Payload doesn’t seem to be an issue here…
Discussion in '2.5 Gen Tundras (2014-2021)' started by Oey12, Sep 27, 2021.
  1. Sep 27, 2021 at 11:58 AM
    Oey12
    Oey12 [OP] New Member
    Joey
    New York
    2020 SR5 TRD OFFROAD
    I just had to snap a picture.E98670C9-42E1-423C-A9F6-6F1E14FB57FA.jpg It definitely had some type of weight assistance in the rear because it had more rack than stock with the trailer attached. Craziness…IMHO. And what is the average weight of two horses?
  2. Sep 27, 2021 at 12:01 PM
    773_eddie
    773_eddie Trd Pro
    Eddie
    Chicago
    Tundra Trd Pro
    12volt remote start, weathertec accessories, Trd Pro decals, Toyota console safe,VLEDS Puddle Lights,Frac Harness,TRD PRO front and Rear Sway Bar,NSV Hood Light Bar,ESP long box,AJT accessories,Thinkware U1000 dashcam, coachbuilder 1/3 Lift, HR LED’s,Pro comp Traction bars, JL complete System wit 2 10” subs, Kenwood DDX9907XR HU
    The white Tundra’s have higher payloads than any other Tundra
    Sumo91, boostedtrdpro, Bammer and 9 others like this.
  3. Sep 27, 2021 at 12:06 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    :rofl::rofl::rofl:
    Oh, you were serious?!?
    Sumo91 and 773_eddie[QUOTED] like this.
  4. Sep 27, 2021 at 12:11 PM
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
    I knew there had to be a logical reason why someone would buy that color. :anonymous:
    Armstrs, Vuducrumax, Darkness and 2 others like this.
  5. Sep 27, 2021 at 12:13 PM
    sbxx312
    sbxx312 New Member
    2018 Tundra, 2012 s/c Tacoma
    If I have to own a white Tundra, I'm not getting the horses.
    Darkness likes this.
  6. Sep 27, 2021 at 12:14 PM
    White Tunny's can handle pretty big horses when it comes to towing...................
    HulkSmurf14, Darkness, Mater and 4 others like this.
  7. Sep 27, 2021 at 12:24 PM
    Oey12
    Joey
    New York
  8. Sep 27, 2021 at 12:35 PM
    Oey12
    Joey
    New York
    Very true but the trailer has to be 5k at least?
  9. Sep 27, 2021 at 12:36 PM
    SLA10
    SLA10 New Member
    2019 Tundra TRD Pro
    Most likely running air bags.
    Occidentalis likes this.
  10. Sep 27, 2021 at 12:40 PM
    sbxx312
    sbxx312 New Member
    Didn't you see the commercial? It can pull the space shuttle. Horses shmorses.
  11. Sep 27, 2021 at 12:49 PM
    ShreveportTSS
    ShreveportTSS Huh?
    Eric
    Louisiana
    2018 5.7 4x4 Crewmax TSS
    Depends on the breed. 800-1200lbs for normal working horses. Draft horses can get pretty heavy at around 2000. That Tundra is probably rated at 9,400. As far as GVWR, depends on how he has the weight balance.
    Oey12[OP] likes this.
  12. Sep 27, 2021 at 12:56 PM
    mountainpete
    Ok - so let's just say that it's a 1000 lb horse. They can each carry a human with some gear right? About 250 lbs worth? So:
    Curb Weight: 1000 lbs
    Payload: 250 lbs
    GAWR (gross animal weight rating): 1250 lbs
    Now let's say that trailer has 3 horses in it. That white Tundra and trailer combination just gained 750 lbs of available payload!
    Internet maths are awesome.
    Sumo91 and Wrongside like this.
  13. Sep 28, 2021 at 10:08 AM
    pman9003
    pman9003 New Member
    2020 Platinum 4x4
    Fun fact: White paint is actually lighter than other colors.
    That's why most commercial airlines use white as the base coat on their planes. Many factory race cars (think GT3/4 and similar series) also primarily offer the cars in white for this reason. Long Road Racing, which formerly built the Global MX-5 Cup cars I believe mentioned it saved like 10-15lbs by starting with a white car.
    Bammer likes this.
  14. Sep 28, 2021 at 10:48 AM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    unfortunately payload and safe towing do not mean much to many people
    211188d1501487890-riding-bump-stops-mean_e93a796b50040312c02090402a44568a30e17a2d.jpg
  15. Sep 28, 2021 at 10:51 AM
    sportbikenut
    sportbikenut New Member
    Chuck
    Pittsburgh Region, PA
    2021 Tundra Limited DC MGM 4x4 (New Oct 2021)
    Traded in 2016 Tundra Limited DC Silver 4x4
    Toyota as compared with other mfts appears to conservatively under-rate the payload numbers. I see more Tundra's exceeding then within the official limits. Look at the over-engineered components compared with half tons from Chevy, Ford and Ram. No comparison. And the others usually have higher official payloads. Ford gets away with it with their aluminum lighter components. But its not as planted and stable. IMO of course.
    HulkSmurf14 likes this.
