First Off-road Trip - First “Maintenance Required” Alert
Discussion in '2.5 Gen Tundras (2014-2021)' started by W3agle, Sep 27, 2021.
  1. Sep 27, 2021 at 7:37 AM
    W3agle
    W3agle [OP] New Member
    San Diego, CA
    2016 White Tundra SR5 TRD Off-Road
    I’ll definitely be taking to a mechanic. I don’t have enough info to sort out the cause here. This thread will document what went wrong and how I fixed it.
    For now, I’m still on the road for work. Is there any way to know how urgent this “Maintenance Required” alert is? I’ll be driving a little bit all week, and then on Friday I have about 140 mile drive home. I don’t want to take it to a new mechanic here, but if it’s possible I’m doing lasting damage I can change priorities.
    I did some pretty rough off roading. Maybe what some might call rock crawling. Used the rock sliders a couple time. No big hits other than that.
    Thoughts and input welcome!
  2. Sep 27, 2021 at 7:39 AM
    BIGUGLY
    BIGUGLY I the SheepDog. I have the capacity for Violence.
    Paul
    2018 Limited
    Possibly just need oil changed, if it's due that light can come on
    W3agle[OP] likes this.
  3. Sep 27, 2021 at 7:39 AM
    Elduder
    Elduder New Member
    It means its due for maintenance. Nothing is wrong.
    This is an interval triggered message that is reset at preventative maintenance so it will expire roughly 5k miles after reset.
    W3agle[OP] and Sunnier like this.
  4. Sep 27, 2021 at 7:40 AM
    CNE0207
    CNE0207 New Member
    Arvada, CO
    2020 Cement CM Limited
    Is it just the oil change reminder?
  5. Sep 27, 2021 at 7:40 AM
    PermaFrostTRD
    Northern NY
    Thats the same "alert" that appears to remind you of Service intervals. (Every 5K for tires, 10k for Oil changes). How long have you had the truck?
  6. Sep 27, 2021 at 7:42 AM
    41bigdawg
    41bigdawg Let the BIG DAWG Eat
    Robert
    Tennessee
    2013 Tundra DC 5.7
    Magnum front, Iron Cross rear bumpers, SB Cold air intake and Gibson Metal Mulisha exhaust, Fender flares, Tow mirrors, 18" Outlaw wheels, 12k Smitty X2O winch, Tech 12v auto start, Firestone Air Bags, Pedal Commander, Devil Horns, etc...
    That is your Oil Change indicator that comes on every 5000 miles. You just need to reset it unless you haven't changed the oil recently.
    How to Reset Maint. Required Light on a Toyota Tundra
    1. Turn your key to the "On" notch, and press your trip odometer knob until "Trip A" is displayed.
    2. Turn your key to the "Off" notch. Press and hold the trip odometer knob. ...
    3. Wait for the system to reset. ...
    4. Release the trip odometer knob when "Trip A" is displayed again.
  7. Sep 27, 2021 at 7:50 AM
    2mchfun
    If the fluids are good and belt isn't broke. Watch guages and drive on.
  8. Sep 27, 2021 at 8:46 AM
    W3agle
    San Diego, CA
    Thank you all so much for putting my mind at ease! All gauges and indicators look good. just had an oil change about 1000 miles ago so no problems there. I’ve owned the truck about 5000 miles now.
    41bigdawg likes this.
  9. Sep 27, 2021 at 9:01 AM
    TexAggie
    TexAggie New Member
    Eric
    2017 CM
    Sounds like people who did your oil change forgot to reset the truck.
  10. Sep 27, 2021 at 9:03 AM
    PermaFrostTRD
    Northern NY
    That's what it is - whoever did your oil change didn't reset the notification system. Definitely a YouTube or some info in the forum on how to reset on your own (likely a combo of turning the key and pumping the brake pedal).
    Enjoy the new (to you) truck!
    W3agle[QUOTED][OP] and WILLINH like this.
  11. Sep 27, 2021 at 9:07 AM
    AZBoatHauler
    So.Arizona
    Key on - press the button on your dash cluster to change ODO to trip A. Key off. Hold down button on dash cluster and flip key on. Continue to hold button until countdown display clears from ODO. You’ve reset your maintenance reminder.
