Upgrading factory backup camera?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Handbanana, Jul 22, 2021.
  1. Jul 22, 2021 at 4:20 PM
    Handbanana
    Handbanana [OP] New Member
    2018 TSS CM 4x4
    Trd sway front Trd sway rear Trd shift knob Nitto ridge grapplers OEM LED FOGS
    Has anyone upgraded their factory back up camera? I have an aftermarket head unit halo9 to be exact and it still has the guidelines which interfere with the head unit guidelines that can be adjusted. I don’t mind running new wires to the head unit but would prefer to find a plug and play unit that has better clarity and definition compared to OEM.
  2. Jul 22, 2021 at 7:11 PM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    The camera isn't the issue...the screen is not High Definition...it has the dpi of an elementary school laptop...upgrade you HU and you will immediately notice a vast improvement...spend well buddy
    BLONGTX, KK6PD and WILLINH like this.
  3. Jul 22, 2021 at 7:47 PM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    He did…
    1lowlife and HulkSmurf14[QUOTED] like this.
  4. Jul 22, 2021 at 8:49 PM
    HulkSmurf14
    2014 Tundra Limited
    Damn, did I say that out loud? My ability to not have my inner-monolog audible is failing :monocle:
  5. Jul 22, 2021 at 8:50 PM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
  6. Jul 23, 2021 at 6:34 AM
    Handbanana
    2018 TSS CM 4x4
    So…surely someone has done it.
  7. Jul 23, 2021 at 6:42 AM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Wasn’t laughing at you, OP. Hopefully someone has a good answer for you, but I think the mounting of the camera is the limiting factor here. I’ve never had a reason to tear into the tailgate handle, though, so I could be wrong.
  8. Jul 23, 2021 at 6:58 AM
    Handbanana
    2018 TSS CM 4x4
    Apparently there is a wire that you can cut on the camera and it will help get rid of the guidelines, if I could do that then I would be cool keeping the factory camera because I would get the full view without distortion of lines.Cleaner image; bigger picture. I just need to find out which wire that is so I can cap It off. Then I can play with the camera settings on the head unit and set it to my liking. Those guidelines are useless unless they are actual park assist lines that move with the steering wheel then they really don’t help especially when hitting up a trailer because the line is not where it needs to be
    TRDFerguson[QUOTED] likes this.
  9. Jul 23, 2021 at 7:00 AM
    jpod
    jpod its Finally here
    London Canada
    2020 Tundra CM Cement Grey
    Diamondback HD, 1Up Racks, Yakima Bars, Garbage Weston Steps
    I'd be more interested in an aftermarket video rear view mirror with the camera mounted above the cab (integrated with the gps antenna would have been good) so I could see over all the crap I'm hauling. The bike racks and roof box murders my rear view and sticks out about 5 feet behind the truck. Backing up when you can't see sucks.
    HulkSmurf14 likes this.
  10. Jul 23, 2021 at 7:05 AM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    https://www.tundras.com/threads/ultimate-wiring-diagrams-collection.81448/#post-2058879 Check out this thread. I can dig later when I’m at my computer, because now I’m curious too.
  11. Jul 23, 2021 at 7:05 AM
    Handbanana
    2018 TSS CM 4x4
    With the alpine halo nine you can just get the alpine AV switch your module and I think you can have up to like four cameras that you can switch on the head unit. A 360 camera would be ideal also for the rear or truck bed
  12. Jul 23, 2021 at 7:08 AM
    Handbanana
    2018 TSS CM 4x4
  13. Jul 23, 2021 at 7:09 AM
    Handbanana
    2018 TSS CM 4x4
  14. Jul 23, 2021 at 7:23 AM
    1lowlife
    1lowlife New Member
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    My Kenwood HU has it own lines, I just turned them off.
    But I can understand why you'd rather use the Alpine lines.
    Keep us posted on what you decide to do and how it turns out.
    This may or may not help you.
    Camera schematics for JBL and non-JBL Entune HUs, they look the same to me.
    You'll just need someone smarter than me to tell you what wires (CA+, V+, V- and CGND) do what, I'd guess GND is ground.
    Non-JBL
    JBL.
    TRDFerguson likes this.
  15. Jul 23, 2021 at 7:45 AM
    Handbanana
    2018 TSS CM 4x4
  16. Jul 23, 2021 at 7:47 AM
    Handbanana
    2018 TSS CM 4x4
    Cv+\- is camera voltage CGND camera ground but not sure about CURT or CB+? Anyone? Maybe one of those is the lines. This really sucks because I’m a control technician by trade and I can’t figure it out
    1lowlife likes this.
  17. Jul 23, 2021 at 9:09 AM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    CURT is just another ground from what I can tell, unless that's the loop that triggers the guide lines. CB+ should be the power signal from the reverse lights that turns on the camera, as I don't think it has constant power. If I have some time today I might open up my tailgate and poke around with a multimeter.
  18. Jul 23, 2021 at 10:32 AM
    Handbanana
    2018 TSS CM 4x4
    It could be that CB is like the remote turn on on a amplifier yet you have 12 V positive and negative constantly connected but doesn’t actually turn on unless it gets a signal from the perverse light so maybe it is just part of the camera. This is the cheapest way for Toyota to have a camera and provide guidelines that can be universally used on all Toyota vehicles.
  19. Jul 24, 2021 at 8:39 AM
    Handbanana
    2018 TSS CM 4x4
    Would be nice to get rid of lines. Lol
  20. Jul 24, 2021 at 10:15 AM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    2023 1794 Edition TRD Package
    Sounds like what I have... camera is above third brake light.
    cowboyjack and jpod[QUOTED] like this.
  21. Sep 25, 2021 at 12:13 AM
    swallace
    swallace Insert profound statement —> here <—
    Steven
    Tri-Cities, WA
    2014 Silver Sky Metallic CM 4.6L 4x4
    6112/5160, DD 10”, Amp steps, Alea leather, more…
    Did anyone ever figure this out? I just upgraded to a Kenwood head unit with dynamic steering guide lines, and I would love to get rid of the factory lines.
  22. Sep 25, 2021 at 11:55 AM
    Handbanana
    2018 TSS CM 4x4
    not yet. But there is no way to get rid of the lines just replace with another camera. Only bad part is you have to run new wires to headunit if you have a aftermarket headunit. The kenwood has the cs710 or something like that and it’s a really good camera. You can also wire the kenwood dash cam to it.
  23. Sep 25, 2021 at 12:43 PM
    danz75
    danz75 New Member
    Everett, WA
    18' Cement SR5
    OEM LED headlights, Rigid SAE foglights, Go Rhino RB10 running boards, ARE Classic CX
    @TucsonTundra1794, if you don't mind me asking, what is the brand of the system you are using and how well has it worked for you? How did you install on the brakelight? I have a shell on mine and am looking to install a camera on the 3rd brake light as well.
  24. Sep 25, 2021 at 3:41 PM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    https://www.amazon.com/dp/B0855GMKMD?_encoding=UTF8
    I also bought this so it wasn't plugged into my 12v socket with an exposed cord.
    https://www.amazon.com/dp/B07FXJD8W1?_encoding=UTF8
    With the hardwire kit I ran the cord down the a pillar and through the firewall and to the battery with the add a fuse attached to the ignition fuse so it comes on when the truck comes on. The mirror also has a built in battery so when it detects movement it will turn on and start recording which is a cool feature. If also recommend getting an SD card because it will need one to store the files.
    Install was simple, 3 wires, one for power which is wired how I said above, next is rear camera which is ran along the headliner on the driver's side and goes through the roof and comes out above the 3rd brake light, If you wanted yours on your topper I would recommend running the wire under the truck and come up inside the bed and attach above the topper from in there. 3rd wire is GPS antenna, the camera monitors speed and distance and you can download all the data on your computer. If you don't need this it will run without the GPS attached. Other then that it's a simple install and no problems or regrets with it at all.
    cowboyjack likes this.
  25. Sep 25, 2021 at 8:03 PM
    swallace
    Steven
    Tri-Cities, WA
    Is there a replacement camera that fits where the OEM camera goes?
  26. Sep 25, 2021 at 10:29 PM
    danz75
    danz75 New Member
    Everett, WA
    18' Cement SR5
    Thanks for the information. I have been looking at that model for awhile but hadn't pulled the trigger because i was sure how well the camera would survive on top of the 3rd brake light. Given your location, I'm assuming you don't have any issues with moisture getting into the camera and the heat hasn't affected the camera either?
  27. Sep 26, 2021 at 11:02 AM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    No issues except for the issues I also have with the factory camera which are water getting on the lenses and distorting the image. Other then that the monsoon season we just had and the extreme heat we have otherwise have not affected the camera at all.
  28. Sep 30, 2021 at 12:37 PM
    jimmyfu
    jimmyfu New Member
    N. California
    2014 Tundra DC SR
    How did you attach the camera if you don't mind me asking? Friction fit and squeeze?
  29. Sep 30, 2021 at 1:18 PM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    The rear camera or the rearview mirror?
  30. Sep 30, 2021 at 5:15 PM
    HulkSmurf14
    2014 Tundra Limited
    It's a camera thread :monocle:
    **again...my inner-monologue is not what it used to be...
