Oil pressure gauge with pic
Discussion in '1st Gen Tundras (2000-2006)' started by AZ59apacheguy, Apr 14, 2017.
  1. May 2, 2019 at 7:49 AM
    Gordon
    Gordon New Member
    So, if the light does not illuminate, and the pressure gauge doesn't work, that means probably a bad wire? or bulb and sending unit or all three?
  2. May 2, 2019 at 7:54 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Yep, probably an electrical fault. I'm sure that there's a way to manually check the oil pressure, but you might need to ask a shop to do that for you to save you from having to purchase the tools yourself for a one time use. I'm not sure if the oil pressure information is available via the OBDII port and a dongle or one of the Scangauge devices that I've read that some use. That could be an option as well.
  3. May 2, 2019 at 9:06 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    I am pretty sure engine oil pressure not available on the OBDII port. I've looked at using actual oil pressure values to "calibrate" my gauge, and I believe I found it not available. Since real-life oil pressure varies from engine to engine, the OEMs decision to leave it off may have been a deliberate attempt to minimize spurious warranty complaints.
    @Gordon Better get it checked out quickly. The light and the gauge provide redundancy. If they're BOTH out, it might be coincidence, but it would worry the **** out of me.
    Wynnded[QUOTED] likes this.
  4. May 2, 2019 at 9:20 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    If the light comes on before you start it then it's good. Attached is how to test the sender with a multimeter. If you have the gauge though I don't believe there is a separate light.
    tunyota, Sampson and JohnLakeman like this.
  5. May 2, 2019 at 10:14 AM
    JohnLakeman
    Whoa...You are RIGHT for my 2017! At least not a dedicated light. :eek:
    Sampson likes this.
  6. May 2, 2019 at 11:03 AM
    Gordon
    Gordon New Member
    So that was my question, I have the gauge which doesn't work, but also see no warning light when i turn the key before starting. My manual does not specifically mention the light. I assumed no light. The engine sounds like new, so I am not too worried about it not getting oil. But still, I would like to get it working.
    FesterW. thanks for sending along the procedure.
    Gordon
  7. May 2, 2019 at 11:15 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Sometimes you can if there is a provision for an idiot lamp by shining a flashlight onto the cluster. True that it won't mean that there's a lamp there though. I had a first generation Tacoma that had the provision for a low fuel light, but didn't actually have the pathways on the circuit board in the cluster.
    You may simply have an open circuit (broken/damaged wire) from the sender.
  8. May 2, 2019 at 1:26 PM
    Festerw
    Festerw New Member
    04 Tundra DC
    Looks like if you have tach you get a gauge and no light. This is from the 00-03 Toyota service manual.
    Sorry about the weird crop, best I could do from my phone.
    Sampson and bmf4069 like this.
  9. May 2, 2019 at 5:46 PM
    Aerindel
    Aerindel New Member
    Montana
    My 2000 has a pressure gauge, no light.
    Sampson likes this.
  10. May 2, 2019 at 6:17 PM
    Professional Hand Model
    Fred
    Hand Protectors
    Pressure gauge and no light here as well.
    Sampson likes this.
  11. May 2, 2019 at 10:06 PM
    Who doesn't have a tach? o_O
    Sampson, Festerw and Aerindel like this.
  12. May 2, 2019 at 10:53 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    And I just checked my '11. Gauge and no lamp. Learned something...:D
    Sampson likes this.
  13. May 3, 2019 at 2:14 AM
    Festerw
    Festerw New Member
    04 Tundra DC
    I'm guessing some base model V6 trucks.
  14. May 25, 2020 at 12:04 AM
    FLJ23
    FLJ23 New Member
    2004 DC 4x4
    Stock for now
    Hey guys, I just got an 02 and noticed the pressure was not moving at all. At idle or when driving. I replaced the gauge with an AC Delco and when I turn the key to ON position the pressure goes up to almost High, then when I turn on the truck it slowly drops to Low. When i start to drive it stays on low and doesn’t move at all. Any advice?
    I know the switch is good since this one actually moves the gauge on dash but don’t know why it drops and stays on low. Thanks
  15. May 25, 2020 at 5:34 AM
    Fred
    Hand Protectors
    Try a Toyota Gauge.
    Sampson likes this.
  16. May 26, 2020 at 4:50 AM
  17. May 29, 2020 at 4:34 PM
    ToyotaJim
    ToyotaJim New Member
    Chiming in on this older thread. I noticed my 2002 oil pressure was at the 1/4 mark while idling today. I was a little concerned. I checked the oil and it's fresh and at the correct level. Looking thru some threads it appears correct.
    It's a bit annoying that these gauges don't have a visual "ok level" indication. Some have a redline area, which I suppose thru a comparison one is okay if there's no red area... Would be a thoughful touch if there were green and red areas...
  18. Feb 28, 2021 at 9:30 AM
    AV8R4AA
    AV8R4AA New Member
    Greg
    Justin Texas
    2005 Tundra XSP
    I run slightly thicker oil. I’m in Texas, and it’s hot as hell here. I prefer a oil
    pressure indicating higher than flatline.
  19. Feb 28, 2021 at 1:02 PM
    See above
  20. Mar 2, 2021 at 8:35 PM
    #50
    Sampson
    Sampson New Member
    2001 Tundra SR5 V8 TRD 4x4
    I also bought an AC Delco replacement. It cost me $25 CAD, and as it turns out, you get exactly what you pay for. Mine behaves exactly the same as yours.
    I got a quote for the genuine Toyota oil pressure switch from my local dealer and it was $138 CAD. I wound up finding a genuine Toyota switch online for $90.
  21. Mar 15, 2021 at 10:57 PM
    #51
    tunyota
    tunyota Wrenching w/ the beautiful wife.
    Phantom Gray 2006 Regular Cab Long Bed 4WD V8 4.7L
    Front Hitch Receiver, Bilstein 5100s, Denso 130A alternator, LED interior and exterior lighting, Kicker 46CSS674 Car Audio 6 3/4" Component Full Range Stereo Speakers, Pioneer AVHX2700BS w/Pioneer NDBC8 Backup Camera, Transcend Drivepro 550 Dual Lens Dash Camera, and much more!
    I wanted to share this YouTube video with the group since it's relevant.
    https://youtu.be/iLqYs4aIErk
    I really enjoy watching that this guy's videos especially when it comes to working on the 2UZ-FE engines and associated drivetrain.
  22. Mar 16, 2021 at 4:18 AM
    #52
    Fred
    Hand Protectors
    Yeah. I watch a little bit of that guy last year. He is an informative Jolly Dude. Best vid he did was when he (jokingly) captured some oil in a Sauerkraut jar. :rofl:
    tunyota[QUOTED] likes this.
  23. Sep 28, 2021 at 8:20 PM
    #53
    01tunder
    01tunder New Member
    Ca
    2010 4x4 trd tundra
    Im having the same issue , it doesnt pass the middle line even when i gas it.
    My 01 tundra would go all the way up to the H
  24. Sep 28, 2021 at 9:06 PM
    #54
    Desert Dog
    2001 SR5 AC 2WD 4.7l
    The issue you have is most likely a faulty oil pressure sending unit and/or the connection to it. If you want peace of mind in knowing that the oil pressure is within spec hook a mechanical gauge up in place of the sending unit and take the reading from there, this will give you the true oil pressure reading.
  25. Sep 29, 2021 at 4:33 AM
    #55
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Correct me if wrong but is this on your new to you 2003 you've mentioned in a few recent threads ?
    If so, I would recommend inputting your year, model and trim on your Personal Details Vehicle One-Line Description: given your screen name implies 2001 Tundra !
    Personal Details | Toyota Tundra Forum (tundras.com)
    The description of your 2003 not passing "middle line" might not be an issue. What reading do you see after engine is warm, in Park, idling ?
    That is very much an issue but if you indeed no longer have the 2001 it's mute ?
