  1. Sep 23, 2021 at 7:27 PM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    Good to know. I honestly never touch my dimmer, so I probably would have never noticed this.
  2. Sep 23, 2021 at 7:32 PM
    DCB500
    DCB500 New Member
    Oklahoma City
    2019 Tundra SR5 TSS Double Cab
    Wheels, sound system, antenna, tailgate letter inserts, Grill/Hood Bulge, Exhaust, Leather
    Gave her a much needed bath - Still has an amazing shine after almost 3 years!
  3. Sep 23, 2021 at 8:04 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    They have two internal LEDs - one is powered by the illumination circuit (the words on the switch) and one is lit by the activation of the switch (the icon on the switch). They both use a common ground, but the switched LED is taking the power source from the power that the switch is turning on (on the load side of the switch).
    The truck illumination circuit sends + and - through the instrument panel dimmer, which is how you get the variable output. I wasn’t interested in sending raw power (even if only 3A) from the switch to the negative side of the illumination circuit and possibly frying my instrument cluster…
    The only way to remove the secondary LED would be to de-solder it from the switch and lose that part of the illumination.
    So far, the ONLY dimmable after market switch I’ve seen/encountered is the one that ABC sell with their Anytime Backup Camera kits, but it isn’t quite the right shade of blue.
  4. Sep 23, 2021 at 8:07 PM
    RainMan_PNW
    Casey
    Clark County, WA
    I notice it only when auto-on headlight sensor will change brightness on the radio based on the ambient light (like going through a tunnel)
    TRDFerguson[QUOTED] likes this.
  5. Sep 23, 2021 at 8:11 PM
    Yzed608
    Yzed608 New Member
    Wisconsin
    Yep, I didn't notice the little nipples either. Here's some pics I took when I took mine apart to help others in the future possibly.
    Also this was the method I used to unhook it, used the short end of an allen to depress the tab.
  6. Sep 24, 2021 at 1:30 AM
    kuokoa
    kuokoa New Member
    Kailua Kona, HI
    2015 Tundra Crewmax BRM
    sorry, yeah, I meant that plastic around the shifter.
    murdered out. I like it.
  7. Sep 24, 2021 at 3:16 AM
    Brettstation37
    Brettstation37 New Member
    Brett
    Catskills NY
    2020 Tundra CrewMax TRD Sport
    rough country 30”…it comes up on there site in the tundra parts
    a522467[QUOTED] likes this.
  8. Sep 24, 2021 at 4:11 AM
    Pillslinger
    Pillslinger New Member
    Rollin
    SWMO
    2018 Cement TRD CrewMax
    Bed light kit Jerry can mount Badge overlays (removed 2021) Pin stripe / TRD decal / pillar vinyl removal Raised tailgate lettering Center console badge/tray/divider Interior/exterior LED upgrade VLED footwells TVD Vinyl TRD Offroad wheels Icon 17x8 rebound titanium Bubbas Garage grab handles WeatherTech floor mats (Eagle Klaw added) Rough country front shackles (removed 2021) DD SS3 yellow fogs MESO map light replacement Softopper MESO Chrome delete
    I hear ya on that. I've had a backflip on since I bought the truck. It was a pretty easy swap and I'm sure I'll go back and forth.
  9. Sep 24, 2021 at 5:10 AM
    parkerbows
    parkerbows New Member
    Jack
    2017 crew max sr5 trd off road
    Firestone air ride air bags
    kuokoa[QUOTED] likes this.
  10. Sep 24, 2021 at 5:15 AM
    parkerbows
    Jack
    smart with the allen wrench. I used a screwdriver from behind on bottom tab. pain in the ass
    Yzed608[QUOTED] likes this.
  11. Sep 24, 2021 at 7:17 AM
    deathorglory75
    deathorglory75 New Member
    New 2019
    only black out emblems, changed to interior led lighting, ajt chrome delete interior, wireless charger, console safe
    Got a long fun day ahead. Will post a before and after picture soon.
    WILLINH, NWPirate, kuokoa and 10 others like this.
  12. Sep 24, 2021 at 7:21 AM
    MikeyRedFL
    MikeyRedFL New Member
    SWFL
    2021 Limited Crew Max 4x4
    Any allergies to cardboard?
  13. Sep 24, 2021 at 7:45 AM
    RoniusMaximus
    RoniusMaximus The One and Only
    J
    Tri-Cities, Washington
    2020 MGM Toyota Tundra TRD PRO
    Synthetic Blinker Fluid
    I removed my Bushwacker Extended Flares that ive had on for about 5 months and added back the OEM mud guards. Thankfully, there was no damage to the paint underneath from the rubbing (Edit: there are some light faint rubbing marks that I can probably buff out).. I have always loved the look of mud guards on a truck and with me committed to keeping the OEM Pro BBS wheels, 1.25" spacers with 295-70-18 tires are as aggressive looking as it gets for me. Had I gone with a different wheel setup with lower offset, I would have kept the flares on. I love how there is a slight poke now with the wheels.
    GAknight, equin, Steve18 and 9 others like this.
  14. Sep 24, 2021 at 7:49 AM
    vl184009
    vl184009 Cheers Boys!
    Vicky
    Southern, Ca.
    2016 MGM CM SR5 4x4 w/Tow Pkg
    Man I love this truck!
    DCB500[QUOTED] likes this.
  15. Sep 24, 2021 at 7:58 AM
    DCB500
    DCB500 New Member
    Oklahoma City
    Thank You ……Appreciate it!
  16. Sep 24, 2021 at 8:12 AM
    RRR1C0
    RRR1C0 New Member
    2014 SR5 TRD CrewMax
    Riding on 275/70R18 Toyo AT3s w/ 1.75” RC leveling kit.
    Looks great! What camper shell is that btw?
    RoniusMaximus[QUOTED] likes this.
  17. Sep 24, 2021 at 8:19 AM
    RoniusMaximus
    J
    Id have to find the receipt to get the model but the brand is Century. Leer has an identical model too as they are made at the same plant.
  18. Sep 24, 2021 at 8:21 AM
    doggiecareman
    doggiecareman YOLO / Best to do it with a Toyota
    Eric
    North Central CT
    Tundra Army Green Limited Double Cab TRD Off Road 2021
    TRD dual exhaust/Factory running boards/center console safe/Truxedo X15 Tonneau/ceramic coated/ceramic window tint/BFG KO2's/swing cases/debadged
    I vote no flares
  19. Sep 24, 2021 at 9:54 AM
    nhw544
    nhw544 Food fight!
    RVA
    2019 Black Tundra 4x4 Sport
    This is the last piece of interior chrome I have to get rid of and I’ve procrastinated because of this very reason.
    Barrett50 likes this.
  20. Sep 24, 2021 at 10:28 AM
    RainMan_PNW
    Casey
    Clark County, WA
    Kinda glad I went with the ME-SO 4WD trim. I don't remember those little springs and detents being part of the dissection process to install it.
    https://mesocustoms.com/collections...ndra-4x4-selector-ring?variant=31289781485681
  21. Sep 24, 2021 at 10:56 AM
    a_double
    a_double New Member
    Attempted to top her off with fuel but sadly couldn’t with these gas prices and cc limits at the pump.
  22. Sep 24, 2021 at 11:54 AM
    MikeyRedFL
    SWFL
    Installed the Truxedo TonneauMate today... Nice easy install.
  23. Sep 24, 2021 at 3:31 PM
    Buckwalleye
    Buckwalleye New Member
    2018 TRD double cab
    Been wanting to do this for a while. Lumber prices finally semi normal again so I banged out this DIY decked system
    GAknight, WFD473, Cosmoblu and 21 others like this.
  24. Sep 24, 2021 at 4:19 PM
    Cl8NL
    Cl8NL Pocket-Sand
    MKE WI
    2017 SR5 5.7 4x4 quicksand dbl cab
    Hit 10k miles yesterday, got her with 8 miles June 9th. Got the 10k service yesterday too and had them change the rear diff fluid as most of the miles so far have been towing 11D31E4F-28E6-4A5D-9E5B-290A0011E215.jpg 5E7EB358-E1F2-4F48-B58A-1BC00877B86A.jpg
  25. Sep 24, 2021 at 7:49 PM
    Beer Man
    Beer Man @cement.tundra
    2021 SR5 XP CrewMax Cement
    SCS Ray 10s
    Matte gray
    Color matched Cement bead lock bolt heads
    275/65/18 Nitto Terra Grapplers
    Undecided on 285/70 or 295/70 coming soon
  26. Sep 24, 2021 at 8:14 PM
    CoachJ
    CoachJ New Member
    J.
    2021 Tundra Trail
    TRD Pro Exhaust Muffler Delete
    washed the Yota gang to start the weekend 2F243B71-220B-41E9-8704-3E36B0F5A57E.jpg
  27. Sep 24, 2021 at 9:18 PM
    Nic146
    Nic146 New Member
    Probably stuck somewhere
    2016 Barcelona Red TRD CM
    I experience a miracle today… :muscleflexing:
  28. Sep 24, 2021 at 10:02 PM
    Bergy24
    Bergy24 New Member
    What gray did you use for you emblems?
  29. Sep 25, 2021 at 4:57 AM
    LarryDangerfield
    Tyler
    Northern Wisconsin
    You just wait
    Me too!
  30. Sep 25, 2021 at 6:22 AM
    normagene
    normagene New Member
    Normagene
    New England
    2021 Cement DC Limited Texas Edition
    Texas Edition
    I used a Plasti-Dip labeled Dark Gray. $6 at Lowe’s.
    I dipped the actual badges and my fender flares on my Tacoma (black) and after 5 years, then traded it for the Tundra, they were still in perfect condition and that includes dozens of washes using my pressure washer. Also dipped the body side moldings on my old Subaru and traded that in for my RAV4 that dip still looked like the day it was applied after 8 years.
    Below is a picture of the Subaru the day before I traded it in and the day I traded in the Tacoma and you can see how well the dip has held up.
    So just saying the dip does hold up and I’ve never had to do any touch ups. Although touch ups are super simple to do if ever needed.
    Cosmoblu, WILLINH, TNTundra16 and 3 others like this.
