  1. Sep 17, 2021 at 12:47 PM
    Wangofree
    Wangofree New Member
    Midwest
    07 Tundra Double Cab 5.7L
    Decided to upgrade the tires on our RV travel trailer. (Ok, not officially something to do with our Tundra, but it was towing the RV when the tire exploded).
    :threadjacked:
    D4x4TRD, WVI, joseph_womack and 3 others like this.
  2. Sep 17, 2021 at 3:09 PM
    Rozr1
    Rozr1 New Member
    2008 SR5 DC
    Got my ebay homelink mirror in, easy upgrade.
    Zebruaj, RJVA, Danny3737 and 7 others like this.
  3. Sep 17, 2021 at 10:09 PM
    Retroboy1989
    Northern Utah
    Your truck looks good with those wheels and thr flairs.
    joseph_womack likes this.
  4. Sep 18, 2021 at 10:32 AM
    Danny3737
    Danny3737 New Member
    2012 Tundra Limited Platinum
    D0DC9082-364C-483D-9787-18E6EB00C8FD.jpg 0DA413CE-8781-4915-82D8-D1BD9855DA09.jpg 26148E55-58DD-40A2-B85A-E17737FDC889.jpg
    Although I love the safe, the tray that came with it is completely useless and the metal edges at the top can be a little sharp. To help with the sharp edges, I used some door edge guard that fit perfectly. Instead of using the tray, I bought some cheap tupperware from the Dollar Tree. Bought two different sizes just to see how I liked them. I know its not sexy, but I’m the only one who will see them. I also put a small Tupperware container at the bottom as well.
  5. Sep 18, 2021 at 2:48 PM
    RJVA
    RJVA Former Lurker
    Richard
    Idaho
    2008 Tundra Silver DC 4.7 4x4
    OEM 18" wheels off a 2.5 gen 275/70/18 Falken Rubitrek A/T FabFour Redsteel front bumper with HF winch. Dobinsons IMS with 2.25" coils (610) JBA UCA's Iron Man +300lb rear leaf packs with Dobinsons IMS shocks ECGS bushing in front diff Black Oak Led Flood Pods. 40watt (x2) Black Oak 20" light bar. 100 watt OEM style rear bumper, black powder coat, added aux reverse leds. Stubby AM/FM antenna Century Camper Shell with Roof rack and bed mat
    Did an oil change with 5w-30 Rotella Gas Truck and an oversize Purolator. New air filter and cabin filter too. Greased UCA's, LBJ's and shackles as well. Also filled up and calculated 16.5 mpg for the last tank. Not too shabby.
  6. Sep 18, 2021 at 7:50 PM
    BlackSheep
    BlackSheep ol’ Reliable
    Scott
    Kansas City, MO
    2010 Black DC 5.7L 4x4
    2.5” shocks, 3/1 level, 37s, 5.29s, air locker, on-board air, bed cap, bed stiffeners, roof rack, steps/sliders, spare carrier, under seat storage bins, window tint
    Today I finally cleaned up the mess of wires in my bed that serves my fuse block, cap dome light, inverter, and air compressor. Also relocated the 100 amp fuse from the engine bay to the bed because it kept rattling around and losing connection. I mounted the fuse block and the big fuse to a wood plank I bolted to my uni-strut rails. Boy, does it feel good to have that mess cleaned up.
    Blang805, RJVA, MTRock and 1 other person like this.
  7. Sep 19, 2021 at 11:31 AM
    azimuth
    azimuth New Member
    2010 double cab SR5
    I wired my OEM style power fold mirror switch to operate my Boost Auto mirrors. Boost provides a switch with their harness. It's okay. It works well, but it does not fit our switch holes without cutting. I didn't want to cut my dash so I jammed the switch into the hole which worked until I could wire the OEM style. I wrote the step by step here with pics and commentary https://www.tundras.com/threads/power-folding-mirrors-boost-auto-parts.71874/#post-1916248
    The OP has a 3rd gen and his plug harness is a little different than my second gen so between the two of us (Toshito and me) we figured it out. Piece of cake. Took me 20 mins start to finish. Knowing how to do it now, I could git 'er dun in 10. Here it is in the pic below.
    Also, I added this exhaust tip. Gained like 50 horse power.
  8. Sep 19, 2021 at 1:14 PM
    Danny3737
    If you fold in the mirrors when you’re driving, you pick up another 10 MPG.
  9. Sep 19, 2021 at 2:42 PM
    biebs96
    PA
    I would love to have some details on this exhaust tip?
    specifically.. where did you buy it?!?
  10. Sep 19, 2021 at 3:02 PM
    Danny3737
    +1
    biebs96[QUOTED] likes this.
  11. Sep 19, 2021 at 3:07 PM
    azimuth
    azimuth New Member
    2010 double cab SR5
    Well……I made it. Kinda. More like this was an exhaust tip that was on the truck when I bought it but miles and years had imposed some surface rust on it. I like the size and style so I media blasted it and cerakoted it black. Then I found the TRD emblem on eBay. It is aluminum so I gradually bent it to match the radius of the exhaust tip. Came with adhesive already installed so I placed it where I thought it looked best. Time will tell if the emblem can take the weather and heat. It is made for outdoors use. If you are still interested, I can find and post the source links
    ETA Emblem link: https://www.ebay.com/itm/263367857284
    I think this is the exhaust tip: https://www.autozone.com/exhaust/ex...eel-4in-x-10in-bolt-on-exhaust-tip/141703_0_0
    Post Script: Seems the emblem can take the heat without losing the adhesive. I’m confident it will continue to last.
  12. Sep 19, 2021 at 3:10 PM
    biebs96
    PA
    Love the diy approach. It looks great!
    WVI likes this.
  13. Sep 19, 2021 at 9:52 PM
    McYoda
    McYoda H4x0r
    Brady
    Oregon
    2010 “Grade”
    It's not a lot, but I finally replaced the lower valance. That was a bigger PITA than I expected. Previous owner had hit at least one or two deer, so the original grill was shredded and the bumper had all kinds of random damage to it. Whoever put it back together last time, left out a few of the pins and screws in various places.
    I think I've finally got her about where I'm happy. There's still a hole in the passenger side of the bumper and some scrapes on the bumper, but that makes it easier to not care if someone taps my truck or slams a cart into it.
    rebmo, Marcstryd, D4x4TRD and 10 others like this.
  14. Sep 19, 2021 at 10:27 PM
    Taco-Blender
    Taco-Blender Old Guys Rule
    AZ
    2010 DC 4x4
    Expanded the lineage thru 2021?
    :boink:
  15. Sep 20, 2021 at 6:18 AM
    Danny3737
  16. Sep 20, 2021 at 7:07 AM
    Retroboy1989
    Northern Utah
    Oh no, the third gen folks won't like being lumped back in with us.
  17. Sep 20, 2021 at 8:38 AM
    Bikeric
    Bikeric New Member
    Eric
    2007 DC 5.7
    Blown Engine.....
    So....if it could have came with the 5.7......It's a SECOND GEN!!!! HaHaHaHa :rofl:
    Taco-Blender[QUOTED] likes this.
  18. Sep 20, 2021 at 1:38 PM
    surffj62
    surffj62 New Member
    2011 DBL RW
    Fixed my broken antenna. Tried backing out the treads with every trick possible. No dice.
    I ordered a cable / mast from Toyota on Amazon. Couldn’t find a 2nd gen video or replacement but there is a third gen that is very similar on how to disassemble the passenger dash.
    I’ve put this aside for 2 years. Wasn’t hard to do at all- it doesn’t get routed all the way to head unit like I thought- the is a male / female plug behind the passenger pillar.
    Mountun Goat likes this.
  19. Sep 20, 2021 at 3:32 PM
    Tundra Fan
    Tundra Fan Got 17's?
    Toby
    Nor Cal (Placer Co.)
    2013 Platinum-SOLD 2022 Sequoia, Celestial Silver Metallic
    I'll second that it is a PITA to replace that piece. The whole damn front end has to come apart. I broke one of the tabs on the piece under the headlight on mine. :mad:
  20. Sep 20, 2021 at 3:33 PM
    Tundra Fan
    Toby
    Toyota never considered the 2014+ a third gen, just a refresh.
    FrogmanTundra likes this.
  21. Sep 20, 2021 at 3:42 PM
    Taco-Blender
    AZ
    2010 DC 4x4
    Correct! But! That's not what the '14+ boys will tell you.
  22. Sep 20, 2021 at 3:53 PM
    Taco-Blender
    AZ
    2010 DC 4x4
    Thanks for posting this up @kparrow
    Got the $20 off and it took a couple of weeks to get them, but they arrived today. Seem to be a bit sturdier than the OEM pieces too. Then again, all 4 of mine were completely shot and just hanging on at the ends. We'll see how they hold up.
  23. Sep 20, 2021 at 7:01 PM
    NueveTundra
    NueveTundra Mod list in Bio
    Planet Earth
    07, Black Tundra SR5 CrewMax
    Exterior: Toytec ultimate 3" lift level, Total Chaos Uniball UCA's, Total Chaos Cam Tab Gusset kit, AcanII smoked headlights, AcanII smoke Tail lights (2.5 gen style), DV8 front winch bumper , Badlands 12k winch with Apex Synthetic, White AUTMATCH Shackles 3/4" D Ring Shackle, Apex Winch shackle, Trail Ridge mirrors ,Icon Rebound Pro 17"x8.5" +25, Cooper Discovery STT Pro 285/70R17, PowerStop drilled n slotted rotors W/Carbon pads, Rigid flood flush mounts rear bumper , WeatherTec rain guards , OEM black side badges , Rigid Amber Radiance Pods. Energy Suspension Red Rack and Pinion Bushings, EAG front mesh Grille, RCI HighLift bed mounts. Rough Country DS2 Steps, A.R.E OverLand Canopy with Ascend basket, Stickers: ToyTec lifts windshield banner, Red Strange Music window sticker(back cab), White Strange Music sticker(back canopy), White Rigid sticker x2 (canopy sides), white Official BigFoot Research Team (Back Canopy) Interior: Alpine double din touch iLX-650 , JL C5-653's (front) JL C1-650x (rear) , JL JX400 4 channel amp , JL JX500 mono amp , 2 JL 12" subs , WeatherTec floor mats, Kenwood F/R Dash Cams, Black steering wheel emblem overlay, Tekonsha P3 Brake controller, ToyTec "Fresh" Scent coilover air freshener, Under the Hood: Koyo all aluminum radiator, Mishimoto red silicon hoses , XS Power 3000 amp battery , LAlectric 300 amp Alternator , K&N replacement filter. Online LED store accessories Fuse/relay box. (Identified) Dirty Deeds 8" Cat back exhaust with DD resonator delete/axel over converted into dump. Coming soon:
    Toke the OEM mud guards off , made the truck look so much better , ended up going to finally get around to replacing the Rear shackles and putting on my Daystar cups. But my rear leafs are shot , so going to order up new leaf packs and do it then , along with all new front Lowers and bushings, SPC uppers , swaybar links and all associated hardware.
  24. Sep 20, 2021 at 7:21 PM
    Bucks04
    Bucks04 New Member
    2013 TRD Tundra
    Working on it
    One trick I learned was one of those little screw drivers with the small magnet on end , has backed out more than one for me. Usually the screw breaks but stays loose.
  25. Sep 21, 2021 at 4:58 PM
    Zebruaj
    Zebruaj New Member
    MN
    08 CM SR5
    Changed out my rear rotor and pads. MN corrosion got the best of them. Been noticing the squeaks for a couple weeks.
  26. Sep 21, 2021 at 4:58 PM
    FrogmanTundra
    FrogmanTundra New Member
    Nashville
    2013 Rock Warrior DC
    Installed the Diode Dynamic SS3 Pro yellow fog lights on Saturday. Really liking them so far, they have a very wide beam. They compliment my Alpharex Pros with GTR Ultra 2 bulbs quite well, may need to adjust the headlights up a bit but at least I'm not blinding on coming traffic.
    Marcstryd, TheBeast, D4x4TRD and 13 others like this.
  27. Sep 23, 2021 at 8:45 AM
    Bikeric
    Bikeric New Member
    Eric
    2007 DC 5.7
    Blown Engine.....
    Did a quick ride by the river after work with my buddy. I noticed the trans temp climb slightly as I powered through the deep sand so I might be looking into a larger tranny cooler.
  28. Sep 23, 2021 at 8:57 AM
    goathauler11
    goathauler11 New Member
    2011 Black Tundra Crewmax TRD Rock Warrior
    Made a roof rack for the topper to clear up the bed for the dog when we camp. Our gear doubled camping with a baby!20210922_192120.jpg
  29. Sep 23, 2021 at 9:00 AM
    LATERAL G
    LATERAL G New Member
    2013 RCSB SR5 TRD Off-Road 5.7 4x4
    17" Black Rhino Stadium wheels installed this weekendPXL_20210917_155312190.jpg
  30. Sep 23, 2021 at 9:17 AM
    zcarpenter92
    zcarpenter92 Yotas and Yellow Jackets
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
    I find the whole generation “correction” interesting. I’ve had dealer personnel refer to the 14+ Tundras as 3rd gens, and we all referred to them as 3rd gens. Did we all just assume that, or does anyone else think of this as a revision by Toyota for some dumb marketing purposes?
