Driveline Grease zerk
Discussion in '2.5 Gen Tundras (2014-2021)' started by Chingo31, Sep 28, 2021.
  1. Sep 28, 2021 at 4:40 PM
    Chingo31
    Chingo31 [OP] New Member
    2019 Toyota Tundra 1794 4X4
    Lift Kit
    Looking to grease driveline on my 2019 Tundra and their is no grease zerk? Why?
  2. Sep 28, 2021 at 4:43 PM
    koditten
    Kirk
    Midland of the Mitten
    Mine were the same. Made it to 100k. Just installed greasable versions this last week.
  3. Sep 28, 2021 at 4:49 PM
    2mchfun
    Just another way to make more service needs (profits)! The less you can lube, the more fail. All about $$$$.
    Mr Badwrench likes this.
  4. Sep 28, 2021 at 5:37 PM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    There are none. Toyota stopped after 2017. All the bearings are sealed units.
  5. Sep 28, 2021 at 5:39 PM
    Danman34
    Danman34 New Member
    Danny
    Not necessarily. There are more failures due to people ignoring the fact they have to routinely add grease to a bearing than units with sealed bearings.
    GODZILLA likes this.
  6. Sep 28, 2021 at 5:40 PM
    crewmaxlmt
    crewmaxlmt How dare you!
    scott
    2020 Crewmax Limited
    To be fair, many trucks have gone to permanently lubed u-joints years ago. I was surprised when my old 2014 had them. I was also surprised when my 2020 didn’t.
  7. Sep 28, 2021 at 5:47 PM
    2mchfun
    Out of all of them I replaced over the years, the seals were basically the same. Only difference was grease ports. So I don't buy the "sealed" BS.
    koditten likes this.
  8. Sep 28, 2021 at 6:02 PM
    koditten
    Kirk
    I was surprised to find my " lifetime free replacement u joints" were without grease zerks and cost $25 each, yet the non lifetime versions with grease zerks only cost $14 each
    If you do your own maintenance and plan on keeping the truck for 300k miles, get the greasable. If you get a new truck every 3 years, don't bother worrying about u joints.
    Some claim the non greasable u joints are stronger since the entire u joint cross is solid with no grease ports drilled in them. With our 430 gear ratios, I don't think the u joint is the weak link. JMO.
    2mchfun and HulkSmurf14 like this.
