side mirrors
Discussion in 'New Member Introductions' started by cruisen63, Sep 23, 2021.
  1. Sep 23, 2021 at 11:54 AM
    cruisen63
    cruisen63 [OP] New Member
    2018 tundra limited double cab
    none
    2018 tundra limited double cab.I want to know if anyone has added side turn signals that have oem turn,heat and bsm.called dealer were i bought it they werant interested in giving me any info on wether its wired for the turn,heat,signal indacator.because there are mirrors on line that sell them identacal to mine.
    RdKing likes this.
  2. Sep 23, 2021 at 4:45 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Welcome from LA (Lower Alabama)! There are a few on the site that have added tow mirrors. Not all of the functions are always available on OEM or aftermarket. Search for tow mirrors on the site and you will find some info.
  3. Sep 23, 2021 at 5:17 PM
    Welcome from NY.
    Doesn't the limited have BSM, turn signals & heated mirrors?
  4. Sep 24, 2021 at 2:17 AM
    cruisen63
    none
    The small mirror has bsm and heat symbol no turn indicator on mirror. Called the dealer they said real fast(speaking)no ,no ahh if it didn't come with it the wiring is not there,click.But I've seen online that the same size mirrors about$500 do have what I want,hesitation to buy and find out that the dealer was right.i had a 2016 tacoma same thing changed mirrors to what I want and they worked so I don't know please help
  5. Sep 24, 2021 at 2:24 AM
    18" TRD Off Road Wheels
    I'm not familiar with everything the Limited has on it, so what features do you already have in your stock mirrors?
    I know that if your truck doesn't already have all those features it can require additional wiring to add what ever is missing. Especially if it's something like the power fold option or BSM.
    To the best of my knowledge there are no OEM mirrors that have all the features you are asking for. I'm not sure I've seen any OEM tundra mirror with a turn signal indicator in the glass. You can get some tow mirrors (aftermarket I think) that have an additional light on the outside of the mirror for better visibility to other drivers, but I don't think any of them maintain BSM.
    Black Wolf likes this.
  6. Sep 24, 2021 at 11:03 AM
    RdKing
    RdKing Not A Roll Model
    Rich
    Eastern Seaboard
    2019 Tundra Platinum 3R3 / Barcelona Red
    Roadtunes By: Taylor's Audio/Tech12Volts Alma GA. JBL Complete System
    Welcome from Delaware
  7. Sep 24, 2021 at 12:56 PM
    RitcheyRch
    RitcheyRch New Member
    Richard
    Santa Clarita, CA
    TRD Lowered and Supercharged
    Welcome from So Cal
  8. Sep 24, 2021 at 1:07 PM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    Welcome from Nevada
  9. Sep 24, 2021 at 1:28 PM
    81 TOY
    81 TOY New Member
    Larry
    Vermont
    2008 Limited Crew Max
    Welcome!
  10. Sep 24, 2021 at 1:48 PM
    ezdog
    ezdog New Member
    Gateway To The West
    2001 RCLB V8,4WD 2015 RCLB 5.7,4WD
    When I stuck the Trail Ridge Tow Mirrors on my SR truck with no mirror features the signalas just worked right out of the box so that tells me that the trucks are wired for that stuff even if you dont have them from Toyota.
    I am also sure that if you do not have BSM that you still wont but of you already do then you likely will with an aftermarket mirror that does.
  11. Sep 24, 2021 at 2:03 PM
    thomasbus337
    thomasbus337 New Member
    2020 TRD Sport DC
    You should be able to swap on a set of Platinum/1794 mirrors and gain the mirror signals. Your truck already has the wiring for the mirror signals in the harness. The only features the Platinum/1794 mirrors have that your truck isn't prewired for would be power fold, auto dim and the puddle lights. All those features could be wired in aftermarket if they are things you didn't know you wanted until now
  12. Sep 24, 2021 at 3:13 PM
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
    All 2014-2021 Tundra are pre-wired in the side mirror harness for power adjust, heating and turn signals regardless if your truck had them originally. Power fold and BSM are only wired in if your truck originally had it.
    If you go to Amazon, etc, and buy aftermarket tow mirrors with integrated turn signals they will work.
    On my 2018 SR5, I was able to add in higher grade side mirrors (I think they came off a Platinum - bought them as new takeoffs) and towing mirrors (mine are OEM) and the turn signals just work. But I had to wire in components to make the Platinum power folding mirrors work. I covered the BSM light with a convex mirror (it's off all the time anyways).
