2018 sr5 tundra drive shaft greasing
Discussion in 'General Tundra Discussion' started by Kalashnikov 47, Sep 23, 2021.
  1. Sep 23, 2021 at 4:27 PM
    Kalashnikov 47
    Kalashnikov 47 [OP] New Member
    Minnesota
    2018 Sr5 double cab gang
    Does anyone know, did toyota stop putting grease fittings on the drive shafts on 2018 tundras? I went from a 2015 to a 2018 was going to grease up the drive shaft and didn't see any zerk fittings at all on my 2018 sr5 at all
  2. Sep 23, 2021 at 4:32 PM
    THinTX
    THinTX New Member
    Tony
    2018 MGM DC 4X4
    I don’t have any on the rear driveshaft, but the front driveshaft does.
  3. Sep 24, 2021 at 3:55 AM
    BrakeDust
    BrakeDust New Member
    Hill Country, TX
    2021 CM SR5 4x4 Magnetic
    I don't have any on front or rear shaft - 2021. My 2008 had them on both.
  4. Sep 24, 2021 at 5:29 AM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    My 21 has none
  5. Sep 24, 2021 at 6:49 AM
    wmchaseb
    wmchaseb New Member
    Chase
    Louisiana
    2018 Plat MGM
    my 18 has none
  6. Sep 25, 2021 at 11:12 PM
    737fixer
    737fixer New Member
    Somewhere in mid 2018 they made the change. Seems I've heard a bunch have a mixture but I think by 2019 they were all sealed driveshafts. This of course led to several threads of the people freaking out cause they could not grease there driveshafts leading to the planet exploding. Not to worry as at the risk of causing another s&%tstorm the sealed units are considered superior to the older unsealed joints (Search "Driveshaft Universal Joint: Greaseable Vs Sealed" and you'll get some information. Now also understand this is now becoming an industry standard and the Tundra never had an issue with there driveshafts but many trucks did.
  7. Sep 27, 2021 at 4:39 AM
    Bammer
    Monroe, CT
    My 2019 says to lube the propeller shaft, what the heck is that?
  8. Sep 27, 2021 at 5:15 AM
    Spyker
    Spyker I’m a dude,playin a dude,disguised as another dude
  9. Sep 27, 2021 at 5:36 AM
    Bammer
    Monroe, CT
    On the "TO DO" list for tonight !:D
  10. Sep 27, 2021 at 7:59 AM
    WhyW8
    WhyW8 “It’s ALWAYS Loaded”
    HB
    Sunny AZ
    2017 Super White SR5 CM
    Level Kit, DiamonBack Tonneau, Step Boards, Alpine Amp, Cerwin Vega powered Sub
    my 2017 has no zerks on the rear driveline
