  1. Sep 29, 2021 at 4:33 PM
    So I might try my luck at eyeballing a hole into the cover cap, so it cleans up the screw/standoff a little better
    Cummins3500[QUOTED] likes this.
  2. Sep 29, 2021 at 4:43 PM
    Cummins3500
    Logan
    I’m likin this idea lol it looked like it was missing something in the pictures
  3. Sep 29, 2021 at 4:49 PM
    Made a shower bag bracket for the Sedona trip coming up. No trees, no problem; you can see my who-ha, your problem!
    I should be able to tie a tarp to my swing out, while it’s open and make a sweet Lil shower stall. 4885AD6F-0DCC-4F83-AC2F-71875873DA11.jpg
    abcinv, des2mtn, alb1k and 6 others like this.
  4. Sep 29, 2021 at 4:53 PM
    You have a who-ha? You sure you know what that means?
    You may need to change this.
    abcinv, oscardog86, bmf4069 and 2 others like this.
  5. Sep 29, 2021 at 5:20 PM
    Cummins3500
    Logan
    So did y’all with a scan gauge have to program codes in for the trans temp?
    I think I’ve got trans temp pulled up on my ultra gauge and it was pre programmed in
  6. Sep 29, 2021 at 5:22 PM
    Yeah SG requires you to input them yourself
  7. Sep 29, 2021 at 5:23 PM
    I use the word at work way to much, so it just carries over.
    Tundra2 and Darkness like this.
  8. Sep 29, 2021 at 5:28 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Ultragauge is pretty cool. My only real complaint is that it will self destruct in the Summer. Be careful how hot your car gets with that thing or the screen can fail. I pulled mine out for the Summer and hoping I don't have to calibrate it again.
    Scan gauge doesn't seem to care how hot or cold it is outside. To be fair mine has only seen 30f at the coldest.
  9. Sep 29, 2021 at 5:39 PM
    SG does fine in the heat, shoot, the company is based in Mesa Az. I’m sure the warehouse isn’t climate controlled!
    I’ve actually been to their office to buy mine and have them set it up to read tire pressure, super nice people!
    des2mtn and Darkness[QUOTED] like this.
  10. Sep 29, 2021 at 5:41 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Tire pressure! Thats a new one.
    In other news I finally did it. I finally got the beer fridge in my garage tuned to get beer just below freezing. Perfect.
    bmf4069, Lil Steve, des2mtn and 3 others like this.
  11. Sep 29, 2021 at 5:44 PM
    Cummins3500
    Logan
    @Darkness @FrenchToasty i wondered about that. My edge in the Cummins is the same way, no issues with heat. It’s mounted on the a pillar and doesn’t care what time of the year it is . I guess if the ultra grenades I pick up a scan gauge lol
    Darkness and FrenchToasty like this.
  12. Sep 29, 2021 at 5:46 PM
    Yep tire pressure!!
    I think I need to pull the one we use in the back room and change the filter dryer and recharge; I feel like it’s low on gas, keep seeing lots of frost on the back wall. We had issues with the Receptacle it was plugged into, changed that. And then one day it was off on overload, so I’m thinking I’m not getting enough cooling back to the compressor from a low charge or clogged drier; usually it leaks from the factory crimp offs
    Darkness[QUOTED] likes this.
  13. Sep 29, 2021 at 5:50 PM
    Casper421
    In the woods
    06 DC
    Did they show you how?! My ocd ass needs this!
    Darkness likes this.
  14. Sep 29, 2021 at 5:52 PM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    Hmm, I would add TPMS to my truck if a scan gauge could give me live PSI readouts. Wonder if that would be possible on the early trucks.
  15. Sep 29, 2021 at 5:53 PM
    This came from a old 4runner thread, but I think you could mail them your unit, and they will reprogram it so it can support tire pressure and whatever else.
    I hadn’t bought one yet, so I just contacted them directly and picked it up from their office in the valley of doom!
    I’d email or call and ask them what would need to be done.
  16. Sep 29, 2021 at 5:55 PM
    daveeasa
    Oh it doesn’t do that out of the box? Womp womp. I’m game for reprogram but it’s not possible to DIY?
  17. Sep 29, 2021 at 5:55 PM
    Yeah I’m not sure when the cutoff would be, maybe we need the committee on this one, but I think your a 1.5 gen, so maybe you would have the capability
  18. Sep 29, 2021 at 5:56 PM
    When did you buy it? I think at the time, old versions needed to be updated, but current versions were sent out game on
  19. Sep 29, 2021 at 6:00 PM
    daveeasa
    Oh sweet. It’s been in a pile for about a week.
    bmf4069 and des2mtn like this.
  20. Sep 29, 2021 at 6:03 PM
    Damn I thought I was bad about having shit just waiting to be installed!
  21. Sep 29, 2021 at 6:03 PM
    daveeasa
    That’s only the Tundra side.
  22. Sep 29, 2021 at 6:06 PM
    Good answer!!!
    daveeasa[QUOTED] likes this.
  23. Sep 29, 2021 at 6:17 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Yes. Same codes as 2nd gen taco
  24. Sep 29, 2021 at 6:18 PM
    empty_lord
    05 rollover special
    05-06 trucks can have it.
  25. Sep 29, 2021 at 6:30 PM
    daveeasa
    Oh but not me? It needs needs the ECU TPMS? Bummer.
  26. Sep 29, 2021 at 6:32 PM
    empty_lord
    05 rollover special
    Yea. But there’s aftermarket options out there to show tpms if you really wanted it
  27. Sep 29, 2021 at 6:44 PM
    Getting the truck ready for the beach trip. Went to grease the upper ball joints and found red grease. I don't own red grease. Apparently they lubed them when they did the alignment recently.
    Removed the rear seat. One nice bonus is that those hooks are useful for holding things.
    Darkness, NUDRAT, NomadicFrog and 7 others like this.
  28. Sep 29, 2021 at 9:23 PM
    Desert Dog
    2001 SR5 AC 2WD 4.7l
    Take pix of your trip, please, the Outer Banks are beautiful.
  29. Sep 29, 2021 at 11:46 PM
    Voss
    Voss Dust in the wind
    Valod
    2003 AC TRD 4x4
    First time seeing the new bumper, looks great!
    Darkness, NUDRAT and alb1k like this.
  30. Sep 29, 2021 at 11:52 PM
    empty_lord
    05 rollover special
    So late night break testing happened tonight.. I really need to get these rear disks done. Pressed the pedal as hard as I possibly could, balance front and rear feels great, but full force on the pedal ABS doesn’t do anything. My grip to the road is better than my brakes. Must fix this.
    Darkness, des2mtn, Sirfive and 3 others like this.
