Crackhead resurrection
Discussion in '1st Gen Tundras (2000-2006)' started by Tundra2, Aug 23, 2021.
  1. Sep 26, 2021 at 4:51 AM
    #721
    Tundra2
    Tundra2 [OP] Zoinked
    Noah
    Western Kentucky
    Is there a test for it on the FSM or do you think it's just the connector being damaged?
  2. Sep 26, 2021 at 4:52 AM
    #722
    Tundra2
    Noah
    Western Kentucky
    Took a break to schmoke, sip coffee, and take in the view.
  3. Sep 26, 2021 at 5:05 AM
    #723
    Tundra2
    Noah
    Western Kentucky
    Spec'd temp on mini-t-stat is 83°C.
  4. Sep 26, 2021 at 5:50 AM
    #724
    I wonder what all that shit is thats packed in those lines...
    Tundra2[OP] likes this.
  5. Sep 26, 2021 at 5:53 AM
    #725
    Tundra2
    Noah
    Western Kentucky
    Pulled the trigger on Throttle body clean up. Pulled the 21mm cap off directly underneath the engine cover mount. Gnarly.
    Cleaned out with brake kleen. Good enough for water flow now, and soon to be radiator flush... Golly Gee, I sure hope my engine drains on the bottom aren't frozen....
    Cleaned up the oil residue on the TB while I had it out.
    Reinstalled mini-t-stat thingy majigger.
    Need new hoses for the mini-t-stat. Anybody with a computer that can pull up exploded links, and supply part numbers? You will have my eternal gratitude. If it didn't have all them complex bends, and shit I'd just use regular hose.
    N84434 likes this.
  6. Sep 26, 2021 at 6:07 AM
    #726
    Tundra2
    Noah
    Western Kentucky
    Currently 48°F here. Assuming everything is ambient temp, ECT sensor checks as good per the FSM. I guesstimated that the reading would be around 3.5k-ohms.
    I'm calling it good, and ruling the connector as my problem. Among the raunchy cooling lines...
    N84434, Lil Steve and FirstGenVol like this.
  7. Sep 26, 2021 at 6:27 AM
    #727
    Tundra2
    Noah
    Western Kentucky
    Was putting the TB water line back on, and it split on me. Making due with silicone for now...
    Really need to order this part, or get @lsaami's.
    See the impression in the hose by my middle finger. Wondering if that's where the the hose clamp was, and thats why it was such a mess. Not squeezing enough on the hose barb.
  8. Sep 26, 2021 at 6:32 AM
    #728
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
  9. Sep 26, 2021 at 6:41 AM
    #729
    Tundra2
    Noah
    Western Kentucky
    NUDRAT likes this.
  10. Sep 26, 2021 at 6:44 AM
    #730
    Tundra2
    Noah
    Western Kentucky
    Anyone got any idea where I can order just the astic connectors listed above?
    Need one for the ECT, and one for the throttle body connector thingamajig Perhaps @empty_lord could point me in the right direction.
  11. Sep 26, 2021 at 7:09 AM
    #731
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    You have to find the part number on the connectors and have a dealer order the connector off those
  12. Sep 26, 2021 at 7:18 AM
    #732
    Tundra2
    Noah
    Western Kentucky
    Fuck. That sounds next to impossible with my redneckistan computer set up.
  13. Sep 26, 2021 at 7:19 AM
    #733
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    bmf4069, shifty`, Lil Steve and 2 others like this.
  14. Sep 26, 2021 at 7:20 AM
    #734
    Tundra2
    Noah
    Western Kentucky
    Whatever this shit is, it's packed in plumb full.
    Line above is the one connected to the backside of the cooler which can be seen in the image of the cooler.
  15. Sep 26, 2021 at 7:21 AM
    #735
    Tundra2
    Noah
    Western Kentucky
    NUDRAT likes this.
  16. Sep 26, 2021 at 7:24 AM
    #736
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    Thanks but you need to spend all your extra money on @TundraGirl2 for putting up with your ass :hattip::cool::D
  17. Sep 26, 2021 at 7:25 AM
    #737
    Tundra2
    Noah
    Western Kentucky
    She's actually asleep so no need in putting up with me currently, but yes. Once this horrendous timing belt job is done, it will be date night for sure. I'll pull out all the stops. She will have earned it.
  18. Sep 26, 2021 at 7:44 AM
    #738
    That is so weird. The oil cooler is fairly critical right? I wonder how it was running. I wonder what you would find if you removed a valve cover.
  19. Sep 26, 2021 at 7:54 AM
    #739
    Tundra2
    Noah
    Western Kentucky
    Now this is happening!
    Some brake kleen, and a pressure washer later I have flow through the cooler.
    I think I fucked up some o-rings or seals in it.
    Got a chunk out.
    Guess this one is Fubar?
    shifty` likes this.
  20. Sep 26, 2021 at 7:59 AM
    #740
    Tundra2
    Noah
    Western Kentucky
    Like you said earlier Erik.
    NUDRAT and FirstGenVol[QUOTED] like this.
  21. Sep 26, 2021 at 8:08 AM
    #741
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    One more grasshopper and I'll let you learn the EWD I posted earlier for your 2000. It's Ryder Cup time for me....U S A ....U S A....U S A
    Look for Part Number of Connectors starting on page 250, alphabetically find Throttle Control Motor which is connector T1.... 90980−10942
    Somewhat verify by searching the pdf for Throttle Control Motor only 6 results to look at and the one below matches the color of the conductors and connector color(gray) posted in your pic.
    Tundra2[QUOTED][OP] and shifty` like this.
  22. Sep 26, 2021 at 8:12 AM
    #742
    empty_lord
    05 rollover special
    Don’t run that one longer term because it’s running the possibility
    Of mixing coolant and oil.. you don’t want that
    Tundra2[QUOTED][OP] likes this.
  23. Sep 26, 2021 at 8:17 AM
    #743
    Tundra2
    Noah
    Western Kentucky
    I won't run it all then. I'll wait on @lsaami or order newness.
  24. Sep 26, 2021 at 8:42 AM
    #744
    Tundra2
    Noah
    Western Kentucky
    Removed AC compressor again. Supported by milk crate.
    Removed coolant line from drivers side block to oil cooler. HAPPILY, a bunch of old, nasty fluid came out of the block which means there's very little bull shit inside!
    Did a cross-section of the hose I'm replacing.
    I just don't understand how this happens.
    N84434 and NUDRAT like this.
  25. Sep 26, 2021 at 8:45 AM
    #745
    NickB_01TRD
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    Seeing this makes me wonder if someone put stop leak in this thing and its gonna have bigger problems later. I hope not though. Hopfully it's just never had a coolant flush and they've been putting an incompatible coolant in there for a while.
    w666 and Tundra2[QUOTED][OP] like this.
  26. Sep 26, 2021 at 8:55 AM
    #746
    empty_lord
    05 rollover special
    Honestly looks like they put dex cool in it.. which is a BIG no no
  27. Sep 26, 2021 at 8:59 AM
    #747
    Tundra2
    Noah
    Western Kentucky
    So here's the hose barb on the block. Drivers side.
    NUDRAT likes this.
  28. Sep 26, 2021 at 8:59 AM
    #748
    I'm not sure if we've tagged @lsaami enough in the last 24 hours so here's one more.
    bmf4069, N84434, shifty` and 3 others like this.
  29. Sep 26, 2021 at 9:00 AM
    #749
    Tundra2
    Noah
    Western Kentucky
    How bad is it? Like am I mega fucked, or am I still in OK situation as long as I so all the purging, and what not.
  30. Sep 26, 2021 at 9:00 AM
    #750
    Is that to drain the coolant, or just a place where a hose connects? The coolant drains on my block are brass.
