Best differential fluid to use
Discussion in 'General Tundra Discussion' started by Oregon 1 Toyo, May 9, 2018.
  1. Sep 22, 2021 at 2:14 PM
    #91
    Spyker
    Spyker I’m a dude,playin a dude,disguised as another dude
    Does anyone have the torque specs for the front & rear diffs (drain & fill plugs)?
    can’t find the ‘book’ answer.
    ARKANSASMARINE and Doxiedad like this.
  2. Sep 22, 2021 at 2:27 PM
    #92
    AZBoatHauler
    So.Arizona
    I’m pretty sure it is:
    Front differential: 29 ft/lb
    Transfer case: 27 ft/lb
    rear differential: 36 ft/lb
    People seem to agree 27 is too high for the t-case and just go snug due to the plug design.
  3. Sep 22, 2021 at 2:32 PM
    #93
    Spyker
    for the front & rear diff, is that for both the drain & fill plugs?
  4. Sep 22, 2021 at 2:34 PM
    #94
    AZBoatHauler
    So.Arizona
    Yes - are you 2007-2021?
    Spyker[QUOTED] likes this.
  5. Sep 22, 2021 at 2:38 PM
    #95
    Spyker
    Yup, 2020
  6. Sep 22, 2021 at 4:02 PM
    #96
    AnthonyC
    AnthonyC TAKE IT EASY WHILE YOU"RE GOING FAST
    Anthony
    Virginia Beach, VA
    2010 Tundra SR5 TRD DOUBLE CAB
    TRD DUAL EXHAUST, FIRESTONE AIR BAGS
    I’d just like to add one thing, if you’ve never did the front differential. Do yourself a favor and use a good quality Allen socket. Clean the corners of the hex as best as you can of the fill plug. I use a Snap-On Allen socket. I had to tap it in the fill plug a little at a time and took it back out before I even tried to loosen the fill plug. Finally got the Allen all the way in the fill plug. It really feels like it’s very tight. Always remove the fill plug first just in case there’s an issue with the leading edges of the fill plug. My fill plug felt like it had 50 ft lbs of torque. It really didn’t but that’s what it feels like when removed for the first time. If you don’t have a torque wrench just make it snug that’s all! The drain plug was much easier to remove, and I can’t explain why. Use whatever oil you choose as mentioned. Keep it to the specifications if that pleases you. I use the AMSOIL 85/140 because I pull a 6,500 lb. travel trailer quite a bit. I don’t force the issue pulling steep hills on the secondary roads, I try very hard not to go above 65MPH on the 4 lane hiways. At that speed in 5th gear I get 10.1 MPG, I feel that’s pretty good for what I’m pulling.
  7. Sep 25, 2021 at 10:24 PM
    #97
    mgnchakar
    mgnchakar New Member
    2016 Black Tundra TRD 4x4
    Side effects if you have not changed the diff fluid? I am at 60k on my 4x4. Do not tow anything.
    do you have to pump it in?
  8. Sep 25, 2021 at 11:54 PM
    #98
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    I did my first one at 57K. I don’t tow either and it looked fine to me. I used Amsoil 75w90
  9. Sep 26, 2021 at 5:39 AM
    #99
    Spyker
    you can either pump it in (hand pump or drill pump) or use a ‘squeezable’ bottle to squeeze it in, both will work just fine. Have you changed the diff fluid before? Or is it going on 60k with the original fluid?
  10. Oct 11, 2021 at 7:03 PM
    #100
    GunWanderer
    GunWanderer New Member
    2019 Tundra SR5 4x4
  11. Oct 30, 2021 at 1:32 PM
    #101
    Heath423
    Heath423 New Member
    Heath
    Chattanooga, TN
    2020 Magnetic Gray CM SR5 4WD
    Console tray/dividers, Interior LED's
    Blauparts.com has a sale on stated fluids above. 10% and free shipping "economy shipping" over $100. Placed my order.
  12. Oct 30, 2021 at 10:51 PM
    #102
    Doxiedad
    Doxiedad Distinguished Member
    James
    Charleston, SC
    2020 Tundra SR5 TRD Off Road Cavalry Blue
    I just ordered my parts from Blauparts.com Question though, I looked through out this entire thread and didn't see any mention of crush washers needed for fill/drain plugs? I know when I did this service on my 2016 4Runner I had to get new crush washers for front and rear diff as well as transfer case. Does my 2020 Tundra need them too?
  13. Oct 31, 2021 at 6:23 AM
    #103
    Spyker
    cant take credit for the photo or info, but this is the info I used when I changed my diff fluid and all went well;
  14. Jan 5, 2023 at 5:59 PM
    #104
    ARKANSASMARINE
    ARKANSASMARINE New Member
    09-Whitw Crewmax
    7" BDS lift.
    Any idea what "it" is? Vescosity and brand? thx
  15. Jan 6, 2023 at 6:54 AM
    #105
    ToolCat
    ToolCat New Member
    Greg
    For a higher mileage Tundra, I recommend the RedLine Heavy Shockproof in the differentials.
    (No affiliation, just a satisfied user).
    The Heavy Shockproof has a viscosity index of 75W-90, but protects like a 75W-250!
    Redline makes a Light Shockproof as well, if you want to run thinner gear oil.
    Both are rated for extreme applications, and protect so well they are considered “liquid grease” by the industry.
    Not cheap, a gallon of Heavy Shockproof is about $80.
    ToolCat
  16. Jan 6, 2023 at 7:31 PM
    #106
    ARKANSASMARINE
    09-Whitw Crewmax
    7" BDS lift.
    lemme know if you have it or not, yet. I have the Chiltons manual and im betting its in there. Its outside in the truck, and its colllllld out there, so me not goin out there unless....LOL
  17. Jan 7, 2023 at 1:25 AM
    #107
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    I hope he found them 2 years ago lol
    Spyker likes this.
  18. Jan 7, 2023 at 1:53 AM
    #108
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    My understanding is he got close. Theeeeeeeeeeeeennnnnn......he looked up and there was a damn squirrel in a tree.
    Joe333x[QUOTED] likes this.
  19. Jan 7, 2023 at 3:53 AM
    #109
    ARKANSASMARINE
    09-Whitw Crewmax
    7" BDS lift.
    I hope so lol
    Spyker and Joe333x[QUOTED] like this.
  20. Jan 7, 2023 at 6:49 AM
    #110
    Ellis42sbgtf
    Ellis42sbgtf New Member
    Kyle
    Houghton, MI
    2018 Crewmax TRD Sport 4x4
    There’s a couple YouTube videos where they give the torque rating. I want to say it was like 30ish lb/ft of torque.
    Spyker likes this.
  21. Apr 28, 2025 at 4:42 PM
    #111
    TheBeast
    TheBeast The Beach
  22. Apr 28, 2025 at 5:15 PM
    #112
    Joe333x
    Joe333x Member
    Boston
    TheBeast[QUOTED] likes this.
  23. Apr 28, 2025 at 9:51 PM
    #113
    TheBeast
    TheBeast The Beach
  24. Apr 29, 2025 at 6:13 PM
    #114
    coldcanuk
    coldcanuk New Member
    2021 Tundra Platinum
    Amsoil now has 75w85. Old news by now I guess but all the Toyota owners no longer have to use the 75W90 stuff.
