Changing front brake pads
Discussion in '1st Gen Tundras (2000-2006)' started by Tundra_girl.87, Sep 28, 2021.
  1. Sep 28, 2021 at 9:44 AM
    Tundra_girl.87
    Tundra_girl.87 [OP] New Member
    Liz
    05 Tundra
    I bought a used 05 Tundra and I'm changing the front break pads for first time, I watched a YouTube video to see how to push the pads into push the Pistons in, he said to use a push pin but idk what size to use? Any help much appreciated!
  2. Sep 28, 2021 at 10:01 AM
    des2mtn
    Shady Grove
    2004 Black DC Limited 4x4
    Tonto cover
    Do you have a c-clamp? You can put the old pads back in the caliper and tighten it to get the piston to go back in. You might have luck pushing it in with a 2x4 or pry bar.
    Screenshot of a c-clamp in action.
    FrenchToasty, bmf4069 and Bob like this.
  3. Sep 28, 2021 at 10:13 AM
    remington351
    remington351 New Member
    2006 SR5 DoubleCab
    Careful with that pic, des2mtn. You're getting awfully close to Professional Hand Models turf...
    N84434, bmf4069 and FirstGenVol like this.
  4. Sep 28, 2021 at 10:15 AM
    jerryallday
    jerryallday New Member
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    I used two screw drivers to pry them back and then used a c-clamp
  5. Sep 28, 2021 at 10:32 AM
    Retroboy1989
    Northern Utah
    I'm a fan of cracking open the bleeder to reset the calipers. It requires much less force to move the pistons and it keeps you from pushing cooked brake fluid backwards through the system. Gravity bleed for a minute or two to make sure you didn't introduce air into the calipers. Top off with new fluid.
    Another benefit is that it makes multi piston calipers more manageable. You don't end up playing whack-a-mole with the pistons.
  6. Sep 28, 2021 at 10:38 AM
    KarmaKannon
    KarmaKannon Master of None
    Utah
    2006 Double Cab w/long travel
    Some junk
    Aren't they two piston calipers? I believe they are. If that's the case you need to be careful pushing one piston in because the other one will push out and if I recall that can make it pop past the ring or something.
    I have used welding style clamps before. You just work the two pistons a little at a time going back and forth. It's easy peasy.
  7. Sep 28, 2021 at 10:40 AM
    des2mtn
    Shady Grove
    Tonto cover
    Yeah, they're two piston calipers. That's why I recommended re-using the old brake pad and center the clamp instead of using the clamp on the pistons themselves.
  8. Sep 28, 2021 at 10:54 AM
    KarmaKannon
    Utah
    Some junk
    Makes sense. I've never tried that but it seems like it would work nicely.
    des2mtn[QUOTED] likes this.
  9. Sep 28, 2021 at 11:03 AM
    Aren't they 4 piston calipers?
    landphil likes this.
  10. Sep 28, 2021 at 11:06 AM
    des2mtn
    Shady Grove
    Tonto cover
    Yes, two on each side of the rotor.
  11. Sep 28, 2021 at 11:13 AM
    Wahayes
    Will
    2017 tundra limited *sold*
    This is the method I use
  12. Sep 28, 2021 at 1:48 PM
    KarmaKannon
    Utah
    Some junk
    And here's me remembering I did new pads and calipers 2 years ago. They even look good still. How I forgot they were 4 piston...
  13. Sep 29, 2021 at 10:19 AM
    Nobody's gonna mention you gotta turn the rotors or replace them if you're putting in new pads? Just in case?
    Retroboy1989 likes this.
  14. Sep 29, 2021 at 10:49 AM
    Yup, that's is what I usually do. I flip the rotor around 180º, mounting it backwards. Literally haven't had to change my brake pads since, the caliper doesn't even make contact with the rotor anymore.
    (j/k kids, don't try this at home. yes, I know what turning rotors means. if you're going to do that @ every pad change, why not just get new rotors and pads at same time?!)
    landphil and bmf4069[QUOTED] like this.
  15. Sep 29, 2021 at 10:49 AM
    Baller
    Baller New Member
    '05 Tundra SR5 DC
    I may go against the grain here but, I've never done this. If my rotors have warped, it makes no sense to me to have them turned. If they warped, they'll warp again under less heat and load when you take material off them. If they're not warped, the new pads shouldn't have a problem bedding on a plumb rotor. If I have a warped rotor, I just buy a new one. In fact, I usually just buy a pair and do both sides.
    shifty` and bmf4069[QUOTED] like this.
  16. Sep 29, 2021 at 10:53 AM
    I concur. I usually just buy new rotors when it's time to change pads. It's just less of a hassle and they're cheap enough.
  17. Sep 29, 2021 at 8:55 PM
    Retroboy1989
    Northern Utah
    Shaking brakes: new rotors
    Smooth brakes: turn rotors
    Rear brakes: dealer's choice
    I'm becoming a fan of buying oe replacement powerstop kits on rockauto.com. Less than $100 per axle for decent parts is tough to beat.
  18. Sep 29, 2021 at 10:01 PM
    Sirfive
    Sirfive Socially feral
    ‘02 Limited AC TRD
    Bassani cat-back
  19. Sep 29, 2021 at 11:55 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    One way to do it I guess… I just use old pads abs 2 flat heads to pry the caliper open. Works all the time
    des2mtn likes this.
  20. Sep 30, 2021 at 12:05 AM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    I was checking all the pistons to see if any were sticky.
  21. Sep 30, 2021 at 7:48 AM
    And what, may I ask, have you been doing with those to make them sticky? :monocle:
  22. Sep 30, 2021 at 7:56 AM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    I’ll have to ask grandpa. When i got the truck the brakes were dragging. I wouldnt have minded getting some of those racecar red calipers, but when i checked em they were fine.
  23. Sep 30, 2021 at 8:44 AM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
  24. Sep 30, 2021 at 10:37 AM
    Y'all and your fancy clamps. I just use the 480s.
  25. Sep 30, 2021 at 12:24 PM
    Retroboy1989
    Northern Utah
    All you need to work on Toyota brakes. Take the C clamp if you have to choose just one.
  26. Sep 30, 2021 at 12:25 PM
    Who makes the yellows? I only have blue handled
  27. Sep 30, 2021 at 12:55 PM
    Klein tools are typically yellow-handle IIRC. Not saying that's what it is, but most hinged Klein tools I own have yellow rubbers.
    EDIT: Just realized he said they were 480s. Maybe they're Channellocks, then.
  28. Sep 30, 2021 at 6:10 PM
    Yeah, they're kleins. It's just easier to go with channys size since most know what that means. Like if I said I need some nm-b cable very few would know wtf that was, but if I said I need romex....
    shifty`[QUOTED] likes this.
  29. Sep 30, 2021 at 6:19 PM
    Sooo you need some ramen?
    bmf4069[QUOTED] likes this.
  30. Sep 30, 2021 at 6:22 PM
    CTundraForMe
    CTundraForMe New Member
    Two C-clamps with the old brake pads (did mine 2-3 months ago). While I concur with the bleeding the brake idea at the same time, make sure you have a good way of catching that fluid. The kit I got works fine ... if you hold the hose on the nipple. Hard to do that while holding the caliper while compressing two C-clamps.
    (Another set of hands would help immensely.)
