Is a 2.25 Readylift required if I go from 255/70R18 to 285/75R18?
Discussion in 'Wheels & Tires' started by Sappj, Sep 27, 2021.
  1. Sep 27, 2021 at 9:52 AM
    Sappj
    Sappj [OP] New Member
    I just got a new 2020 Tundra and I want bigger tires. The level kit w/ installation has a cost of $483. Is a 2.25 Readylift required if I go from 255/70R18 to 285/75R18?
  2. Sep 27, 2021 at 10:04 AM
    PermaFrostTRD
    Northern NY
    Not if you're comfortable with a sawzall / angle grinder and some welding.
    Sappj[OP] likes this.
  3. Sep 27, 2021 at 11:09 AM
    GT87
    GT87 New Member
    Greg
    Western NY
    White 2021 SR5 O/R CM
    295/60r20 Toyo ATIII, 20x9 XD 820, 3/1 ReadyLift Carven Exhaust
    Thats almost a 35" so you'd probably at the very least have to remove the front little mud flap, trim the skid plate and mess with the front bumper liner. Depends on the wheel offset as well. Stock wheels?
  4. Sep 27, 2021 at 11:33 AM
    Sappj
    Yes, I plan on keeping the stock 18" wheels.
    GT87 likes this.
  5. Sep 27, 2021 at 11:40 AM
    GT87
    GT87 New Member
    Greg
    Western NY
    Sappj[QUOTED][OP] likes this.
  6. Sep 27, 2021 at 12:04 PM
    2mchfun
    I have a 3" lift w/ SPC UCA's, also plan same size tire and rim. Discount has said if they don't fit, I don't pay. Others here said they will fit. My UCA's protrude more than stock and that is my concern. I know it will be very close, if between an 1/8" and a 1/4" minimum clearance I will run them. Already have aftermarket bumper here so my case is a bit different. But based on what others here said I think you will be fine. Check your tire shop for the policy if they don't fit.
