Justdifferentials
Discussion in '1st Gen Tundras (2000-2006)' started by tyler-brown, Sep 16, 2021.
  1. Sep 16, 2021 at 7:12 AM
    tyler-brown
    tyler-brown [OP] New Member
    Canada, B.C.
    2001 AC Tundra V8 LTD 4x4
    5" tuff country lift 2.5" Eibach front coil overs SPC upper control arms 33x12.5's JBA long tubes Jba mid pipes Jba full exhaust & muffler Dirty deeds 12 hole injectors Front hitch receiver
    Hey guys,
    'Bout to make an order from these guys, just reaching out if anyone has/knows of active coupon codes at the moment.
    Thanks! :burnrubber::mudding:
    Darkness likes this.
  2. Sep 16, 2021 at 8:05 AM
    Just hitting their home page, in the lower left corner there's a link for 5% off if you give them your email.
    Outside of that, I'm not finding anything worthwhile from my usual sources.
  3. Sep 16, 2021 at 10:24 AM
    Whatchya gettin?
  4. Sep 16, 2021 at 12:47 PM
    tyler-brown
    Canada, B.C.
    Only difference is being in Canada it'll be just shy of about 5gs for me. Which is why some kinda coupon would be nice haha
    bmf4069 and dbittle like this.
  5. Sep 16, 2021 at 3:17 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Sweeeeeeet. Hit them up and ask about solid collar upgrades. Its cheap, stronger, and your install guy will thank you.
    Usually kits come with a collapsing collar. If your guy gets the shims dead right first try thats okay, but if he is off at all he has to recalculate when the collar crushes. Solid collars let them have a constant to work with. :thumbsup:
    You're gonna like 4.56
    bmf4069 and FrenchToasty like this.
  6. Sep 16, 2021 at 5:31 PM
    tyler-brown
    Canada, B.C.
    Awesome thankyou for taking the time to check
    Awesome thanks for the recommendation! I guess I'll just call them than to make sure to get that part as well
  7. Sep 22, 2021 at 3:03 PM
    HamGardener
    HamGardener New Member
    Matthew
    So a helical in the rear and an e-Locker in the front. Similar combination to what I've been considering, but I keep finding pretty negative opinions of rear LSDs on off-road forums. Everyone seems to think the torque delivered to the low traction wheel is insufficient for off-road use. Everyone seems to evaluate clutch type LSDs not a Torsen, though. I'd really like to know how this combination works out for you, tyler-brown! Keep us posted!
  8. Sep 22, 2021 at 3:32 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    Locker or selectable (air or electric) for the rear. If for heavier off road use (any type of off roading that could lead to a rear wheel being air borne or zero traction on one side).
    Dirt roads, gravel, sand, snow, etc an LSD is (clutch or gear/torsen).
    Don't bother with the front unless you want heavier steering and other possible problems. IMO
  9. Sep 22, 2021 at 3:46 PM
    tyler-brown
    Canada, B.C.
    yah like...I suppose it depends on what you wanna do with your truck. The stock LSD in the rear has been working fine for me all these years, but since Iam pretty much rebuilding the rear end, figured i'd be crazy not to freshen that up as well.
    In my opinion for what I do off road. Ive seen locked fronts go MUCH further than locked rear & open front. The non-power tire front just acts like an anchor. IMO.
    Having selectable up front will give me better road manners, and tire wire. More for oopsie situations than an all day driver. If that was the case the smart bet would be on a SAS (which isnt in the plans)
    des2mtn and Darkness like this.
  10. Sep 22, 2021 at 3:56 PM
    Cummins3500
    Logan
    Did I miss what tire size your running?
  11. Sep 22, 2021 at 3:57 PM
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    True.
    I did torsen front and locker rear on my Tacoma. I also have manual hubs so I would leave the front unlocked until I actually needed it lol.
    des2mtn likes this.
  12. Sep 22, 2021 at 4:43 PM
    tyler-brown
    Canada, B.C.
    33x12.5
    Cummins3500[QUOTED] likes this.
  13. Sep 23, 2021 at 8:22 AM
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz
    06 Double Cab 360k+
    I always do rear locker, selectable if it will be primarily street driven. Front selectable, but only when you need it. I’ve seen lots of snapped CV’s from front lockers.
    Look up how the Torsen works, I believe they do not work when a tire is lifted off the ground. It’s hard to beat an Auburn limited slip for normal use.
    Tacoma, front open, rear ARB. Debated front ARB.
    Juggy, front ARB, rear Detroit Locker.
    FrenchToasty, Darkness and Lil Steve like this.
