Front brake issues.
Discussion in '1st Gen Tundras (2000-2006)' started by John02, Sep 27, 2021.
  1. Sep 27, 2021 at 8:30 AM
    John02
    John02 [OP] New Member
    2002 Tundra SR5 4.7L TRD Access Cab
    None
    Front brakes keep freezing up tight. Brake pedal won’t move an inch! Have to sit for 10 to 15 minutes before the brakes will release. What’s causing this??
  2. Sep 27, 2021 at 9:01 AM
    I take it you already checked the lines and hoses for kinks? Sounds like something is pinched somewhere, not allowing the pressure to release at the caliper.
    We also have zero idea where you live, and if you're in the rust belt, rust and corrosion could be a factor here. Seized piston, rusty caliper hardware etc.
  3. Sep 27, 2021 at 9:10 AM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    Toyotas are notorious for seized calipers. Check that first
    Rodtheviking and KNABORES like this.
  4. Sep 27, 2021 at 9:57 AM
    xtyfighterx
    xtyfighterx New Member
    Ty
    North Idaho
    2015 Black Crewmax Mid Travel
    Agreed with above post my initial thoughts
  5. Sep 27, 2021 at 11:06 AM
    Rodtheviking
    Rodtheviking New Member
    Vancouver, WA
    Sequoia
    Yup, the lower piston likes to get stuck.
  6. Sep 27, 2021 at 8:52 PM
    NickB_01TRD
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    Could be bad soft lines going to caliper. Would be cheapest thing to try first. Sometimes they go bad and let fluid in but will not let fluid out.
