Chopping your frame
Discussion in 'General Tundra Discussion' started by Eclipsed & Floating, May 9, 2017.
  1. May 9, 2017 at 3:48 PM
    Eclipsed & Floating
    Eclipsed & Floating [OP] Over it.........
    I’m right where I need to be
    Voluptuous Whitey
    My daughter is going to camp up there so I'll probably be taking a little sabatical from life at the same time. Sign me up for a day or two following you around some of that good shit they have in that "terrible" state
  2. May 9, 2017 at 3:52 PM
    Darth Tundra
    Curt
    17 CM TRD Black
    IMG_0241.jpg My old sand toy....I MISS IT BAD
  3. May 9, 2017 at 3:55 PM
    Darth Tundra
    Curt
    17 CM TRD Black
    LOL...Just let me know when and where...
  4. May 9, 2017 at 3:57 PM
    Darth Tundra
    Curt
    17 CM TRD Black
    And my other "ole" stand by"s when i needed a change from the BALLISTIC BANSHEE..IMG_0250.jpg
  5. May 9, 2017 at 5:27 PM
    jberry813
    jberry813 The Mad Scientist Staff Member
    Lake Tahoe
    2015 Tundra Platinum, 2012 Tacoma, 2007 T4R
    Metric shit ton of parts
    Here's the deal. A plasma cutter is an investment just like any other tool. Only you can decide if it's worth it. For me, my time is valuable. I occasionally do fab work on the side, but the majority of it is for me and my rigs. And the time difference between a plasma and...anything else...is absurd. I got my Hypertherm on Craigslist for a screaming deal. But you don't need the a 65 amp plasma for garage stuff.
    Take a look at Lotos plasmas. They are very affordable by comparison. I've used a 5000 on several occasions and it does the job and the consumables are significantly cheaper than Hypertherm's.
    Lotos LT5000D Plasma Cutter 50Amps Dual Voltage Compact Metal Cutter 110/220V AC 1/2" Clean Cut https://www.amazon.com/dp/B004VFJL14/ref=cm_sw_r_cp_api_V0LezbANVTETA
    ColoradoTJ, mdavis and Darth Tundra like this.
  6. May 9, 2017 at 5:38 PM
    n2deep
    n2deep Pavement Princess
    Thats not a bad price - I always have a need for a plasma but never wanted to spend the $$$ I just upgraded my welder from a Miller 140 to a Miller 211.
    mdavis and jberry813 like this.
  7. May 9, 2017 at 6:45 PM
    JMB
    Chesapeake, VA
    2013 Super White Tundra DC
    What he said, but, if you do decide to go with a plasma cutter, or oxy-acetylene, or even a grinder with cutting wheels, PRACTICE before you cut into something that you care about. Find scrap metal and learn about the machine adjustments, eye hand coordination, control of the tool and the safety aspects at a minimum. Having been a shipfitter in a previous life, you can't screw something up beyond repair, but you might not want to pay the price to make the repair. Unless of course if you kill yourself or someone else. Not trying to be overly dramatic, but I've seen a guy die from careless torch handling.
  8. May 10, 2017 at 9:58 AM
    Spvrtan
    Spvrtan Amateur fabricator
    Kris
    San Diego, CA
    Black '14 CM SR5 w/ SC; 40s on 17s; 5.29s
  9. May 10, 2017 at 11:07 AM
    ej63090
    ej63090 New Member
    Eric
    McHenry, Illinois
    2017 White Crewmax SR5
    That is not a bad price. Welding is next on my list after I finish building out my woodworking arsenal. Truck mods are coming first. I need to do more side work.
    ColoradoTJ likes this.
  10. May 10, 2017 at 11:39 PM
    zackbremer
    zackbremer New Member
    Da Z
    nvm saw shock pic a few post after.
    Darth Tundra likes this.
  11. May 11, 2017 at 4:30 AM
    DVYota
    DVYota Super stock street truck
    2014 Sequoia 2021 Tacoma
    Basically stock
    Surprised it's not SUA.
    I miss riding at Coos Bay when I was younger.
    Darth Tundra[QUOTED] likes this.
  12. May 11, 2017 at 7:09 AM
    TexasMofo
    TexasMofo New Member
    Chad
    Great Country of Texas
    2017 Toyota Tundra TRD Pro
    Illegal Tint 2 Shims/ 3 inch Shacke
    Grinder with a cutting wheel. You can buy the wheels at Lowes, homedepot or tractor supply. I have cut everything with those, from frames to thin metal.
