20 Duratracs.
    Not a perfect view. The driveway slopes and all my old tires/rims are in the back.
  11. Sep 29, 2021 at 6:16 PM
    MikeyRedFL
    SWFL
    So my Limited came with Chrome LED headlights stock.... The DRL's were good with the stock lights as well as with the Alpha Rex. They are bright in the day time but i have no way to compare now. The DRL's have multiple modes so that when you have IGN on with no lights on they are brightest.
    Ignition/Engine ON – DRL at High intensity
    Parking Light ON – DRL at reduced intensity
    – amber side marker
    Low Beam ON – DRL at reduced Intensity
    – Amber side marker
    – Low beam on
    High Beam ON – DRL at reduced Intensity
    – Amber side marker
    – Low beam on
    – High beam on
    Automatic Function – Will function as normal
    The have a really cool startup routine where they startup amber then flash in a sequence and then go white. The big difference is in the low beams and the high beams which are both way superior (and brighter) with the Nova's while maintaining DOT.
    The tail lights look great on and off...The brake and turn/flashers are big and bright.
    The leveling motors work and the auto dim brights work
  12. Sep 29, 2021 at 6:26 PM
    ErikTRDTUNDRA
    ErikTRDTUNDRA New Member
    Erik
    2018 Tundra crewmax 1794
    Looks awesome, my tires were scheduled to be installed today but haven’t showed up yet.
  13. Sep 29, 2021 at 6:39 PM
    KDDesignsri
    KDDesignsri Www.kddesignsri.com
    Kyle
    Rhode Island
    2021 Tundra
    Just a few so far
    Did a ton! Ajt designs interior bits, led tails, started the audio system. Started an Instagram page for the truck as well. @tundramodshop
    GAknight, Cosmoblu, 3xYOTA and 11 others like this.
  14. Sep 29, 2021 at 6:41 PM
    Start a build thread here in the forum as well. :thumbsup:
    50Shades and KDDesignsri[QUOTED] like this.
  15. Sep 29, 2021 at 6:53 PM
    KDDesignsri
    Kyle
    Rhode Island
    2021 Tundra
    Just a few so far
    Will do! Thank you!
  16. Sep 29, 2021 at 8:52 PM
    Terndrerrr
    Terndrerrr 925000 miles to go
    Music City
    6UR-FE
    Removed badges and replaced the 5.7s with black. As far as debadging goes, it sucks. I used a heat gun in addition to letting each side of the truck sit in direct sunlight on a hot day. I still left tons of adhesive on the truck after prying the badges off. After picking all the adhesive off that I could, I sprayed some Goo Gone on and gently scrubbed after letting it sit for 15 minutes. I can still faintly see the outline of the removed badges. I’m going to wash the whole truck as soon as I can and apply some Griot’s synthetic clay bar followed by Griot’s 3 in 1. We’ll see how it comes out then.
    Also, had some Pro wheels mounted up. I like them with the Land Cruiser center caps. Going to order some black lug nuts as well.
    GAknight, Tidechaser, 2Tall and 22 others like this.
  17. Sep 29, 2021 at 10:24 PM
    Truckinewbie
    Truckinewbie New Member
    2014 Crewmax LTD TRD offroad beast
    285 65 18 KO2's, added P3 brake controller, tinted front windows, tow Mirrors
    "It's not who you are underneath, it's what you do that defines you."....Holy Moley, that is Bat-ASS!!! :smokertransformer:
  18. Sep 29, 2021 at 10:32 PM
    French Avocado
    Utah / Wyo
    Looks great - here are the part numbers for the black lugs with pricing from Lewis Toyota
    PT2763420002 $ 51.75 Alloy Wheel Locks - Black PVD (four locking lug nuts and one key)
    PT0760C20002 $ 12.94 Black PVD Lug Nuts (package of five - one package needed for each wheel - four packages for complete set)
  19. Sep 30, 2021 at 7:43 AM
    Npowers66
    Npowers66 New Member
    18 SR5 crew max
    I LOVE that color. Truck looks good man
  20. Sep 30, 2021 at 7:47 AM
    TundraTRD08
    TundraTRD08 Somehow I fit 37s on a level
    Wesley
    08 Super White TRD Off-Road on 37s
    3.5' RC lifted struts with RC UCA Alcan rear leaf spring upgrade with 300lbs added weight+1" lift built in. Adjustable Alcan Shackles set to add an extra inch which equals to a 2" lift in the rear. 37” Maxxis RAZR M/Ts with 1.5” spacers 8” BAMuffler Tuned by Bully Dog Tuner
    Do you know if there are any taillights similar to these? Other suggestions are welcome too! Also not trying to break the bank
  21. Sep 30, 2021 at 7:55 AM
    RobertD
    Robert
    DFW, Texas
    Do a search or create a thread. Many different threads on taillights already. I think you will find some you like. The Alpharex and HiRevs are currently the most popular aftermarket and both are affordable.
  22. Sep 30, 2021 at 8:04 AM
    50Shades
    J
    West Coast
    nope! it was very straight forward. plug and play and a little wire tap for the turn signals is all! One thing i can say though, because the Alpharex uses milky white color translucent lens for the DRL, it's not as bright looking at the OEM clear lens. but my fogs with DRL compensates for that.
    that's my only concern in broad daylight. but other than that, the DRL and sequential are very bright and visible when not facing against the sun.
  23. Sep 30, 2021 at 8:09 AM
    50Shades
    J
    West Coast
    thank you for the feedback! I just recently installed Alpharex on mine too and i love them! I didnt go with the "premium" Nova series. I just have the TRD style with reflectors and LED and it is already a huuuge upgrade from my stock halogens. And I agree, I love the little start up sequence it does lol
    Gonna get me some Alpharex tail lights next!
    Jcmf52 likes this.
  24. Sep 30, 2021 at 9:44 AM
    infidel
    infidel New Member
    Jesse
    SE Wisconsin
    2016 Silver SR5 Crewmax
    Procomp 3/1 Method 307 18x9 +25 Falken Wildpeak AT3W 295/70r18
    Really digging those tails
    50Shades likes this.
  25. Sep 30, 2021 at 10:14 AM
    runningbombtech
    runningbombtech Newest Member
    2021 Army Green Tundra 4x4 Trail Edition
    Interior chrome delete progress. That cup holder glare is no joke.
    GAknight, GELCW, 1lowlife and 5 others like this.
  26. Sep 30, 2021 at 10:22 AM
    JeffMac
    JeffMac 2 Words, 1 Finger
    Jeff
    South Florida
    2015 Black Tundra OVTUNE
    Suspension: Bilstein 6150 Front Max Setting CB Shim 2x Driver 1x Passenger Bilstein 5160 Rear CB +3 Shackles Firestone Airbags w/ Daystar Craddles Engine: OVTUNE - 87 w/ Torque Modifier SABM w/ K&N Filter TB Coolant Bypass Fumoto Drain Plug Wheels/Tires: ProComp Bandidos 0mm Offset Nitto Exo Grappler AWT 285/70/18 Exterior: TRD Pro Grille Spyder Headlights/Taillights Ecoological Bumpershellz LED everything Tinted windows Bakflip MX4 Tonneau Cover K-Source Tow Mirrors Interior: Pioneer AVH-W4500NEX Radio 2x 10” Pioneer Subwoofers 1200W Pioneer Mono Amp 2000W Pioneer 4 Channel Amp
    I’ve heard you really only need it if you’re supercharged which I’m not. I got this off Amazon for $20ish then I bought 6ft of 1/2 hose from Advanced Auto. It’s function is pretty basic I didn’t see the point of spending $200.
    Ruien Polish Baffled Universal Aluminum Oil Catch Can Reservoir Tank Black https://smile.amazon.com/dp/B06XK9PTP7?_encoding=UTF8
    SchnauzerMan likes this.
  27. Sep 30, 2021 at 11:40 AM
    MARanger
    MARanger Lost in the woods
    Andy
    Home of Friendly's Ice Cream
    2017 Super White SR5 DC 4X4
  28. Sep 30, 2021 at 11:44 AM
    Hamster14
    Hamster14 New Member
    Utah
    2014 Tundra Limited
    -46 gallon tank - shell
    :101010:
    that’s one BAAAAD tundra :101010:
    PaulROahu[QUOTED] likes this.
  29. Sep 30, 2021 at 1:31 PM
    713Tundra
    713Tundra New Member
    HTX
    2017 BBP Limited TRD OR CM
  30. Sep 30, 2021 at 1:57 PM
    SchnauzerMan
    SchnauzerMan New Member
    Southern New Mexico
    2019 SR5 CM 4x4
    Sumo Struts, Tiger Steps, Bed Rug, Undercover Flex Hard Folding Tonneau Cover
