Front brakes dragging 2006
Discussion in '1st Gen Tundras (2000-2006)' started by moericke, Sep 26, 2021.
  1. Sep 26, 2021 at 10:45 AM
    moericke
    moericke [OP] New Member
    2006 Tundra Lucchese Edition
    Greetings all! Sorry if this is redundant but I've searched other posts and could not find an answer.
    The front brakes are dragging on my '06 Double Cab Limited, specifically the right front. I have replaced both calipers, rotors, and pads but the problem seems to persist. I only notice it when travelling at highway speeds. The truck feels sluggish and when I lightly tap the brakes they immediately respond as if the are already partially activated. After tapping the brake pedal, it returns to normal until I have to brake again. Could this be faulty brake lines? I have read in other threads about the inside of rubber lines breaking apart and possibly causing the fluid not to release back into the system. I can't imagine what else it could be. Thanks in advance for your help!
  2. Sep 26, 2021 at 12:00 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    An incorrectly adjust master cylinder can also cause this. But not likely unless you replaced it recently and it wasn't installed correctly.
    moericke[OP] likes this.
  3. Sep 26, 2021 at 2:08 PM
    Did you happen to bleed the brakes BEFORE you installed new calipers? I've heard it's best to do this so you aren't pushing old gunky fluid into brand new calipers. I'm just wondering if you have some debris in there making the new brake pistons stick. Seems less likely though. Google does say a worn out brake hose can cause this but I've never heard of this. Might be worth upgrading to stainless steel hoses which many of have done.
    moericke[QUOTED][OP] likes this.
  4. Sep 26, 2021 at 2:20 PM
    moericke
    I bled them after installing but made sure I pushed new fluid thru them before actually driving on them. Where does one get stainless steel lines?
  5. Sep 26, 2021 at 2:34 PM
    These are what I ordered but there are other options out there.
  6. Sep 26, 2021 at 5:12 PM
    N84434
    N84434 In the Frozen Tundra
    Milwaukee WI.
    2001 Limited TRD
    This was going to be my suggestion as well. Stainless lines make a very big difference with braking. Does the OP have ABS on the truck?
  7. Sep 26, 2021 at 5:44 PM
    NickB_01TRD
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    I agree with all the posts about bad brake soft lines. Especially if you were to pinch them shut during the caliper change. The hoses can act like a check valve and let fluid in the calipers but not let the fluid back out. I haven't tried the stainless lines myself but if you don't want to spend as much the rubber ones seem just fine and that's what I did recently on my truck.
